Installation Issue RHEL5 64-bit
jasweitzer
Re: Installation Issue RHEL5 64-bit
Post by jasweitzer »
I tried the touch command you recommended and it did get me past the useradd issue I was having. Unfortunately it did not get me much further as now I fail on the 3-dbservers step in the install as again it is trying to add a user (I think).
Starting MySQL...
chown: `mysql:mysql': invalid user
Timeout error occurred trying to start MySQL Daemon.
Post by slansing »
First make sure another mysql daemon is not running with:
-ef | grep -i mysql
Also could you do a ls of the directory:
/var/lib/mysql/
And write back with what you see. Thank you.
jasweitzer
Still having issues with installation, we have ldap and it appears to be interferring with the install. I continue to get kick out during the 2-usersgroups portion of the installation.
Prerequisites installed OK
RESULT=0
Running './2-usersgroups'...
Adding users and groups...
groupadd: group nagios exists
RESULT=9
useradd: user nagios exists
Group does exist in ldap, I tried commenting out this portion of the script and it still fails further down the line.
if you edit ./2-usersgroups and remove the -e from the top line it will error, but continue on and complete
Also, make sure you don't have the touch installed.XXX line commented out.
jasweitzer
This is what I got when I removed the -e from the first line:
groupadd: group nagcmd exists
ERROR: Group 'nagios' was not created - exiting.
Since this is ldap controlled my bigger issue is with mysql.
PostgresQL already initialized - skipping.
MySQL installed OK - continuing...
Starting MySQL...
can you post your install.log
thanks
jasweitzer
DATE: Tue Jun 19 14:46:25 EDT 2012
DISTRO INFO:
RedHatEnterpriseServer
5.8
i686
THIS IS A NEW INSTALL!
INSTALLING:
full=2011R3.1
major=2011
minor=R3.1
releasedate=2012-06-08
release=216
Configuring Yum...
Enabling RPMForge repo...
Installing RPMForge PKG: packages/rpmforge-release-0.5.2-2.el5.rf.i386.rpm
warning: packages/rpmforge-release-0.5.2-2.el5.rf.i386.rpm: Header V3 DSA signature: NOKEY, key ID 6b8d79e6
Preparing... ########################################
rpmforge-release #######################################
Loaded plugins: rhnplugin
clamav.i386 0.97.4-1.el5.rf rpmforge
rpmforge-release RPM installed OK
Enabling EPEL repo...
Installing EPEL PKG: ./packages/epel-release-5-4.noarch.rpm
warning: ./packages/epel-release-5-4.noarch.rpm: Header V3 DSA signature: NOKEY, key ID 217521f6
epel-release ########################################
epel-release RPM installed OK
Yum configured OK
Installing prerequisites...
Setting up Local Package Process
Examining /tmp/nagiosxi/packages/php-pear-HTML-Template-IT-1.3.0-2.el5.noarch.rpm: php-pear-HTML-Template-IT-1.3.0-2.el5.noarch
Marking /tmp/nagiosxi/packages/php-pear-HTML-Template-IT-1.3.0-2.el5.noarch.rpm to be installed
Examining /tmp/nagiosxi/nagiosxi-deps-2011r3.1-1.noarch.rpm: nagiosxi-deps-2011r3.1-1.noarch
Marking /tmp/nagiosxi/nagiosxi-deps-2011r3.1-1.noarch.rpm to be installed
Resolving Dependencies
--> Running transaction check
--> Package nagiosxi-deps.noarch 0:2011r3.1-1 set to be updated
--> Processing Dependency: dstat for package: nagiosxi-deps
--> Processing Dependency: expat-devel for package: nagiosxi-deps
--> Processing Dependency: fping for package: nagiosxi-deps
--> Processing Dependency: gcc for package: nagiosxi-deps
--> Processing Dependency: gd for package: nagiosxi-deps
--> Processing Dependency: gd-devel for package: nagiosxi-deps
--> Processing Dependency: graphviz for package: nagiosxi-deps
--> Processing Dependency: httpd for package: nagiosxi-deps
--> Processing Dependency: libmcrypt for package: nagiosxi-deps
--> Processing Dependency: libmcrypt-devel for package: nagiosxi-deps
--> Processing Dependency: mrtg for package: nagiosxi-deps
--> Processing Dependency: mysql for package: nagiosxi-deps
--> Processing Dependency: mysql-devel for package: nagiosxi-deps
--> Processing Dependency: mysql-server for package: nagiosxi-deps
--> Processing Dependency: net-snmp for package: nagiosxi-deps
--> Processing Dependency: net-snmp-utils for package: nagiosxi-deps
--> Processing Dependency: nmap for package: nagiosxi-deps
--> Processing Dependency: numpy for package: nagiosxi-deps
--> Processing Dependency: openldap-devel for package: nagiosxi-deps
--> Processing Dependency: openssl-devel for package: nagiosxi-deps
--> Processing Dependency: perl(Crypt::SSLeay) for package: nagiosxi-deps
--> Processing Dependency: perl(Error) for package: nagiosxi-deps
--> Processing Dependency: perl(HTTP::Cookies) for package: nagiosxi-deps
--> Processing Dependency: perl(HTTP::Request::Common) for package: nagiosxi-deps
--> Processing Dependency: perl(Mail::POP3Client) for package: nagiosxi-deps
--> Processing Dependency: perl(Net::SMTP::TLS) for package: nagiosxi-deps
--> Processing Dependency: perl(XML::Parser) for package: nagiosxi-deps
--> Processing Dependency: perl(XML::Simple) for package: nagiosxi-deps
--> Processing Dependency: perl-Net-SNMP for package: nagiosxi-deps
--> Processing Dependency: php for package: nagiosxi-deps
--> Processing Dependency: php-gd for package: nagiosxi-deps
--> Processing Dependency: php-mcrypt for package: nagiosxi-deps
