GUI issues after 5.6.12 -> 5.7.1 upgrade
sib
Re: GUI issues after 5.6.12 -> 5.7.1 upgrade
Post by sib »
What is the state on this? It has not been working for a long time
# cat /etc/my.cnf
[mysqld]
innodb_file_per_table=1
datadir=/var/lib/mysql
socket=/var/lib/mysql/mysql.sock
# Disabling symbolic-links is recommended to prevent assorted security risks
symbolic-links=0
# Settings user and group are ignored when systemd is used.
# If you need to run mysqld under a different user or group,
# customize your systemd unit file for mariadb according to the
# instructions in http://fedoraproject.org/wiki/Systemd
[mysqld_safe]
log-error=/var/log/mariadb/mariadb.log
pid-file=/var/run/mariadb/mariadb.pid
# include all files from the config directory
!includedir /etc/my.cnf.d
benjaminsmith
Post by benjaminsmith »
Hi @sib,
The database configuration file looks ok. At this point, I would recommend downgrading the backend database utility to the previous version, see the instructions below. Let me know if you need any assistance.
Downgrade Instructons (Local Database)
systemctl stop nagios
cd /tmp
rm -rf /tmp/nagiosxi
wget https://assets.nagios.com/downloads/nagiosxi/5/xi-5.6.14.tar.gz
tar zxf xi-5.6.14.tar.gz
cd /tmp/nagiosxi/subcomponents/ndoutils
./install
systemctl enable ndo2db
Then edit your /usr/local/nagios/etc/nagios.cfg and make sure this line is uncommented:
broker_module=/usr/local/nagios/bin/ndomod.o config_file=/usr/local/nagios/etc/ndomod.cfg
Make sure this line is commented:
#broker_module=/usr/local/nagios/bin/ndo.so /usr/local/nagios/etc/ndo.cfg
Then start the nagios service:
systemctl start nagios
sib
Post by sib »
Hi
what is the downgrade procedure for RPM installs?
benjaminsmith
Hi @Sib,
As long as you have the development packages on the server, it would be the same process used on the standard installs, as follow:
cd /tmp
./install
sib
Post by sib »
Hi
This "solved" the issue. I hope it will be fixed in 5.7.3?
benjaminsmith
Hi Sib,
Glad to hear that helped resolve the issue for now. I should have more information on the next release late next week.
