Report or dashboard with several query graphs
Re: Report or dashboard with several query graphs
gormank wrote:query * to select all.
You have to add multiple queries like I showed in the first picture above, then add the one you want displayed to each of your histograms
If you just have one query of * there is no way to graph different queries in each histogram because there is only 1 query.
gormank
Post by gormank »
Ok,
The part I was missing was going to the first graph and selecting only the first query. I also didn't get at first that once queries were defined, the menu changed.
You're right of course and my theory about the problem being me above was correct.
You can close this one.
Thanks for your patience.
