Windows Service Monitoring Error
vtrac
Re: Windows Service Monitoring Error
Post by vtrac »
Hi Diego,
Since you do not use "password", you can remove the "-s 'XXXXXX'" option off of the command.
Could you please test the below command on your XI server?
cd /usr/local/nagios/libexec
./check_nt -H PARCCVWPIEDA01 -p 12489 -v SERVICESTATE -d SHOWALL -l "PI SQL Data Access Server (RTQP Engine)"
or
./check_nt -H PARCCVWPIEDA01 -p 12489 -v SERVICESTATE -d SHOWALL -l "PISqlDas.RTQP"
If it is working, you could try replace the '-l "SSERVICEDESC$"' (picture below) to either:
-l "PISqlDas.RTQP"
or
Regards,
Vinh
dsilvero
Post by dsilvero »
Now it works !!!, than you very much for all and for the patience !! :)
Diego
dsilvero wrote:Now it works !!!, than you very much for all and for the patience !! :)
Diego
Great!
Locking thread
