SQL Error [nagiosxi] : ERROR: syntax error at or near
Re: SQL Error [nagiosxi] : ERROR: syntax error at or near
Hi , aaply runs as usual. +/- 7-20 sec. After that the mysql process keeps running at 100-120 % for about +/- 5 minutes.
See the PM I sent about the need to install ndoutils on the system to fix the slow status updates and the MYSQL load.
acties are done. After apply services return whitin short time with result. Also mysql process is not spinning as far i can see.
cleaner.log still shows errors:
Running callbacks:
<p><pre>SQL Error [nagiosxi] : ERROR: syntax error at or near "24"
LINE 1: ..._deploy_agents WHERE last_status_check + INTERVAL 24 HOUR <=...
^</pre></p>
DIR: /usr/local/nagiosxi/nom/checkpoints/nagioscore
NUMFOUND: 10
KEEPING ALL GOOD CHECKPOINTS
DIR: /usr/local/nagiosxi/nom/checkpoints/nagioscore/errors
ls: cannot access /usr/local/nagiosxi/nom/checkpoints/nagioscore/errors/*.gz: No such file or directory
NUMFOUND: 0
KEEPING ALL ERROR CHECKPOINTS
DIR: /usr/local/nagiosxi/nom/checkpoints/nagiosxi
NUMFOUND: 10
KEEPING ALL SNAPSHOTS
Running callbacks:
^</pre></p>
NUMFOUND: 11
ALL:
1597953333.tar.gz
1597953333.txt
1597952804.tar.gz
1597952804.txt
1597932933.tar.gz
1597932933.txt
1597875902.tar.gz
1597875902.txt
1597865329.tar.gz
1597865329.txt
1597864778.tar.gz
1597864778.txt
1597839204.tar.gz
1597839204.txt
1597824500.tar.gz
1597824500.txt
1597822045.tar.gz
1597822045.txt
1597789442.tar.gz
1597789442.txt
1597737134.tar.gz
1597737134.txt
errors
LAST GOOD CHECKPOINT TO KEEP: /usr/local/nagiosxi/nom/checkpoints/nagioscore/1597737134.tar.gz
DELETING OLD TEXT FILES...
DELETING OLD TARBALL FILES...
NUMFOUND: 0
NUMFOUND: 11
ALL:
1597953333_nagiosql.sql.gz
1597952804_nagiosql.sql.gz
1597932933_nagiosql.sql.gz
1597875902_nagiosql.sql.gz
1597865329_nagiosql.sql.gz
1597864778_nagiosql.sql.gz
1597839204_nagiosql.sql.gz
1597824500_nagiosql.sql.gz
1597822045_nagiosql.sql.gz
1597789442_nagiosql.sql.gz
1597737134_nagiosql.sql.gz
LAST GOOD SNAPSHOTS TO KEEP: /usr/local/nagiosxi/nom/checkpoints/nagiosxi/1597737134_nagiosql.sql.gz
DELETING OLD SNAPSHOT FILES...
Running callbacks:
^</pre></p>
Running callbacks:
^</pre></p>
NUMFOUND: 10
NUMFOUND: 0
NUMFOUND: 10
Running callbacks:
^</pre></p>
NUMFOUND: 11
ALL:
1597953333.tar.gz
1597953333.txt
1597952804.tar.gz
1597952804.txt
1597932933.tar.gz
1597932933.txt
1597875902.tar.gz
1597875902.txt
1597865329.tar.gz
1597865329.txt
1597864778.tar.gz
1597864778.txt
1597839204.tar.gz
1597839204.txt
1597824500.tar.gz
1597824500.txt
1597822045.tar.gz
1597822045.txt
1597789442.tar.gz
1597789442.txt
1597737134.tar.gz
1597737134.txt
errors
NUMFOUND: 0
NUMFOUND: 11
ALL:
Running callbacks:
^</pre></p>
This is the fix for the cleaner.php script syntax error.
Edit the /usr/local/nagiosxi/cron/cleaner.php file and on line 61, add this line
so it looks like this.
Then remove the following line from the file (it should be line 65)
Replace it will all of the following.
Save the settings and see if the errors are gone from the /usr/local/nagiosxi/var/cleaner.log file.
global $cfg;
function do_deploy_statuschecks()
global $cfg;
global $db_tables;
$sql = "SELECT * FROM " . $db_tables[DB_NAGIOSXI]["deploy_agents"] . " WHERE last_status_check + INTERVAL " . intval($deploy_avail_check) . " HOUR <= NOW()";
$dbtype = '';
if (array_key_exists("dbtype", $cfg['db_info'][DB_NAGIOSXI])) {
$dbtype = $cfg['db_info'][DB_NAGIOSXI]['dbtype'];
$interval = "INTERVAL ".intval($deploy_avail_check)." HOUR";
if ($dbtype == 'pgsql') {
$interval = "INTERVAL '".intval($deploy_avail_check)." hours'";
$sql = "SELECT * FROM " . $db_tables[DB_NAGIOSXI]["deploy_agents"] . " WHERE last_status_check + ".$interval." <= NOW()";
Changes made. Error messages are gone.
NUMFOUND: 10
NUMFOUND: 0
NUMFOUND: 10
Running callbacks:
the "cannot access" message is because there are no *.gz files but only :
nagios1:root:/usr/local/nagiosxi/var> ll -ltr /usr/local/nagiosxi/nom/checkpoints/nagioscore/errors/
total 40
-rw-r--r-- 1 nagios nagios 1257 Nov 22 2019 1574408560.txt
-rw-r--r-- 1 nagios nagios 1203 Feb 27 12:45 1582803918.txt
-rw-r--r-- 1 nagios nagios 1270 Apr 17 12:54 1587120866.txt
-rw-r--r-- 1 nagios nagios 1270 Apr 17 12:55 1587120950.txt
-rw-r--r-- 1 nagios nagios 1183 May 14 14:26 1589459214.txt
-rw-r--r-- 1 nagios nagios 1183 May 14 14:28 1589459309.txt
-rw-r--r-- 1 nagios nagios 1806 May 26 12:25 1590488711.txt
-rw-r--r-- 1 nagios nagios 1646 Jun 26 13:30 1593171042.txt
-rw-r--r-- 1 nagios nagios 1284 Jun 29 17:48 1593445682.txt
-rw-r--r-- 1 nagios nagios 1284 Jun 29 17:48 1593445721.txt
NUMFOUND: 10
NUMFOUND: 0
NUMFOUND: 10
Running callbacks:
total 40
Glad it fixed the SQL error on the system. The next release of XI will have the change.
The ls message can be ignored.
OK. Thanks for you great help.
Locking threadCBoekhuis wrote:OK. Thanks for you great help.
