Ok nevermind. It was the password. A newly generate password worked. I'm not sure which char it was that did it, but here's some of the character breakdowns:
-Started with a '<'
-Contained '<', '_', '+', '~' among other more common ones, but these are the oddballs that might have caught it.
Can you close the ticket too bud? Thanks for helping get this one.
CCM responds with 500 error code on any CCM page
Re: CCM responds with 500 error code on any CCM page
Thanks for reporting back that the issue is fixed.
For a quick test, I created a password with all of the characters that you used.
And it seemed to work.
I also closed the ticket.
<_+~passwordI also closed the ticket.
