solaris-nrpe-agent
shethm
Re: solaris-nrpe-agent
Post by shethm »
Hi there ...
when i run these command on the solaris agent .. i get this error.
# ./check_nrpe -H 143.55.165.123 -t 30 -c check_load -a '-w 15,10,5 -c 30,20,10'
CHECK_NRPE: Error - Could not complete SSL handshake.
# ./check_nrpe -H 143.55.165.123 -t 30 -c check_users -a '-w 5 -c 10'
you should run this from the nagios machine.
If you get the same error you will want to check /etc/nagios/nrpe.cfg on the Solaris machine and make sure your Nagios server's IP address is listed next to allowed_hosts
You will need to restart nrpe on the Solaris machine for the changes to take affect
svcadm restart nrpe
shethm
Post by shethm »
shethm
Post by shethm »
Hi , nrpe.cfg file has allowed_hosts configuration... it is giving me " Could not complete SSL handshake" How do i troubleshoot SSL on the unix agent side ?
did you restart nrpe on the Solaris machine after making the change to the nrpe.cfg on the Solaris machine?
svcadm restart nrpe
shethm
Post by shethm »
nrpe config was allready in place ... didn't do anything ... i can restart teh service.
please PM me a copy of your nrpe.cfg from the solaris machine along with the IP address of your Nagios XI server
shethm
Post by shethm »
name = nagios-c108-01.fitsuny.edu. here is the nslookup for nagios server.
please view attach for nrpe.cfg config ...
It seems that you don't have the proper IP defined in the nrpe.cfg file. IN the line:
allowed_hosts=
you need to put your nagios server's IP (not the client's IP!)
Is 143.55.161.51 your nagios server's IP?
After this, you should run:
svcadm restart nrpe
Hope this helps.
shethm
Post by shethm »
YES, it is defined in the nrpe.cfg file ... R u looking at the same config as i am ? which line do you not see it ?
# ALLOWED HOST ADDRESSES
# This is an optional comma-delimited list of IP address or hostnames
# that are allowed to talk to the NRPE daemon. Network addresses with a bit mask
# (i.e. 192.168.1.0/24) are also supported. Hostname wildcards are not currently
# supported.
# Note: The daemon only does rudimentary checking of the client's IP
# address. I would highly recommend adding entries in your /etc/hosts.allow
# file to allow only the specified host to connect to the port
# you are running this daemon on.
# NOTE: This option is ignored if NRPE is running under either inetd or xinetd
allowed_hosts=143.55.161.51
