Snapshot Repo Reconfig
duchenz
Re: Snapshot Repo Reconfig
Post by duchenz »
Hmmm...This is wried...It shows nothing is going on
[root@nagiosls ~]# curl -XGET 'http://localhost:9200/_snapshot/Snapsho ... all?pretty'
"snapshots" : [ ]
cdienger
Post by cdienger »
That does seem weird. Try deleting the job it is complaining about:
curl -XDELETE 'http://localhost:9200/_snapshot/Snapshot%20Repository/curator-20201005133221'
duchenz
Post by duchenz »
[root@nagiosls ~]# curl -XDELETE 'http://localhost:9200/_snapshot/Snapsho ... 1005133221'
{"error":"RemoteTransportException[[bad2dc30-4cc1-4952-893c-00ea50d25ba7][inet[/140.141.7.101:9300]][cluster:admin/snapshot/delete]]; nested: SnapshotMissingException[[Snapshot Repository:curator-20201005133221] is missing]; nested: FileNotFoundException[/mnt/snapshotrepo/snapshot-curator-20201005133221 (No such file or directory)]; ","status
cdienger
Post by cdienger »
Please provide a profile from the system. It can be gathered under Admin > System > System Status > Download System Profile or from the command line with:
/usr/local/nagioslogserver/scripts/profile.sh
This will create /tmp/system-profile.tar.gz.
Note that this file can be very large and may not be able to be uploaded through the system. You can split the file into smaller files with the split command on the NLS(or other Linux machine) command line:
split -b 5000000 /tmp/system-profile.tar.gz system-profile- -d
The above command will split the system-profile.tar.gz into 5MB segments and save them to files with the naming convention system-profile​-nn.
I'd also like to get a copy of the current settings index. This can be gathered by running:
curl -XPOST http://localhost:9200/nagioslogserver/_export?path=/tmp/nagioslogserver.tar.gz
The file it creates and that we'd like to see is /tmp/nagioslogserver.tar.gz.
Please send the files to me in a private message.
duchenz
Post by duchenz »
After sending the last result to you, apparently, the snapshot starts to working again. I saw the job just successfully finished and will keep monitoring it.
benjaminsmith
Post by benjaminsmith »
Good to hear. We can leave this post open for now if you need anything.
