apply config slow
fsodah
Re: apply config slow
Post by fsodah »
should i change the apache one.
[root@nagios ~]# ls -al /usr/share/snmp/mibs
total 5912
drwxrwsr-x. 2 root   nagios    8192 Aug 25 22:20 .
drwxr-xr-x. 5 root   root      4096 Jun 27 10:29 ..
-rw-rw-r--  1 root   nagios   68104 Jun 23 18:39 DISMAN-EVENT-MIB.txt
-rw-rw-r--  1 root   nagios   24613 Jun 23 18:39 DISMAN-SCHEDULE-MIB.txt
-rw-rw-r--  1 root   nagios   64311 Jun 23 18:39 DISMAN-SCRIPT-MIB.txt
-rw-rw-r--  1 root   nagios 1444080 Nov 14  2019 Extreme_MIB_II.txt
-rw-rw-r--  1 apache nagios 1218910 Aug 24 22:04 Extreme-MIB.txt
-rw-rw-r--  1 apache nagios   25322 Aug 24 22:09 EXTREME-SOFTWARE-MONITOR-MIB.mib
-rw-r--r--  1 root   nagios   81343 Aug 25 21:58 EXTREME-SYSTEM-MIB
-rw-rw-r--  1 root   nagios   14714 Oct  7  2019 FORTINET-CORE-MIB.mib
-rw-rw-r--  1 root   nagios  341374 Oct  7  2019 FORTINET-FORTIGATE-MIB.mib
-rw-rw-r--  1 root   nagios   41916 Jan 22  2020 FORTINET-FORTIMANAGER-FORTIANALYZER-MIB-build0255.mib
-rw-rw-r--  1 root   nagios    4660 Jun 23 18:39 HCNUM-TC.txt
-rw-rw-r--  1 root   nagios   52544 Jun 23 18:39 HOST-RESOURCES-MIB.txt
-rw-rw-r--  1 root   nagios   10583 Jun 23 18:39 HOST-RESOURCES-TYPES.txt
-rw-rw-r--  1 root   nagios    4819 Jun 23 18:39 IANA-ADDRESS-FAMILY-NUMBERS-MIB.txt
-rw-rw-r--  1 root   nagios   32465 Jun 23 18:39 IANAifType-MIB.txt
-rw-rw-r--  1 root   nagios    4299 Jun 23 18:39 IANA-LANGUAGE-MIB.txt
-rw-rw-r--  1 root   nagios    3659 Jun 23 18:39 IANA-RTPROTO-MIB.txt
-rw-rw-r--  1 root   nagios  135156 Jan  4  2020 IEEE8021-CFM-MIB.my
-rw-rw-r--  1 root   nagios    5066 Jun 23 18:39 IF-INVERTED-STACK-MIB.txt
-rw-rw-r--  1 root   nagios   71691 Jun 23 18:39 IF-MIB.txt
-rw-rw-r--  1 root   nagios   16782 Jun 23 18:39 INET-ADDRESS-MIB.txt
-rw-rw-r--  1 root   nagios   46286 Jun 23 18:39 IP-FORWARD-MIB.txt
-rw-rw-r--  1 root   nagios  185667 Jun 23 18:39 IP-MIB.txt
-rw-rw-r--  1 root   nagios    2028 Jun 23 18:39 IPV6-FLOW-LABEL-MIB.txt
-rw-rw-r--  1 root   nagios   15936 Jun 23 18:39 IPV6-ICMP-MIB.txt
-rw-rw-r--  1 root   nagios   48703 Jun 23 18:39 IPV6-MIB.txt
-rw-rw-r--  1 root   nagios    7257 Jun 23 18:39 IPV6-TCP-MIB.txt
-rw-rw-r--  1 root   nagios    2367 Jun 23 18:39 IPV6-TC.txt
-rw-rw-r--  1 root   nagios    4400 Jun 23 18:39 IPV6-UDP-MIB.txt
-rw-r--r--  1 root   nagios   18287 Aug 24 20:44 LIEBERT_GP_AGENT.MIB
-rw-rw-r--  1 root   nagios  179812 Aug 24 20:44 LIEBERT_GP_COND.MIB
-rw-r--r--  1 root   nagios    3244 Aug 24 20:44 LIEBERT_GP_CONTROLLER.MIB
-rw-r--r--  1 root   nagios  110321 Aug 24 20:44 LIEBERT_GP_ENV.MIB
-rw-r--r--  1 root   nagios  218559 Aug 24 20:44 LIEBERT_GP_FLEXIBLE_COND.MIB
-rw-r--r--  1 root   nagios   14519 Aug 24 20:44 LIEBERT_GP_FLEXIBLE.MIB
-rw-r--r--  1 root   nagios   13848 Aug 24 20:44 LIEBERT_GP_NOTIFY.MIB
-rw-r--r--  1 root   nagios  145427 Aug 24 20:44 LIEBERT_GP_PDU.MIB
-rw-r--r--  1 root   nagios  111407 Aug 24 20:44 LIEBERT_GP_POWER.MIB
-rw-rw-r--  1 root   nagios   60442 Aug 24 20:44 LIEBERT_GP_REG.MIB
-rw-r--r--  1 root   nagios   14159 Aug 24 20:44 LIEBERT_GP_SRC.MIB
-rw-r--r--  1 root   nagios   18380 Aug 24 20:44 LIEBERT_GP_SYSTEM.MIB
-rw-rw-r--  1 root   nagios    5931 Jun 23 18:39 LM-SENSORS-MIB.txt
-rw-rw-r--  1 root   nagios    6875 Nov 14  2019 mib-veritas
-rw-rw-r--  1 root   nagios   42375 Jun 23 18:39 MTA-MIB.txt