--> Processing Dependency: php-mssql for package: nagiosxi-deps
--> Processing Dependency: php-mysql for package: nagiosxi-deps
--> Processing Dependency: php-pear for package: nagiosxi-deps
--> Processing Dependency: php-pgsql for package: nagiosxi-deps
--> Processing Dependency: php-snmp for package: nagiosxi-deps
--> Processing Dependency: php-xml for package: nagiosxi-deps
--> Processing Dependency: postgresql for package: nagiosxi-deps
--> Processing Dependency: postgresql-devel for package: nagiosxi-deps
--> Processing Dependency: postgresql-libs for package: nagiosxi-deps
--> Processing Dependency: postgresql-server for package: nagiosxi-deps
--> Processing Dependency: python-lxml for package: nagiosxi-deps
--> Processing Dependency: python-matplotlib for package: nagiosxi-deps
--> Processing Dependency: rpmdevtools for package: nagiosxi-deps
--> Processing Dependency: rrdtool for package: nagiosxi-deps
--> Processing Dependency: rrdtool-perl for package: nagiosxi-deps
--> Processing Dependency: rrdtool-python for package: nagiosxi-deps
--> Processing Dependency: scipy for package: nagiosxi-deps
--> Package php-pear-HTML-Template-IT.noarch 0:1.3.0-2.el5 set to be updated
--> Package dstat.noarch 0:0.6.6-5.el5 set to be updated
--> Package expat-devel.i386 0:1.95.8-8.3.el5_5.3 set to be updated
--> Package fping.i386 0:3.1-1.el5.rf set to be updated
--> Package gcc.i386 0:4.1.2-52.el5 set to be updated
--> Processing Dependency: cpp = 4.1.2-52.el5 for package: gcc
--> Processing Dependency: glibc-devel >= 2.2.90-12 for package: gcc
--> Package gd.i386 0:2.0.33-9.4.el5_4.2 set to be updated
--> Processing Dependency: pkgconfig for package: gd
--> Package gd-devel.i386 0:2.0.33-9.4.el5_4.2 set to be updated
--> Processing Dependency: fontconfig-devel for package: gd-devel
--> Processing Dependency: libX11-devel for package: gd-devel
--> Processing Dependency: libXpm-devel for package: gd-devel
--> Processing Dependency: zlib-devel for package: gd-devel
--> Processing Dependency: libpng-devel for package: gd-devel
--> Processing Dependency: freetype-devel for package: gd-devel
--> Processing Dependency: libjpeg-devel for package: gd-devel
--> Package graphviz.i386 0:2.22.0-4.el5.rf set to be updated
--> Processing Dependency: libXaw.so.7 for package: graphviz
--> Processing Dependency: libgs.so.8 for package: graphviz
--> Processing Dependency: librsvg-2.so.2 for package: graphviz
--> Package httpd.i386 0:2.2.3-63.el5_8.1 set to be updated
--> Processing Dependency: libapr-1.so.0 for package: httpd
--> Processing Dependency: libaprutil-1.so.0 for package: httpd
--> Package libmcrypt.i386 0:2.5.7-5.el5 set to be updated
--> Package libmcrypt-devel.i386 0:2.5.7-5.el5 set to be updated
--> Package mrtg.i386 0:2.14.5-4.el5 set to be updated
--> Processing Dependency: perl-IO-Socket-INET6 for package: mrtg
--> Processing Dependency: perl-Socket6 for package: mrtg
--> Package mysql.i386 0:5.0.95-1.el5_7.1 set to be updated
--> Processing Dependency: perl(DBI) for package: mysql
--> Package mysql-devel.i386 0:5.0.95-1.el5_7.1 set to be updated
--> Package mysql-server.i386 0:5.0.95-1.el5_7.1 set to be updated
--> Processing Dependency: perl-DBD-MySQL for package: mysql-server
--> Package net-snmp.i386 1:5.3.2.2-17.el5 set to be updated
--> Processing Dependency: libsensors.so.3 for package: net-snmp
--> Package net-snmp-utils.i386 1:5.3.2.2-17.el5 set to be updated
--> Package nmap.i386 2:4.11-2 set to be updated
--> Package numpy.i386 0:1.2.1-2.el5 set to be updated
--> Processing Dependency: python-nose for package: numpy
--> Processing Dependency: libatlas.so.3 for package: numpy
--> Processing Dependency: python-devel for package: numpy
--> Processing Dependency: libptcblas.so.3 for package: numpy
--> Processing Dependency: liblapack.so.3 for package: numpy
--> Processing Dependency: libptf77blas.so.3 for package: numpy
---> Package openldap-devel.i386 0:2.3.43-25.el5 set to be updated
--> Processing Dependency: cyrus-sasl-devel >= 2.1 for package: openldap-devel
--> Package openssl-devel.i386 0:0.9.8e-22.el5 set to be updated
--> Processing Dependency: krb5-devel for package: openssl-devel
--> Package perl-Crypt-SSLeay.i386 0:0.51-11.el5 set to be updated
--> Package perl-Error.noarch 1:0.17010-1.el5 set to be updated
--> Package perl-Mail-POP3Client.noarch 0:2.18-1.el5.rf set to be updated
--> Package perl-Net-SMTP-TLS.noarch 0:0.12-1.el5.rf set to be updated
--> Processing Dependency: perl(Digest::HMAC_MD5) for package: perl-Net-SMTP-TLS
--> Processing Dependency: perl(Net::SSLeay) for package: perl-Net-SMTP-TLS
--> Processing Dependency: perl(IO::Socket::SSL) for package: perl-Net-SMTP-TLS
--> Package perl-Net-SNMP.noarch 0:5.2.0-1.2.el5.rf set to be updated
--> Processing Dependency: perl(Crypt::DES) for package: perl-Net-SNMP
--> Processing Dependency: perl(Digest::SHA1) for package: perl-Net-SNMP
--> Package perl-XML-Parser.i386 0:2.34-6.1.2.2.1 set to be updated
--> Package perl-XML-Simple.noarch 0:2.14-4.fc6 set to be updated
--> Package perl-libwww-perl.noarch 0:5.805-1.1.1 set to be updated
--> Processing Dependency: perl-HTML-Parser >= 3.33 for package: perl-libwww-perl
--> Processing Dependency: perl(Compress::Zlib) for package: perl-libwww-perl
