check_snmp on Ubuntu Server 12.04 - Bug?
agriffin
Re: check_snmp on Ubuntu Server 12.04 - Bug?
Post by agriffin »
Thanks for sharing - good to see you got it working!
neffets
Post by neffets »
LHammonds wrote:The bug regarding the install / uninstall / re-install is too minor for me to worry about since I can work around that.
However, the check_snmp issue is not an easy issue to resolve.
Does anyone have a 12.04 server running with a functional check_snmp using sysUpTime, sysName, sysContact or sysLocation?
The MIB packages are not automatically installed due to license problems.
Install all MIBs via:
apt-get install snmp-mibs-downloader
it will after installation automatically start the download of a lot of MIBs.
Its special: snmpwalk will show only numeric values further, BUT You cann now ask for string-expressions like "sysUpTime.0"
