Perfdata: Nagios not painting performance graphs
FCC_Nagios_Support
Re: Perfdata: Nagios not painting performance graphs
[root@a2nagio001p mrtg]# ll /var/lock/
total 0
drwx------ 2 root root 60 Aug 5 15:09 iscsi
-rw-r--r-- 1 root root 0 Aug 5 15:09 kdump
drwxrwxr-x 2 root lock 40 Aug 5 15:09 lockdev
drwx------ 2 root root 40 Aug 5 15:09 lvm
drwxr-xr-x 2 root root 40 Aug 5 15:09 ppp
drwxr-xr-x 2 root root 120 Aug 5 15:10 subsys
total 0
benjaminsmith
A couple of questions. After you installed the RAMDISK, were the performance graphs working? Are you able to re-start the ncpd service from the command line?
Are you able to view the lock file?
I'd like to get a current profile since installing the RAMDISK. Thanks, Benjamin
To send us your system profile.
Login to the Nagios XI GUI using a web browser.
Save the profile.zip file and share in a private message or upload it to the post/ticket, and then reply to this post to bring it up in the queue.
systemctl restart npcd
ls -l /usr/local/nagiosxi/var/subsys/npcd.pid
FCC_Nagios_Support
Good evening
We did both things:
Restart npcd
and locate .pid
-rw-r--r-- 1 root root 4 Aug 10 10:10 /usr/local/nagiosxi/var/subsys/npcd.pid
[root@a2nagio001p etc]# systemctl status npcd
● npcd.service - LSB: Nagios NPCD Initscript
Loaded: loaded (/etc/rc.d/init.d/npcd; bad; vendor preset: disabled)
Active: active (running) since Mon 2020-08-10 10:10:20 CEST; 8h ago
Docs: man:systemd-sysv-generator(8)
Process: 6373 ExecStop=/etc/rc.d/init.d/npcd stop (code=exited, status=0/SUCCESS)
Process: 6387 ExecStart=/etc/rc.d/init.d/npcd start (code=exited, status=0/SUCCESS)
Main PID: 6390 (npcd)
CGroup: /system.slice/npcd.service
└─6390 /usr/local/nagios/bin/npcd -d -f /usr/local/nagios/etc/pnp/npcd.cfg
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
I attach profile
Many Thnks in advance
KR
Moderator's Note: The profile has been shared with the support team but has been removed from the public forum
We did both things:
Restart npcd
and locate .pid
I attach profile
KR
FCC_Nagios_Support
Yes before RAMDISK installatiion Performnace Graph was running ok
FCC_Nagios_Support
I restart crond
service crond restart
and see movement
[root@a2nagio001p nagiosramdisk]# find .
./host-perfdata
./service-perfdata
./status.dat
./objects.cache
./spool
./spool/perfdata
./spool/perfdata/1597133288.perfdata.service
./spool/perfdata/1597133289.perfdata.host
./spool/xidpe
./spool/checkresults
./tmp
I restart crond
and see movement
./host-perfdata
./service-perfdata
./status.dat
./objects.cache
./spool
./spool/perfdata
./spool/xidpe
./tmp
FCC_Nagios_Support
I restart crond with service crond restart
I saw movement
Every 2.0s: find . Tue Aug 11 10:13:25 2020
./status.dat
./service-perfdata
./host-perfdata
./objects.cache
./spool
./spool/perfdata
./spool/xidpe
./spool/xidpe/1597133604.perfdata.service
./spool/xidpe/1597133604.perfdata.host
./tmp
but no painting
I saw movement
./status.dat
./service-perfdata
./host-perfdata
./objects.cache
./spool
./spool/perfdata
./spool/xidpe
./tmp
but no painting
FCC_Nagios_Support
[root@a2nagio001p ~]# tail -f /usr/local/nagios/var/npcd.log
[08-10-2020 10:10:20] NPCD: Please have a look at 'npcd -V' to get license information
[08-10-2020 10:10:20] NPCD: HINT: load_threshold is enabled - ('60.000000')
[08-11-2020 09:43:18] NPCD: Caught Termination Signal - Hasta la vista... baby
[08-11-2020 09:43:18] NPCD: npcd Daemon (0.4.14) started with PID=26156
[08-11-2020 09:43:18] NPCD: Please have a look at 'npcd -V' to get license information
[08-11-2020 09:43:18] NPCD: HINT: load_threshold is enabled - ('60.000000')
[08-11-2020 09:45:42] NPCD: ERROR: Executed command exits with return code '7'
[08-11-2020 09:45:42] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /var/nagiosramdisk/spool/perfdata//1597131908.perfdata.service'
[08-11-2020 09:46:42] NPCD: ERROR: Executed command exits with return code '7'
[08-11-2020 09:46:42] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /var/nagiosramdisk/spool/perfdata//1597131968.perfdata.service'
FCC_Nagios_Support
[root@a2nagio001p ~]# systemctl status npcd.service
Active: active (running) since Tue 2020-08-11 10:30:25 CEST; 5s ago
Process: 64086 ExecStop=/etc/rc.d/init.d/npcd stop (code=exited, status=0/SUCCESS)
Process: 65104 ExecStart=/etc/rc.d/init.d/npcd start (code=exited, status=0/SUCCESS)
Main PID: 65109 (npcd)
└─65109 /usr/local/nagios/bin/npcd -d -f /usr/local/nagios/etc/pnp/npcd.cfg
Aug 11 10:30:25 a2nagio001p.fcc.intfcc.local systemd[1]: Starting LSB: Nagios NPCD Initscript...
Aug 11 10:30:25 a2nagio001p.fcc.intfcc.local npcd[65104]: NPCD started.
Aug 11 10:30:25 a2nagio001p.fcc.intfcc.local systemd[1]: Failed to read PID from file /usr/local/nagiosxi/var/subsys/npcd.pid: Invalid argument
Aug 11 10:30:25 a2nagio001p.fcc.intfcc.local systemd[1]: Started LSB: Nagios NPCD Initscript.
FCC_Nagios_Support
[root@a2nagio001p ~]# tail -f /usr/local/nagiosxi/var/perfdataproc.log
Outbound data DISABLED Tue, 11 Aug 2020 10:55:01 +0200
Outbound data DISABLED Tue, 11 Aug 2020 10:56:01 +0200
DONE. Processed 0 files.
Outbound data DISABLED Tue, 11 Aug 2020 10:57:01 +0200
Outbound data DISABLED Tue, 11 Aug 2020 10:58:01 +0200
Outbound data DISABLED Tue, 11 Aug 2020 10:59:01 +0200
Outbound data DISABLED Tue, 11 Aug 2020 11:00:01 +0200
FCC_Nagios_Support
We got some improve:
diff /usr/local/nagiosxi/var/xi-sys.cfg /usr/local/nagiosxi/var/xi-sys.cfg.20200811
[root@a2nagio001p nagiosramdisk]# diff /usr/local/nagiosxi/var/xi-sys.cfg /usr/local/nagiosxi/var/xi-sys.cfg.20200811
34,35c34,35
< cfg__xidpe_dir='/var/nagiosramdisk/spool/xidpe'
< cfg__perfdata_spool='/var/nagiosramdisk/spool/perfdata'
> cfg__xidpe_dir='/usr/local/nagios/var/spool/xidpe/'
> cfg__perfdata_spool='/usr/local/nagios/var/spool/perfdata/'
34,35c34,35
