So after importing the nagiosql database, I can repeat the error you're getting on my test system.
The issue that I'm seeing is those services in UPS - Temp do not exist in the database.
If you deactivate this service group you can Apply Configuration without error. If these services were removed for some reason, when did you notice the issue, and are you running scheduled backups (how often)?
Regards,
Benjamin
Nagios apply configuration issue
benjaminsmith
Re: Nagios apply configuration issue
Hi benjaminsmith,
We have deactivated this service group "UPS-Temp" and done Apply Configuration. We did not see any configuration errors after that.
We are monitoring the service for a few days and will let you know the updates.
benjaminsmith
Hi @mejokj ,
Benjamin
Thanks for the update. We'll keep this thread open.We are monitoring the service for a few days and will let you know the updates.
Benjamin
Hi Benjaminsmith,
Please close the thread, the issue is fixed.
Thank you for your support
Great!mejokj wrote:Hi Benjaminsmith,
Locking thread