--> Processing Dependency: perl(HTML::Entities) for package: perl-libwww-perl
--> Package perl-rrdtool.i386 0:1.4.7-1.el5.rf set to be updated
--> Package php.i386 0:5.1.6-32.el5 set to be updated
--> Processing Dependency: php-cli = 5.1.6-32.el5 for package: php
--> Processing Dependency: php-common = 5.1.6-32.el5 for package: php
--> Processing Dependency: libgmp.so.3 for package: php
--> Processing Dependency: libaspell.so.15 for package: php
--> Processing Dependency: libpspell.so.15 for package: php
--> Package php-gd.i386 0:5.1.6-32.el5 set to be updated
--> Package php-mcrypt.i386 0:5.1.6-5.el5 set to be updated
--> Package php-mssql.i386 0:5.1.6-5.el5 set to be updated
--> Processing Dependency: php-pdo >= 5.1.6 for package: php-mssql
--> Processing Dependency: libsybdb.so.5 for package: php-mssql
--> Package php-mysql.i386 0:5.1.6-32.el5 set to be updated
--> Package php-pear.noarch 1:1.4.9-8.el5 set to be updated
--> Processing Dependency: php-devel for package: php-pear
--> Package php-pgsql.i386 0:5.1.6-32.el5 set to be updated
--> Package php-snmp.i386 0:5.1.6-32.el5 set to be updated
--> Package php-xml.i386 0:5.1.6-32.el5 set to be updated
--> Processing Dependency: libexslt.so.0 for package: php-xml
--> Processing Dependency: libxslt.so.1 for package: php-xml
--> Package postgresql.i386 0:8.1.23-1.el5_7.3 set to be updated
--> Package postgresql-devel.i386 0:8.1.23-1.el5_7.3 set to be updated
--> Package postgresql-libs.i386 0:8.1.23-1.el5_7.3 set to be updated
--> Package postgresql-server.i386 0:8.1.23-1.el5_7.3 set to be updated
--> Package python-lxml.i386 0:2.0.11-1.el5 set to be updated
--> Package python-matplotlib.i386 0:0.99.1.2-1.el5 set to be updated
--> Processing Dependency: pycairo >= 1.2.0 for package: python-matplotlib
--> Processing Dependency: python-dateutil for package: python-matplotlib
--> Processing Dependency: pytz for package: python-matplotlib
--> Package python-rrdtool.i386 0:1.4.7-1.el5.rf set to be updated
--> Package rpmdevtools.noarch 0:6.8-1.el5 set to be updated
--> Processing Dependency: rpm-build >= 4.4.2.1 for package: rpmdevtools
--> Processing Dependency: fakeroot for package: rpmdevtools
--> Processing Dependency: gcc-c++ for package: rpmdevtools
--> Processing Dependency: redhat-rpm-config for package: rpmdevtools
--> Package rrdtool.i386 0:1.4.7-1.el5.rf set to be updated
--> Processing Dependency: xorg-x11-fonts-Type1 for package: rrdtool
--> Processing Dependency: ruby for package: rrdtool
--> Processing Dependency: lua for package: rrdtool
--> Processing Dependency: libdbi.so.0 for package: rrdtool
--> Package scipy.i386 0:0.6.0-6.el5 set to be updated
--> Processing Dependency: libumfpack.so.5 for package: scipy
--> Processing Dependency: libfftw3.so.3 for package: scipy
--> Processing Dependency: libamd.so.2 for package: scipy
--> Processing Dependency: libblas.so.3 for package: scipy
--> Processing Dependency: libgfortran.so.1 for package: scipy
--> Package apr.i386 0:1.2.7-11.el5_6.5 set to be updated
--> Package apr-util.i386 0:1.2.7-11.el5_5.2 set to be updated
--> Package aspell.i386 12:0.60.3-12 set to be updated
--> Processing Dependency: aspell-en for package: aspell
--> Package atlas-sse.i386 0:3.8.3-1.el5 set to be updated
--> Package blas.i386 0:3.0-38.el5 set to be updated
--> Package cpp.i386 0:4.1.2-52.el5 set to be updated
--> Package cyrus-sasl-devel.i386 0:2.1.22-5.el5_4.3 set to be updated
--> Package fakeroot.i386 0:1.12.2-21.el5.2 set to be updated
--> Processing Dependency: fakeroot-libs = 1.12.2-21.el5.2 for package: fakeroot
--> Package fftw3.i386 0:3.2.2-3.el5 set to be updated
--> Package fontconfig-devel.i386 0:2.4.1-7.el5 set to be updated
--> Package freetds.i386 0:0.91-2.el5 set to be updated
--> Processing Dependency: libodbcinst.so.1 for package: freetds
--> Processing Dependency: libodbc.so.1 for package: freetds
--> Package freetype-devel.i386 0:2.2.1-28.el5_7.2 set to be updated
--> Package gcc-c++.i386 0:4.1.2-52.el5 set to be updated
--> Processing Dependency: libstdc++-devel = 4.1.2-52.el5 for package: gcc-c++
--> Package ghostscript.i386 0:8.70-14.el5 set to be updated
--> Processing Dependency: urw-fonts >= 1.1 for package: ghostscript
--> Processing Dependency: ghostscript-fonts for package: ghostscript
--> Package glibc-devel.i386 0:2.5-81 set to be updated
--> Processing Dependency: glibc-headers = 2.5-81 for package: glibc-devel
--> Processing Dependency: glibc-headers for package: glibc-devel
--> Package gmp.i386 0:4.1.4-10.el5 set to be updated
--> Package krb5-devel.i386 0:1.6.1-70.el5 set to be updated
--> Processing Dependency: keyutils-libs-devel for package: krb5-devel
--> Processing Dependency: libselinux-devel for package: krb5-devel
--> Processing Dependency: e2fsprogs-devel for package: krb5-devel
--> Package libX11-devel.i386 0:1.0.3-11.el5_7.1 set to be updated
--> Processing Dependency: xorg-x11-proto-devel >= 7.1-2 for package: libX11-devel
--> Processing Dependency: libXdmcp-devel for package: libX11-devel
--> Processing Dependency: libXau-devel for package: libX11-devel
--> Package libXaw.i386 0:1.0.2-8.1 set to be updated
--> Package libXpm-devel.i386 0:3.5.5-3 set to be updated
--> Package libdbi.i386 0:0.8.1-2.1 set to be updated
