$ grep -R 'ixed\|sourceguardian' /etc/php*
/etc/php.d/sourceguardian.ini:extension=ixed.7.2ts.lin
/etc/php.ini:extension=/usr/lib64/php-zts/modules/ixed.7.2ts.lin
/etc/php.ini:extension=/usr/lib64/php/modules/ixed.7.2.linCode: Select all
$ ls -l /etc/php.d
total 168
-rw-r--r-- 1 root root 4847 Sep 30 13:30 10-opcache.ini
-rw-r--r-- 1 root root 44 Sep 30 13:36 20-bz2.ini
-rw-r--r-- 1 root root 54 Sep 30 13:36 20-calendar.ini
-rw-r--r-- 1 root root 48 Sep 30 13:36 20-ctype.ini
-rw-r--r-- 1 root root 46 Sep 30 13:36 20-curl.ini
-rw-r--r-- 1 root root 44 Sep 30 13:36 20-dom.ini
-rw-r--r-- 1 root root 46 Sep 30 13:36 20-exif.ini
-rw-r--r-- 1 root root 54 Sep 30 13:36 20-fileinfo.ini
-rw-r--r-- 1 root root 44 Sep 30 13:36 20-ftp.ini
-rw-r--r-- 1 root root 42 Sep 30 13:36 20-gd.ini
-rw-r--r-- 1 root root 52 Sep 30 13:36 20-gettext.ini
-rw-r--r-- 1 root root 48 Sep 30 13:36 20-iconv.ini
-rw-r--r-- 1 root root 46 Sep 30 13:36 20-json.ini
-rw-r--r-- 1 root root 46 Sep 30 13:36 20-ldap.ini
-rw-r--r-- 1 root root 54 Sep 30 13:36 20-mbstring.ini
-rw-r--r-- 1 root root 52 Sep 30 13:36 20-mysqlnd.ini
-rw-r--r-- 1 root root 44 Sep 30 13:36 20-pdo.ini
-rw-r--r-- 1 root root 48 Sep 30 13:36 20-pgsql.ini
-rw-r--r-- 1 root root 46 Sep 30 13:36 20-phar.ini
-rw-r--r-- 1 root root 48 Sep 30 13:36 20-posix.ini
-rw-r--r-- 1 root root 48 Sep 30 13:36 20-shmop.ini
-rw-r--r-- 1 root root 56 Sep 30 13:36 20-simplexml.ini
-rw-r--r-- 1 root root 46 Sep 30 13:36 20-snmp.ini
-rw-r--r-- 1 root root 52 Sep 30 13:36 20-sockets.ini
-rw-r--r-- 1 root root 52 Sep 30 13:36 20-sqlite3.ini
-rw-r--r-- 1 root root 52 Sep 30 13:36 20-sysvmsg.ini
-rw-r--r-- 1 root root 52 Sep 30 13:36 20-sysvsem.ini
-rw-r--r-- 1 root root 52 Sep 30 13:36 20-sysvshm.ini
-rw-r--r-- 1 root root 56 Sep 30 13:36 20-tokenizer.ini
-rw-r--r-- 1 root root 44 Sep 30 13:36 20-xml.ini
-rw-r--r-- 1 root root 56 Sep 30 13:36 20-xmlwriter.ini
-rw-r--r-- 1 root root 44 Sep 30 13:36 20-xsl.ini
-rw-r--r-- 1 root root 50 Sep 30 13:36 30-mysqli.ini
-rw-r--r-- 1 root root 56 Sep 30 13:36 30-pdo_mysql.ini
-rw-r--r-- 1 root root 56 Sep 30 13:36 30-pdo_pgsql.ini
-rw-r--r-- 1 root root 58 Sep 30 13:36 30-pdo_sqlite.ini
-rw-r--r-- 1 root root 46 Sep 30 13:36 30-wddx.ini
-rw-r--r-- 1 root root 56 Sep 30 13:36 30-xmlreader.ini
-rw-r--r-- 1 root root 49 Jul 26 2018 40-ssh2.ini
-rw-r--r-- 1 root root 645 Sep 30 13:36 opcache-default.blacklist
-rw-r--r-- 1 root root 25 Nov 19 16:05 sourceguardian.ini
$ ls -l /usr/local/lib/php/extensions
ls: cannot access /usr/local/lib/php/extensions: No such file or directory
And, The php error message as below:
PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib64/php-zts/modules/ixed.7.2ts.lin' (tried: /usr/lib64/php-zts/modules/ixed.7.2ts.lin (/usr/lib64/php-zts/modules/ixed.7.2ts.lin: undefined symbol: core_globals_id), /usr/lib64/php/modules//usr/lib64/php-zts/modules/ixed.7.2ts.lin.so (/usr/lib64/php/modules//usr/lib64/php-zts/modules/ixed.7.2ts.lin.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library 'ixed.7.2ts.lin' (tried: /usr/lib64/php/modules/ixed.7.2ts.lin (/usr/lib64/php/modules/ixed.7.2ts.lin: undefined symbol: core_globals_id), /usr/lib64/php/modules/ixed.7.2ts.lin.so (/usr/lib64/php/modules/ixed.7.2ts.lin.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
or in
And the php.ini is attached.
Meanwhile, I will keep eyes on it to make sure no fatal error.
Because it runs well so far; not sure what would happen.
Thank you for help!