-rw-rw-r--. 1 root   nagios   19760 Jun 27 10:29 NAGIOS-NOTIFY-MIB.txt
-rw-rw-r--. 1 root   nagios    2093 Jun 27 10:29 NAGIOS-ROOT-MIB.txt
-rw-rw-r--  1 root   nagios   15901 Jun 23 18:39 NET-SNMP-AGENT-MIB.txt
-rw-rw-r--  1 root   nagios    9160 Jun 23 18:39 NET-SNMP-EXAMPLES-MIB.txt
-rw-rw-r--  1 root   nagios    9326 Jun 23 18:39 NET-SNMP-EXTEND-MIB.txt
-rw-rw-r--  1 root   nagios    2036 Jun 23 18:39 NET-SNMP-MIB.txt
-rw-rw-r--  1 root   nagios    3350 Jun 23 18:39 NET-SNMP-PASS-MIB.txt
-rw-rw-r--  1 root   nagios    4814 Jun 23 18:39 NET-SNMP-TC.txt
-rw-rw-r--  1 root   nagios    5039 Jun 23 18:39 NET-SNMP-VACM-MIB.txt
-rw-rw-r--  1 root   nagios   21006 Jun 23 18:39 NETWORK-SERVICES-MIB.txt
-rw-rw-r--  1 root   nagios   24694 Jun 23 18:39 NOTIFICATION-LOG-MIB.txt
-rw-rw-r--  1 root   nagios    3067 Jun 23 18:39 RFC1155-SMI.txt
-rw-rw-r--  1 root   nagios  104699 Jan  4  2020 RFC1213-MIB.mib
-rw-rw-r--  1 root   nagios    1174 Jun 23 18:39 RFC-1215.txt
-rw-r--r--  1 root   nagios   70133 Aug 24 20:44 RFC1628_UPS_MIB.MIB
-rw-rw-r--  1 root   nagios  147822 Jun 23 18:39 RMON-MIB.txt
-rw-rw-r--  1 root   nagios   45323 Jun 23 18:39 SCTP-MIB.txt
-rw-rw-r--  1 root   nagios    4649 Jun 23 18:39 SMUX-MIB.txt
-rw-rw-r--  1 root   nagios   15490 Jun 23 18:39 SNMP-COMMUNITY-MIB.txt
-rw-rw-r--  1 root   nagios   22342 Jun 23 18:39 SNMP-FRAMEWORK-MIB.txt
-rw-rw-r--  1 root   nagios    5496 Jun 23 18:39 SNMP-MPD-MIB.txt
-rw-rw-r--  1 root   nagios   20014 Jun 23 18:39 SNMP-NOTIFICATION-MIB.txt
-rw-rw-r--  1 root   nagios    9106 Jun 23 18:39 SNMP-PROXY-MIB.txt
-rw-rw-r--  1 root   nagios   22769 Jun 23 18:39 SNMP-TARGET-MIB.txt
-rw-rw-r--  1 root   nagios    2205 Jun 23 18:39 SNMP-USM-AES-MIB.txt
-rw-rw-r--  1 root   nagios   21101 Jun 23 18:39 SNMP-USM-DH-OBJECTS-MIB.txt
-rw-rw-r--  1 root   nagios    8263 Jun 23 18:39 SNMPv2-CONF.txt
-rw-rw-r--  1 root   nagios   29305 Jun 23 18:39 SNMPv2-MIB.txt
-rw-rw-r--  1 root   nagios    8924 Jun 23 18:39 SNMPv2-SMI.txt
-rw-rw-r--  1 root   nagios   38034 Jun 23 18:39 SNMPv2-TC.txt
-rw-rw-r--  1 root   nagios    5775 Jun 23 18:39 SNMPv2-TM.txt
-rw-rw-r--  1 root   nagios   34162 Jun 23 18:39 SNMP-VIEW-BASED-ACM-MIB.txt
-rw-rw-r--  1 root   nagios   28564 Jun 23 18:39 TCP-MIB.txt
-rw-rw-r--  1 root   nagios   16418 Jun 23 18:39 TRANSPORT-ADDRESS-MIB.txt
-rw-rw-r--  1 root   nagios   27826 Jun 23 18:39 TUNNEL-MIB.txt
-rw-rw-r--  1 root   nagios    2163 Jun 23 18:39 UCD-DEMO-MIB.txt
-rw-rw-r--  1 root   nagios    4613 Jun 23 18:39 UCD-DISKIO-MIB.txt
-rw-rw-r--  1 root   nagios    3087 Jun 23 18:39 UCD-DLMOD-MIB.txt
-rw-rw-r--  1 root   nagios    8118 Jun 23 18:39 UCD-IPFWACC-MIB.txt
-rw-rw-r--  1 root   nagios   52146 Jun 23 18:39 UCD-SNMP-MIB.txt
-rw-rw-r--  1 root   nagios   20882 Jun 23 18:39 UDP-MIB.txt
-rw-rw-r--  1 root   nagios    6905 Nov 11  2019 Veritas-MIB.mib
[root@nagios ~]#
This point i didnt get it .... what should I do to remove the fatal error as you mentioned in your previous talk
PHP Fatal error:  Call to a member function xpath() on a non-object in /usr/local/nagiosxi/html/includes/components/graphexplorer/visFunctions.inc.php on line 554, referer: http://x.x.x.222/nagiosxi/dashboards/dashboard.php?id=u0J9shnQ
fsodah
Post by fsodah »
please note your suggestion regarding permissions and removing the unused dashlet has been implemented, any other recommendations?