--> Package libgfortran.i386 0:4.1.2-52.el5 set to be updated
--> Package libjpeg-devel.i386 0:6b-37 set to be updated
--> Package libpng-devel.i386 2:1.2.10-15.el5_7 set to be updated
--> Package librsvg2.i386 0:2.16.1-1.el5 set to be updated
--> Processing Dependency: libcroco >= 0.6.1 for package: librsvg2
--> Processing Dependency: libgsf >= 1.6.0 for package: librsvg2
--> Processing Dependency: gnome-vfs2 >= 1.9.16 for package: librsvg2
--> Processing Dependency: libgsf-1.so.114 for package: librsvg2
--> Processing Dependency: libcroco-0.6.so.3 for package: librsvg2
--> Processing Dependency: libgnomevfs-2.so.0 for package: librsvg2
--> Processing Dependency: libORBit-2.so.0 for package: librsvg2
--> Processing Dependency: libgconf-2.so.4 for package: librsvg2
--> Package libxslt.i386 0:1.1.17-2.el5_2.2 set to be updated
--> Package lm_sensors.i386 0:2.10.7-9.el5 set to be updated
--> Package lua.i386 0:5.1.4-4.el5 set to be updated
--> Package perl-Compress-Zlib.i386 0:1.42-1.fc6 set to be updated
--> Package perl-Crypt-DES.i386 0:2.05-3.2.el5.rf set to be updated
--> Package perl-DBD-MySQL.i386 0:3.0007-2.el5 set to be updated
--> Package perl-DBI.i386 0:1.52-2.el5 set to be updated
--> Package perl-Digest-HMAC.noarch 0:1.01-15 set to be updated
--> Package perl-Digest-SHA1.i386 0:2.11-1.2.1 set to be updated
--> Package perl-HTML-Parser.i386 0:3.55-1.fc6 set to be updated
--> Processing Dependency: perl-HTML-Tagset >= 3.03 for package: perl-HTML-Parser
--> Processing Dependency: perl(HTML::Tagset) for package: perl-HTML-Parser
--> Package perl-IO-Socket-INET6.noarch 0:2.51-2.fc6 set to be updated
--> Package perl-IO-Socket-SSL.noarch 0:1.01-1.fc6 set to be updated
--> Package perl-Net-SSLeay.i386 0:1.30-4.fc6 set to be updated
--> Package perl-Socket6.i386 0:0.19-3.fc6 set to be updated
--> Package php-cli.i386 0:5.1.6-32.el5 set to be updated
--> Package php-common.i386 0:5.1.6-32.el5 set to be updated
--> Package php-devel.i386 0:5.1.6-32.el5 set to be updated
--> Processing Dependency: automake for package: php-devel
--> Processing Dependency: autoconf for package: php-devel
--> Package php-pdo.i386 0:5.1.6-32.el5 set to be updated
--> Package pkgconfig.i386 1:0.21-2.el5 set to be updated
--> Package pycairo.i386 0:1.2.0-1.1 set to be updated
--> Package python-dateutil.noarch 0:1.2-1.el5.rf set to be updated
--> Package python-devel.i386 0:2.4.3-46.el5 set to be updated
--> Package python-nose.noarch 0:0.11.3-2.el5 set to be updated
--> Processing Dependency: python-setuptools for package: python-nose
--> Package python-tz.noarch 0:2006p-1.el5.rf set to be updated
--> Package redhat-rpm-config.noarch 0:8.0.45-32.el5 set to be updated
--> Package rpm-build.i386 0:4.4.2.3-27.el5 set to be updated
--> Processing Dependency: xz for package: rpm-build
--> Processing Dependency: elfutils for package: rpm-build
--> Package ruby.i386 0:1.8.5-24.el5 set to be updated
--> Processing Dependency: ruby-libs = 1.8.5-24.el5 for package: ruby
--> Processing Dependency: libruby.so.1.8 for package: ruby
--> Package suitesparse.i386 0:3.1.0-1.el5 set to be updated
--> Package xorg-x11-fonts-Type1.noarch 0:7.1-2.1.el5 set to be updated
--> Processing Dependency: mkfontscale for package: xorg-x11-fonts-Type1
--> Processing Dependency: mkfontdir for package: xorg-x11-fonts-Type1
--> Processing Dependency: chkfontpath for package: xorg-x11-fonts-Type1
--> Package zlib-devel.i386 0:1.2.3-4.el5 set to be updated
--> Package GConf2.i386 0:2.14.0-9.el5 set to be updated
--> Package ORBit2.i386 0:2.14.3-5.el5 set to be updated
--> Processing Dependency: libIDL-2.so.0 for package: ORBit2
--> Package aspell-en.i386 50:6.0-2.1 set to be updated
--> Package autoconf.noarch 0:2.59-12 set to be updated
--> Processing Dependency: imake for package: autoconf
--> Package automake.noarch 0:1.9.6-2.3.el5 set to be updated
--> Package chkfontpath.i386 0:1.10.1-1.1 set to be updated
--> Processing Dependency: xfs for package: chkfontpath
--> Package e2fsprogs-devel.i386 0:1.39-33.el5 set to be updated
--> Package elfutils.i386 0:0.137-3.el5 set to be updated
--> Processing Dependency: elfutils-libs-i386 = 0.137-3.el5 for package: elfutils
--> Processing Dependency: libasm.so.1(ELFUTILS_1.0) for package: elfutils
--> Processing Dependency: libdw.so.1(ELFUTILS_0.127) for package: elfutils
--> Processing Dependency: libdw.so.1(ELFUTILS_0.126) for package: elfutils
--> Processing Dependency: libdw.so.1(ELFUTILS_0.130) for package: elfutils
--> Processing Dependency: libasm.so.1 for package: elfutils
--> Processing Dependency: libdw.so.1(ELFUTILS_0.122) for package: elfutils
--> Processing Dependency: libdw.so.1 for package: elfutils
--> Package fakeroot-libs.i386 0:1.12.2-21.el5.2 set to be updated
--> Package ghostscript-fonts.noarch 0:5.50-13.1.1 set to be updated
--> Package glibc-headers.i386 0:2.5-81 set to be updated
--> Package gnome-vfs2.i386 0:2.16.2-8.el5 set to be updated
--> Processing Dependency: gnome-mount >= 0.4 for package: gnome-vfs2
--> Processing Dependency: gnome-mime-data >= 2.0.0-11 for package: gnome-vfs2
--> Processing Dependency: libavahi-glib.so.1 for package: gnome-vfs2
--> Processing Dependency: shared-mime-info for package: gnome-vfs2
--> Package keyutils-libs-devel.i386 0:1.2-1.el5 set to be updated
