Hello, I will try this and report back. My concern is that I now have multiple traps and hosts that are showing as 'unknown'. If this fix corrects my issue, will I need to then go in and edit each trap? These have previously worked fine before.
Thanks!
'UNKNOWN' Host within snmptt.log
Re: 'UNKNOWN' Host within snmptt.log
Please try this:
Stop snmptt:
Then send in a trap to replicate the (null) and once you've sent it, send me the trap file from this directory:
/var/spool/snmptt.
Then once you're done, start snmptt back up again:
Then do this as well:
Edit your /etc/snmp/snmptt.ini and set:
Then restart snmptt:
Then submit one of the traps that say (null) and after that send me this file:
Then disable debugging (set it to 0) and restart the service.
If that doesn't provide any details, please create a ticket for this and include a link back to this forum thread so we can get a remote session setup:
https://support.nagios.com/tickets/
Thank you!
Stop snmptt:
service snmptt stop/var/spool/snmptt.
service snmptt startEdit your /etc/snmp/snmptt.ini and set:
DEBUGGING = 2Code: Select all
service snmptt restartCode: Select all
/var/log/snmptt/snmptt.debugIf that doesn't provide any details, please create a ticket for this and include a link back to this forum thread so we can get a remote session setup:
Thank you!
In addition to my previous post, please try editing this file:
Change line 3291 from this:
To this:
See if that resolves it.
Taken from here:
https://sourceforge.net/p/snmptt/bugs/46/
/usr/sbin/snmpttCode: Select all
if ($tempvar[0] =~ /<UNKNOWN>/) {Code: Select all
if ($tempvar[0] =~ /UNKNOWN/) {Taken from here:
I have sent PM's with attachments you had requested. I then edited line 3291 in /usr/sbin/snmptt to the changes you had posted. I then restarted snmptt and sent a test trap. The test trap continues to show UNKNOWN as host in snmptt.log.
EDIT: I think this is likely failing because DNS is not working and the $r in the EXEC line requires it.
Does this command work with one of the hosts where it's showing as UNKNOWN?
- Change X.X.X.X. to the IP of the sending device
Try changing the trap EXEC line where it shows $r and change it to $aA to see if that resolves it for one of them:
To:
Restart SNMPTT and then test again with the trap you modified:
If that doesn't resolve it, please create a ticket for this and include a link back to this forum thread so we can get a remote session setup:
nslookup X.X.X.XFrom:
EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" "Critical alarms are sent for service affecting $*"Code: Select all
EXEC /usr/local/bin/snmptraphandling.py "$aA" "SNMP Traps" "$s" "$@" "$-*" "Critical alarms are sent for service affecting $*"Code: Select all
systemctl restart snmptthttps://support.nagios.com/tickets/
Hello
I apologize for the long delay in getting this tested.
When performing a nslookup on that host I receive a:
I edited the particular trap I am using to test in /etc/snmp/snmptt.conf. I then restarted snmptt and went back to my device to send a test trap. The trap is still appearing in /var/log/snmptt/snmptt.log as 'UNKNOWN' but I am now receiving email notifications that a test trap was sent from that host.
Thanks!
When performing a nslookup against google it is successful.** server can't find X.X.X.X.in-addr.arpa: REFUSED
Thanks!
Please create a ticket for this and include a link back to this forum thread so we can get a remote session setup:
Thank you!
Thank you!