benjaminsmith
Post by benjaminsmith »
Did you notice any performance improvement in the interface after removing the dashelt? The permissions on the mib files look ok, but those mibs (with errors) are not there.
I would recommend uploading any missing mib's to clear those errors. You can do this in the web interface by going to Admin > System Extensions > Manage MIBs
See:
Nagios XI - Uploading and Managing MIBS
http://net-snmp.sourceforge.net/docs/mi ... ke-MIB.txt
Have you noticed any improvement in the apply configuration time? Can you run the following tail command, select apply configuration and then post the full output to the thread?
tail -f /usr/local/nagiosxi/var/cmdsubsys.log
fsodah
Post by fsodah »
Yes performance better ... regarding the tail i ll post it tomorrow asap i ll get to you
fsodah
Post by fsodah »
I added missing files (2x), should i send you the profile again after adjusting above ... so to check it out
[root@nagios mibs]# ls -al
total 6080
drwxrwsr-x. 2 root nagios    8192 Sep  2 08:04 .
-rw-r--r--  1 root nagios   84492 Aug 25  2019 EtherLike-MIB.txt
-rw-rw-r--  1 root nagios 1218910 Aug 24 22:04 Extreme-MIB.txt
-rw-rw-r--  1 root nagios   25322 Aug 24 22:09 EXTREME-SOFTWARE-MONITOR-MIB.mib
-rw-rw-r--  1 root nagios   81343 Aug 25 21:58 EXTREME-SYSTEM-MIB
-rw-rw-r--  1 root nagios   18287 Aug 24 20:44 LIEBERT_GP_AGENT.MIB
-rw-rw-r--  1 root nagios    3244 Aug 24 20:44 LIEBERT_GP_CONTROLLER.MIB
-rw-rw-r--  1 root nagios  110321 Aug 24 20:44 LIEBERT_GP_ENV.MIB
-rw-rw-r--  1 root nagios  218559 Aug 24 20:44 LIEBERT_GP_FLEXIBLE_COND.MIB
-rw-rw-r--  1 root nagios   14519 Aug 24 20:44 LIEBERT_GP_FLEXIBLE.MIB
-rw-rw-r--  1 root nagios   13848 Aug 24 20:44 LIEBERT_GP_NOTIFY.MIB
-rw-rw-r--  1 root nagios  145427 Aug 24 20:44 LIEBERT_GP_PDU.MIB
-rw-rw-r--  1 root nagios  111407 Aug 24 20:44 LIEBERT_GP_POWER.MIB
-rw-rw-r--  1 root nagios   14159 Aug 24 20:44 LIEBERT_GP_SRC.MIB
-rw-rw-r--  1 root nagios   18380 Aug 24 20:44 LIEBERT_GP_SYSTEM.MIB
-rw-rw-r--  1 root nagios   70133 Aug 24 20:44 RFC1628_UPS_MIB.MIB
-rw-r--r--  1 root nagios   39201 Aug 25  2019 SNMP-USER-BASED-SM-MIB.txt
[root@nagios mibs]# tail -f /usr/local/nagiosxi/var/cmdsubsys.log
Cannot find module (SNMP-USER-BASED-SM-MIB): At line 9 in (none)
PROCESSED 0 COMMANDS
........................................................MIB search path: /home/nagios/.snmp/mibs:/usr/share/snmp/mibs
............................^C
[root@nagios mibs]# ls -al SNMP-*
[root@nagios mibs]# ls -al Ether*
[root@nagios mibs]#
benjaminsmith
Glad to hear the performance has improved. Sure, if you want to send your profile again I can take a look.
Benjmain
fsodah
Post by fsodah »
I will do it tomorrow morning as soon as i get to my office.
fsodah
Post by fsodah »
set the updated profile
benjaminsmith
The logs are in the profile look good, nothing really standing out. For some reason, the database log was not included, it wouldn't hurt to take a quick look at this log and check for any recent errors.
tail -n 50 /var/log/mariadb/mariadb.log
Benjamin
fsodah
Post by fsodah »
I will check it tomorrow morning and get back to you asap.