--> Package libXau-devel.i386 0:1.0.1-3.1 set to be updated
--> Package libXdmcp-devel.i386 0:1.0.1-2.1 set to be updated
--> Package libcroco.i386 0:0.6.1-2.1 set to be updated
--> Package libgsf.i386 0:1.14.1-6.1 set to be updated
--> Processing Dependency: libbonobo-activation.so.4 for package: libgsf
--> Processing Dependency: libbonobo-2.so.0 for package: libgsf
--> Package libselinux-devel.i386 0:1.33.4-5.7.el5 set to be updated
--> Processing Dependency: libsepol-devel >= 1.15.2-1 for package: libselinux-devel
--> Package libstdc++-devel.i386 0:4.1.2-52.el5 set to be updated
--> Package perl-HTML-Tagset.noarch 0:3.10-2.1.1 set to be updated
--> Package python-setuptools.noarch 0:0.6c5-2.el5 set to be updated
--> Package ruby-libs.i386 0:1.8.5-24.el5 set to be updated
--> Package unixODBC-libs.i386 0:2.2.11-10.el5 set to be updated
--> Package urw-fonts.noarch 0:2.3-6.1.1 set to be updated
--> Package xorg-x11-font-utils.i386 1:7.1-3 set to be updated
--> Processing Dependency: libfontenc >= 0.99.2-2 for package: xorg-x11-font-utils
--> Processing Dependency: libXfont.so.1 for package: xorg-x11-font-utils
--> Processing Dependency: libfontenc.so.1 for package: xorg-x11-font-utils
--> Package xorg-x11-proto-devel.i386 0:7.1-13.el5 set to be updated
--> Processing Dependency: mesa-libGL-devel for package: xorg-x11-proto-devel
--> Package xz.i386 0:4.999.9-0.3.beta.20091007git.el5 set to be updated
--> Processing Dependency: xz-libs = 4.999.9-0.3.beta.20091007git.el5 for package: xz
--> Processing Dependency: liblzma.so.0 for package: xz
--> Package avahi-glib.i386 0:0.6.16-10.el5_6 set to be updated
--> Package elfutils-libs.i386 0:0.137-3.el5 set to be updated
--> Package gnome-mime-data.i386 0:2.4.2-3.1 set to be updated
--> Package gnome-mount.i386 0:0.5-3.el5 set to be updated
--> Processing Dependency: libnotify.so.1 for package: gnome-mount
--> Processing Dependency: libgnome-keyring.so.0 for package: gnome-mount
--> Processing Dependency: libgnome-2.so.0 for package: gnome-mount
--> Processing Dependency: libgnomeui-2.so.0 for package: gnome-mount
--> Processing Dependency: libgnomecanvas-2.so.0 for package: gnome-mount
--> Processing Dependency: libart_lgpl_2.so.2 for package: gnome-mount
--> Processing Dependency: libbonoboui-2.so.0 for package: gnome-mount
--> Package imake.i386 0:1.0.2-3 set to be updated
--> Package libIDL.i386 0:0.8.7-1.fc6 set to be updated
--> Package libXfont.i386 0:1.2.2-1.0.4.el5_7 set to be updated
--> Package libbonobo.i386 0:2.16.0-1.1.el5_5.1 set to be updated
--> Package libfontenc.i386 0:1.0.2-2.2.el5 set to be updated
--> Package libsepol-devel.i386 0:1.15.2-3.el5 set to be updated
--> Package mesa-libGL-devel.i386 0:6.5.1-7.10.el5 set to be updated
--> Package shared-mime-info.i386 0:0.19-5.el5 set to be updated
--> Package xorg-x11-xfs.i386 1:1.0.2-5.el5_6.1 set to be updated
--> Processing Dependency: libFS.so.6 for package: xorg-x11-xfs
--> Processing Dependency: ttmkfdir for package: xorg-x11-xfs
--> Package xz-libs.i386 0:4.999.9-0.3.beta.20091007git.el5 set to be updated
---> Package gnome-keyring.i386 0:0.6.0-1.fc6 set to be updated
---> Package libFS.i386 0:1.0.0-3.1 set to be updated
--> Package libart_lgpl.i386 0:2.3.17-4 set to be updated
--> Package libbonoboui.i386 0:2.16.0-1.fc6 set to be updated
--> Processing Dependency: libglade2 >= 2.0.0 for package: libbonoboui
--> Processing Dependency: libglade-2.0.so.0 for package: libbonoboui
--> Package libgnome.i386 0:2.16.0-6.el5 set to be updated
--> Processing Dependency: libaudiofile.so.0 for package: libgnome
--> Processing Dependency: libesd.so.0 for package: libgnome
--> Package libgnomecanvas.i386 0:2.14.0-4.1 set to be updated
--> Package libgnomeui.i386 0:2.16.0-5.el5 set to be updated
--> Package libnotify.i386 0:0.4.2-6.el5 set to be updated
--> Processing Dependency: desktop-notification-daemon for package: libnotify
--> Package ttmkfdir.i386 0:3.0.9-23.el5 set to be updated
--> Package audiofile.i386 1:0.2.6-5 set to be updated
--> Package esound.i386 1:0.2.36-4 set to be updated
--> Processing Dependency: libasound.so.2 for package: esound
--> Processing Dependency: libasound.so.2(ALSA_0.9.0rc4) for package: esound
--> Processing Dependency: libasound.so.2(ALSA_0.9) for package: esound
--> Package libglade2.i386 0:2.6.0-2 set to be updated
--> Package notification-daemon.i386 0:0.3.5-9.el5 set to be updated
--> Processing Dependency: libwnck-1.so.18 for package: notification-daemon
--> Package alsa-lib.i386 0:1.0.17-1.el5 set to be updated
--> Package libwnck.i386 0:2.16.0-4.fc6 set to be updated
--> Processing Dependency: startup-notification >= 0.5 for package: libwnck
--> Processing Dependency: libXRes.so.1 for package: libwnck
--> Processing Dependency: libstartup-notification-1.so.0 for package: libwnck
--> Package libXres.i386 0:1.0.1-3.1 set to be updated
--> Package startup-notification.i386 0:0.8-4.1 set to be updated
Dependencies Resolved
Package Arch Version Repository Size
Installing:
nagiosxi-deps noarch 2011r3.1-1 /nagiosxi-deps-2011r3.1-1.noarch
0.0
noarch 1.3.0-2.el5 /php-pear-HTML-Template-IT-1.3.0-2.el5.noarch
107 k
Installing for dependencies:
GConf2 i386 2.14.0-9.el5 dev-rhel5-key-approved-i386 1.5 M
