check_http "HTTP/1.1 302 Found"
cdienger
Re: check_http "HTTP/1.1 302 Found"
Post by cdienger »
Is it form based authentication? If so, check out the web transaction wizard under Configure > Configuration Wizards. It uses webinject on the backend. You can find examples on using web inject by searching the forums. https://support.nagios.com/forum/viewto ... 16&t=50917 for example. I've also attached a copy of the web inject documentation.
sacom01
Post by sacom01 »
hi cdienger,
i can reach it now.
pls help me close this ticket
thanks for your support
cdienger
Post by cdienger »
Glad to hear!
