We have not.
When I look at the number of occurrences of this error in are /var/log/messages since 3AM EST today, I get 588 lines.
I saw something like this available, but I am not sure if that would help me in my instance. https://support.nagios.com/kb/article.php?id=149
RRDCached issues
Re: RRDCached issues
I had completely forgot about that script.
Yes, that should fix them
I just tried that, but I am getting the following error when running "cpan -i RRD::Simple"
I have rrdcached installed, but apparently not rrd. it exists in /opt/rrdtool-1.4.4/lib/perl/5.16.3/x86_64-linux-thread-multi/RRDs.pm
| ERROR! -- Could not load RRDs.pm |
| RRD::Simple requires RRDs.pm (a part of RRDtool) in order to function. You |
| can download a copy of RRDtool from http://www.rrdtool.org. See the INSTALL |
| document for more details. |
Checking prerequisites...
requires:
! RRDs is not installed
recommends:
* Test::Deep is not installed
* Test::Pod is not installed
* Test::Pod::Coverage is not installed
ERRORS/WARNINGS FOUND IN PREREQUISITES. You may wish to install the versions
of the modules indicated above before proceeding with this installation
This is usually installed with
Which usually is already on the system
yum install rrdtool-perlRe: RRDCached issues
Thank you. With other work going on, I won't be able to test this until Thursday morning.
Sounds goodhbouma wrote:Thank you. With other work going on, I won't be able to test this until Thursday morning.
This cleared up almost all the issues. The It just appears that one or 2 still remain, and I will clean those up manually by deleting the rrd file.
Thank you for the help.
Great!hbouma wrote:This cleared up almost all the issues. The It just appears that one or 2 still remain, and I will clean those up manually by deleting the rrd file.
Closing thread