ORBit2 i386 2.14.3-5.el5 dev-rhel5-key-approved-i386 253 k
alsa-lib i386 1.0.17-1.el5 dev-rhel5-key-approved-i386 411 k
apr i386 1.2.7-11.el5_6.5 dev-rhel5-key-approved-i386 124 k
apr-util i386 1.2.7-11.el5_5.2 dev-rhel5-key-approved-i386 80 k
aspell i386 12:0.60.3-12 dev-rhel5-key-approved-i386 946 k
aspell-en i386 50:6.0-2.1 dev-rhel5-key-approved-i386 1.6 M
atlas-sse i386 3.8.3-1.el5 epel 2.6 M
audiofile i386 1:0.2.6-5 dev-rhel5-key-approved-i386 107 k
autoconf noarch 2.59-12 dev-rhel5-key-approved-i386 646 k
automake noarch 1.9.6-2.3.el5 dev-rhel5-key-approved-i386 476 k
avahi-glib i386 0.6.16-10.el5_6 dev-rhel5-key-approved-i386 15 k
blas i386 3.0-38.el5 dev-rhel5-key-approved-i386 318 k
chkfontpath i386 1.10.1-1.1 dev-rhel5-key-approved-i386 15 k
cpp i386 4.1.2-52.el5 dev-rhel5-key-approved-i386 2.7 M
cyrus-sasl-devel i386 2.1.22-5.el5_4.3 dev-rhel5-key-approved-i386 1.4 M
dstat noarch 0.6.6-5.el5 dev-rhel5-key-approved-i386 106 k
e2fsprogs-devel i386 1.39-33.el5 dev-rhel5-key-approved-i386 573 k
elfutils i386 0.137-3.el5 dev-rhel5-key-approved-i386 228 k
elfutils-libs i386 0.137-3.el5 dev-rhel5-key-approved-i386 193 k
esound i386 1:0.2.36-4 dev-rhel5-key-approved-i386 130 k
expat-devel i386 1.95.8-8.3.el5_5.3
dev-rhel5-key-approved-i386 132 k
fakeroot i386 1.12.2-21.el5.2 epel 75 k
fakeroot-libs i386 1.12.2-21.el5.2 epel 71 k
fftw3 i386 3.2.2-3.el5 epel 1.3 M
fontconfig-devel i386 2.4.1-7.el5 dev-rhel5-key-approved-i386 168 k
fping i386 3.1-1.el5.rf rpmforge 56 k
freetds i386 0.91-2.el5 epel 992 k
freetype-devel i386 2.2.1-28.el5_7.2 dev-rhel5-key-approved-i386 149 k
gcc i386 4.1.2-52.el5 dev-rhel5-key-approved-i386 5.2 M
gcc-c++ i386 4.1.2-52.el5 dev-rhel5-key-approved-i386 3.4 M
gd i386 2.0.33-9.4.el5_4.2
dev-rhel5-key-approved-i386 155 k
gd-devel i386 2.0.33-9.4.el5_4.2
dev-rhel5-key-approved-i386 98 k
ghostscript i386 8.70-14.el5 dev-rhel5-key-approved-i386 9.0 M
ghostscript-fonts noarch 5.50-13.1.1 dev-rhel5-key-approved-i386 801 k
glibc-devel i386 2.5-81 dev-rhel5-key-approved-i386 2.0 M
glibc-headers i386 2.5-81 dev-rhel5-key-approved-i386 606 k
gmp i386 4.1.4-10.el5 dev-rhel5-key-approved-i386 665 k
gnome-keyring i386 0.6.0-1.fc6 dev-rhel5-key-approved-i386 170 k
gnome-mime-data i386 2.4.2-3.1 dev-rhel5-key-approved-i386 691 k
gnome-mount i386 0.5-3.el5 dev-rhel5-key-approved-i386 70 k
gnome-vfs2 i386 2.16.2-8.el5 dev-rhel5-key-approved-i386 1.2 M
graphviz i386 2.22.0-4.el5.rf rpmforge 2.5 M
httpd i386 2.2.3-63.el5_8.1 dev-rhel5-key-approved-i386 1.2 M
imake i386 1.0.2-3 dev-rhel5-key-approved-i386 318 k
keyutils-libs-devel i386 1.2-1.el5 dev-rhel5-key-approved-i386 27 k
krb5-devel i386 1.6.1-70.el5 dev-rhel5-key-approved-i386 1.9 M
libFS i386 1.0.0-3.1 dev-rhel5-key-approved-i386 30 k
libIDL i386 0.8.7-1.fc6 dev-rhel5-key-approved-i386 85 k
libX11-devel i386 1.0.3-11.el5_7.1 dev-rhel5-key-approved-i386 661 k
libXau-devel i386 1.0.1-3.1 dev-rhel5-key-approved-i386 11 k
libXaw i386 1.0.2-8.1 dev-rhel5-key-approved-i386 325 k
libXdmcp-devel i386 1.0.1-2.1 dev-rhel5-key-approved-i386 7.6 k
libXfont i386 1.2.2-1.0.4.el5_7
dev-rhel5-key-approved-i386 240 k
libXpm-devel i386 3.5.5-3 dev-rhel5-key-approved-i386 31 k
libXres i386 1.0.1-3.1 dev-rhel5-key-approved-i386 14 k
libart_lgpl i386 2.3.17-4 dev-rhel5-key-approved-i386 76 k
libbonobo i386 2.16.0-1.1.el5_5.1
dev-rhel5-key-approved-i386 502 k
libbonoboui i386 2.16.0-1.fc6 dev-rhel5-key-approved-i386 390 k
libcroco i386 0.6.1-2.1 dev-rhel5-key-approved-i386 127 k
libdbi i386 0.8.1-2.1 dev-rhel5-key-approved-i386 35 k
libfontenc i386 1.0.2-2.2.el5 dev-rhel5-key-approved-i386 19 k
libgfortran i386 4.1.2-52.el5 dev-rhel5-key-approved-i386 232 k
libglade2 i386 2.6.0-2 dev-rhel5-key-approved-i386 96 k
libgnome i386 2.16.0-6.el5 dev-rhel5-key-approved-i386 859 k
libgnomecanvas i386 2.14.0-4.1 dev-rhel5-key-approved-i386 222 k
libgnomeui i386 2.16.0-5.el5 dev-rhel5-key-approved-i386 977 k
libgsf i386 1.14.1-6.1 dev-rhel5-key-approved-i386 116 k
libjpeg-devel i386 6b-37 dev-rhel5-key-approved-i386 106 k
libmcrypt i386 2.5.7-5.el5 epel 124 k
libmcrypt-devel i386 2.5.7-5.el5 epel 103 k
libnotify i386 0.4.2-6.el5 dev-rhel5-key-approved-i386 37 k
libpng-devel i386 2:1.2.10-15.el5_7
dev-rhel5-key-approved-i386 182 k
librsvg2 i386 2.16.1-1.el5 dev-rhel5-key-approved-i386 179 k
libselinux-devel i386 1.33.4-5.7.el5 dev-rhel5-key-approved-i386 144 k
libsepol-devel i386 1.15.2-3.el5 dev-rhel5-key-approved-i386 188 k
libstdc++-devel i386 4.1.2-52.el5 dev-rhel5-key-approved-i386 2.8 M
libwnck i386 2.16.0-4.fc6 dev-rhel5-key-approved-i386 185 k
libxslt i386 1.1.17-2.el5_2.2 dev-rhel5-key-approved-i386 485 k
lm_sensors i386 2.10.7-9.el5 dev-rhel5-key-approved-i386 511 k
lua i386 5.1.4-4.el5 epel 228 k
mesa-libGL-devel i386 6.5.1-7.10.el5 dev-rhel5-key-approved-i386 461 k
mrtg i386 2.14.5-4.el5 dev-rhel5-key-approved-i386 837 k
mysql i386 5.0.95-1.el5_7.1 dev-rhel5-key-approved-i386 4.9 M
mysql-devel i386 5.0.95-1.el5_7.1 dev-rhel5-key-approved-i386 2.4 M
mysql-server i386 5.0.95-1.el5_7.1 dev-rhel5-key-approved-i386 9.8 M
net-snmp i386 1:5.3.2.2-17.el5 dev-rhel5-key-approved-i386 703 k
net-snmp-utils i386 1:5.3.2.2-17.el5 dev-rhel5-key-approved-i386 191 k
nmap i386 2:4.11-2 dev-rhel5-key-approved-i386 660 k
