We have PM the nagiosql file. Please have a look.
Difference in number of hosts in hostgroups
benjaminsmith
Re: Difference in number of hosts in hostgroups
Did you PM it to my account? If so, can re-send this once more or attach it to the thread. I'm not seeing anything new coming since your last reply on 11/21.
Regards,
Benjamin
Regards,
Benjamin
I have resent the msg.
The discrepancy likely comes from the fact that you can apply hosts to hostgroups OR hostgroups to hosts, so when you edit the hostgroup in CCM > Hostgroups it will ONLY show the count for the number of HOSTS applied directly on the hostgroup. It does not include the host count from hosts that have the hostgroup defined on the host directly under CCM > Hosts (you can see them grayed out in the left hand column though it will show you that they are linked somewhere else).
So you have 154 selected directly on the hostgroup in CCM > Host Groups.
You have 7 hosts that have the hostgroup directly applied in CCM > Hosts.
I've sent you a PM with those hosts, please check your PMs.
Thanks for the support it is working now
Great!mejokj wrote:Thanks for the support it is working now
Locking thread
