New hosts remain pending after upgrade to 5.7.3
DennisPR
Re: New hosts remain pending after upgrade to 5.7.3
Post by DennisPR »
I have reboot the server today (to add extra CPU's to the VM) and it seems that the ndo2db is running by default
[root@localhost ~]# service ndo2db status
ndo2db (pid 3764) is running...
[root@localhost ~]# service ndo2db stop
Stopping ndo2db: done.
[root@localhost ~]# ps aux | grep ndo2db
root     19508  0.0  0.0 103320   860 pts/1    R+   01:02   0:00 grep ndo2db
cdienger
Post by cdienger »
Run:
systemctl disable ndo2db
and then reboot to verify that it doesn't start again.
DennisPR
Post by DennisPR »
Shouldn't ndo2db be running all the time ?
If I stop ndo2db Nagios doesn't execute services anymore
In what version of Nagios XI will this be fixed pls ?
At this time I am running XI 5.7.4 with ndoutils 5.6.14 and can't upgrade to 5.7.5 because I don't see any fixes about ndoutils in the 5.7.5 changelog ?
cdienger
Post by cdienger »
The last profile I have shows this module is loaded:
broker_module=/usr/local/nagios/bin/ndo.so /usr/local/nagios/etc/ndo.cfg
so the ndo2db process should no longer be needed with that. If you switch to using ndoutils instead, then the above line should be commented out and this line used instead:
broker_module=/usr/local/nagios/bin/ndomod.o config_file=/usr/local/nagios/etc/ndomod.cfg
and in that case the ndo2db process should be run.
We're aiming for 5.8 to include fixes to the new ndo module.
DennisPR
Post by DennisPR »
I found the following lines in /usr/local/nagios/etc/nagios.cfg
# NDOUtils module^M
# Commented out by NDO 'make install-broker-line' on Mon Oct 19 11:26:29 CEST 2020
#broker_module=/usr/local/nagios/bin/ndomod.o config_file=/usr/local/nagios/etc/ndomod.cfg^M
# Added by NDO 'make install-broker-line' on Mon Oct 19 11:26:29 CEST 2020
#broker_module=/usr/local/nagios/bin/ndo.so /usr/local/nagios/etc/ndo.cfg
19 October is the date that we excetuted the last Nagios XI update.
How do I determine what's best... Using the ndo module or service ?
Looks like the update script installed the module so I guess I need to turn off by running
That's all I need to do ?
cdienger
Post by cdienger »
The new module has had issues with not updating statuses so I would recommend the old method for now. I think there may have been some confusion with what steps were done when. To be clear - you're still seeing issues with the statuses not updating and nagios.cfg currently contains:
If so, then that would mean the ndo2db is being used and what we'd suggest. In which case the ndo2db service should running.
Please provide a fresh profile so we can take a look a the current setup/logs.
junkertf
Post by junkertf »
Same issue here after upgrade from 5.6.8 to 5.7.5
Don't understand why let ppl do upgrade in these situation on the systems.
Eighter or, i can add it to the solution with my profiles.
Our TEST not produce the symptoms detailed in these Thread, and our PROD system produce it.
We decided to revert back our version to the originally working 5.6.8 version.
I post our profiles to cdinenger.
Thank you, best regards,
Ferenc
cdienger
Post by cdienger »
XI 5.8 was released today and addresses the pending issue seen in 5.7.x releases.