notification-daemon i386 0.3.5-9.el5 dev-rhel5-key-approved-i386 47 k
numpy i386 1.2.1-2.el5 epel 2.4 M
openldap-devel i386 2.3.43-25.el5 dev-rhel5-key-approved-i386 2.9 M
openssl-devel i386 0.9.8e-22.el5 dev-rhel5-key-approved-i386 1.9 M
perl-Compress-Zlib i386 1.42-1.fc6 dev-rhel5-key-approved-i386 52 k
perl-Crypt-DES i386 2.05-3.2.el5.rf rpmforge 37 k
perl-Crypt-SSLeay i386 0.51-11.el5 dev-rhel5-key-approved-i386 45 k
perl-DBD-MySQL i386 3.0007-2.el5 dev-rhel5-key-approved-i386 147 k
perl-DBI i386 1.52-2.el5 dev-rhel5-key-approved-i386 605 k
perl-Digest-HMAC noarch 1.01-15 dev-rhel5-key-approved-i386 12 k
perl-Digest-SHA1 i386 2.11-1.2.1 dev-rhel5-key-approved-i386 49 k
perl-Error noarch 1:0.17010-1.el5 epel 26 k
perl-HTML-Parser i386 3.55-1.fc6 dev-rhel5-key-approved-i386 92 k
perl-HTML-Tagset noarch 3.10-2.1.1 dev-rhel5-key-approved-i386 14 k
perl-IO-Socket-INET6 noarch 2.51-2.fc6 dev-rhel5-key-approved-i386 13 k
perl-IO-Socket-SSL noarch 1.01-1.fc6 dev-rhel5-key-approved-i386 49 k
perl-Mail-POP3Client noarch 2.18-1.el5.rf rpmforge 26 k
perl-Net-SMTP-TLS noarch 0.12-1.el5.rf rpmforge 13 k
perl-Net-SNMP noarch 5.2.0-1.2.el5.rf rpmforge 96 k
perl-Net-SSLeay i386 1.30-4.fc6 dev-rhel5-key-approved-i386 195 k
perl-Socket6 i386 0.19-3.fc6 dev-rhel5-key-approved-i386 22 k
perl-XML-Parser i386 2.34-6.1.2.2.1 dev-rhel5-key-approved-i386 209 k
perl-XML-Simple noarch 2.14-4.fc6 dev-rhel5-key-approved-i386 68 k
perl-libwww-perl noarch 5.805-1.1.1 dev-rhel5-key-approved-i386 376 k
perl-rrdtool i386 1.4.7-1.el5.rf rpmforge 52 k
php i386 5.1.6-32.el5 dev-rhel5-key-approved-i386 2.3 M
php-cli i386 5.1.6-32.el5 dev-rhel5-key-approved-i386 2.1 M
php-common i386 5.1.6-32.el5 dev-rhel5-key-approved-i386 153 k
php-devel i386 5.1.6-32.el5 dev-rhel5-key-approved-i386 504 k
php-gd i386 5.1.6-32.el5 dev-rhel5-key-approved-i386 118 k
php-mcrypt i386 5.1.6-5.el5 epel 16 k
php-mssql i386 5.1.6-5.el5 epel 29 k
php-mysql i386 5.1.6-32.el5 dev-rhel5-key-approved-i386 87 k
php-pdo i386 5.1.6-32.el5 dev-rhel5-key-approved-i386 66 k
php-pear noarch 1:1.4.9-8.el5 dev-rhel5-key-approved-i386 344 k
php-pgsql i386 5.1.6-32.el5 dev-rhel5-key-approved-i386 69 k
php-snmp i386 5.1.6-32.el5 dev-rhel5-key-approved-i386 31 k
php-xml i386 5.1.6-32.el5 dev-rhel5-key-approved-i386 97 k
pkgconfig i386 1:0.21-2.el5 dev-rhel5-key-approved-i386 59 k
postgresql i386 8.1.23-1.el5_7.3 dev-rhel5-key-approved-i386 2.9 M
postgresql-devel i386 8.1.23-1.el5_7.3 dev-rhel5-key-approved-i386 1.2 M
postgresql-libs i386 8.1.23-1.el5_7.3 dev-rhel5-key-approved-i386 197 k
postgresql-server i386 8.1.23-1.el5_7.3 dev-rhel5-key-approved-i386 3.8 M
pycairo i386 1.2.0-1.1 dev-rhel5-key-approved-i386 27 k
python-dateutil noarch 1.2-1.el5.rf rpmforge 164 k
python-devel i386 2.4.3-46.el5 dev-rhel5-key-approved-i386 3.0 M
python-lxml i386 2.0.11-1.el5 epel 1.7 M
python-matplotlib i386 0.99.1.2-1.el5 epel 5.8 M
python-nose noarch 0.11.3-2.el5 epel 310 k
python-rrdtool i386 1.4.7-1.el5.rf rpmforge 28 k
python-setuptools noarch 0.6c5-2.el5 dev-rhel5-key-approved-i386 480 k
python-tz noarch 2006p-1.el5.rf rpmforge 667 k
redhat-rpm-config noarch 8.0.45-32.el5 dev-rhel5-key-approved-i386 54 k
rpm-build i386 4.4.2.3-27.el5 dev-rhel5-key-approved-i386 303 k
rpmdevtools noarch 6.8-1.el5 epel 77 k
rrdtool i386 1.4.7-1.el5.rf rpmforge 906 k
ruby i386 1.8.5-24.el5 dev-rhel5-key-approved-i386 277 k
ruby-libs i386 1.8.5-24.el5 dev-rhel5-key-approved-i386 1.6 M
scipy i386 0.6.0-6.el5 epel 4.7 M
shared-mime-info i386 0.19-5.el5 dev-rhel5-key-approved-i386 148 k
startup-notification i386 0.8-4.1 dev-rhel5-key-approved-i386 32 k
suitesparse i386 3.1.0-1.el5 epel 931 k
ttmkfdir i386 3.0.9-23.el5 dev-rhel5-key-approved-i386 46 k
unixODBC-libs i386 2.2.11-10.el5 dev-rhel5-key-approved-i386 551 k
urw-fonts noarch 2.3-6.1.1 dev-rhel5-key-approved-i386 4.5 M
xorg-x11-font-utils i386 1:7.1-3 dev-rhel5-key-approved-i386 76 k
xorg-x11-fonts-Type1 noarch 7.1-2.1.el5 dev-rhel5-key-approved-i386 1.5 M
xorg-x11-proto-devel i386 7.1-13.el5 dev-rhel5-key-approved-i386 247 k
xorg-x11-xfs i386 1:1.0.2-5.el5_6.1
xz i386 4.999.9-0.3.beta.20091007git.el5
dev-rhel5-key-approved-i386 146 k
xz-libs i386 4.999.9-0.3.beta.20091007git.el5
dev-rhel5-key-approved-i386 100 k
zlib-devel i386 1.2.3-4.el5 dev-rhel5-key-approved-i386 102 k
Transaction Summary
Install 163 Package(s)
Upgrade 0 Package(s)
Total size: 129 M
Total download size: 129 M
Downloading Packages:
Total 2.0 MB/s | 129 MB 01:02
Running rpm_check_debug
Running Transaction Test
Finished Transaction Test
Transaction Test Succeeded
Running Transaction
^M Installing : php-common 1/163
^M Installing : postgresql-libs 2/163
^M Installing : libart_lgpl 3/163
^M Installing : postgresql 4/163
^M Installing : php-pdo 5/163
^M Installing : libxslt 6/163
^M Installing : pkgconfig 7/163
^M Installing : gd 8/163
^M Installing : libgfortran 9/163
^M Installing : perl-DBI 10/163
^M Installing : mysql 11/163
^M Installing : libmcrypt 12/163
^M Installing : perl-Socket6 13/163
^M Installing : libglade2 14/163
^M Installing : libgnomecanvas 15/163
^M Installing : blas 16/163
^M Installing : atlas-sse 17/163
^M Installing : gmp 18/163
^M Installing : perl-Digest-SHA1 19/163
^M Installing : gnome-keyring 20/163
^M Installing : libfontenc 21/163
^M Installing : libXfont 22/163
^M Installing : xorg-x11-font-utils 23/163
^M Installing : perl-Net-SSLeay 24/163
^M Installing : apr 25/163
^M Installing : audiofile 26/163
^M Installing : apr-util 27/163
^M Installing : httpd 28/163
^M Installing : suitesparse 29/163
^M Installing : php-mysql 30/163
^M Installing : perl-DBD-MySQL 31/163
^M Installing : mysql-server 32/163
warning: user mysql does not exist - using root
^M Installing : python-lxml 33/163
^M Installing : php-xml 34/163
^M Installing : php-pgsql 35/163
^M Installing : postgresql-server 36/163
^M Installing : postgresql-devel 37/163
^M Installing : php-gd 38/163
^M Installing : libdbi 39/163
^M Installing : cyrus-sasl-devel 40/163
^M Installing : ruby-libs 41/163
^M Installing : ruby 42/163
^M Installing : python-devel 43/163
^M Installing : startup-notification 44/163
^M Installing : perl-Crypt-SSLeay 45/163
^M Installing : elfutils-libs 46/163
^M Installing : elfutils 47/163
^M Installing : libcroco 48/163
^M Installing : libIDL 49/163
^M Installing : ORBit2 50/163
^M Installing : GConf2 51/163
^M Installing : libbonobo 52/163
^M Installing : avahi-glib 53/163
^M Installing : fping 54/163
^M Installing : cpp 55/163
^M Installing : libXaw 56/163
^M Installing : perl-Crypt-DES 57/163
^M Installing : nmap 58/163
^M Installing : lua 59/163
^M Installing : fftw3 60/163
^M Installing : lm_sensors 61/163
^M Installing : net-snmp 62/163
^M Installing : net-snmp-utils 63/163
^M Installing : php-snmp 64/163
^M Installing : perl-Compress-Zlib 65/163
^M Installing : pycairo 66/163
^M Installing : imake 67/163
^M Installing : alsa-lib 68/163
^M Installing : esound 69/163
^M Installing : xz-libs 70/163
^M Installing : xz 71/163
^M Installing : rpm-build 72/163
^M Installing : ttmkfdir 73/163
^M Installing : fakeroot-libs 74/163
^M Installing : fakeroot 75/163
^M Installing : libFS 76/163
^M Installing : libXres 77/163
^M Installing : libwnck 78/163
^M Installing : notification-daemon 79/163
^M Installing : libnotify 80/163
^M Installing : unixODBC-libs 81/163
^M Installing : freetds 82/163
^M Installing : shared-mime-info 83/163
^M Installing : zlib-devel 84/163
^M Installing : freetype-devel 85/163
^M Installing : autoconf 86/163
^M Installing : perl-Digest-HMAC 87/163
^M Installing : perl-Net-SNMP 88/163
^M Installing : automake 89/163
^M Installing : fontconfig-devel 90/163
^M Installing : libpng-devel 91/163
^M Installing : openldap-devel 92/163
^M Installing : perl-IO-Socket-SSL 93/163
^M Installing : perl-Net-SMTP-TLS 94/163
^M Installing : perl-IO-Socket-INET6 95/163
^M Installing : mrtg 96/163
^M Installing : libmcrypt-devel 97/163
^M Installing : e2fsprogs-devel 98/163
^M Installing : perl-Error 99/163
^M Installing : libXau-devel 100/163
^M Installing : dstat 101/163
^M Installing : python-dateutil 102/163
^M Installing : gnome-mime-data 103/163
^M Installing : glibc-headers 104/163
^M Installing : glibc-devel 105/163
^M Installing : redhat-rpm-config 106/163
^M Installing : keyutils-libs-devel 107/163
^M Installing : libjpeg-devel 108/163
^M Installing : python-tz 109/163
^M Installing : expat-devel 110/163
^M Installing : perl-Mail-POP3Client 111/163
^M Installing : python-setuptools 112/163
^M Installing : python-nose 113/163
^M Installing : perl-HTML-Tagset 114/163
^M Installing : libsepol-devel 115/163
^M Installing : libselinux-devel 116/163
^M Installing : libstdc++-devel 117/163
^M Installing : numpy 118/163
^M Installing : gcc 119/163
^M Installing : gcc-c++ 120/163
^M Installing : scipy 121/163
^M Installing : python-matplotlib 122/163
^M Installing : krb5-devel 123/163
^M Installing : perl-HTML-Parser 124/163
^M Installing : perl-libwww-perl 125/163
^M Installing : openssl-devel 126/163
^M Installing : mysql-devel 127/163
^M Installing : rpmdevtools 128/163
^M Installing : perl-XML-Parser 129/163
^M Installing : perl-XML-Simple 130/163
^M Installing : xorg-x11-proto-devel 131/163
^M Installing : libXdmcp-devel 132/163
^M Installing : libX11-devel 133/163
^M Installing : aspell-en 134/163
^M Installing : mesa-libGL-devel 135/163
^M Installing : gnome-vfs2 136/163
^M Installing : libgnome 137/163
^M Installing : chkfontpath 138/163
^M Installing : aspell 139/163
^M Installing : php-cli 140/163
^M Installing : php 141/163
^M Installing : libbonoboui 142/163
^M Installing : gnome-mount 143/163
^M Installing : php-mcrypt 144/163
^M Installing : php-mssql 145/163
^M Installing : libgnomeui 146/163
^M Installing : libgsf 147/163
^M Installing : librsvg2 148/163
^M Installing : libXpm-devel 149/163
^M Installing : xorg-x11-xfs 150/163
^M Installing : gd-devel 151/163
^M Installing : php-devel 152/163
^M Installing : php-pear 153/163
^M Installing : php-pear-HTML-Template-IT 154/163
^M Installing : xorg-x11-fonts-Type1 155/163
^M Installing : urw-fonts 156/163
^M Installing : rrdtool 157/163
^M Installing : ghostscript 158/163
^M Installing : perl-rrdtool 159/163
^M Installing : ghostscript-fonts 160/163
^M Installing : graphviz 161/163
^M Installing : python-rrdtool 162/163
^M Installing : nagiosxi-deps 163/163
Installed:
Dependency Installed:
nmap.i386 2:4.11-2
Complete!
jasweitzer
My unix admin was able to get mysql running after that the install completed.
