[root@vmnagios01 nagiosxi]# ping http://www.cpan.org
PING dualstack.j.sni.global.fastly.net (151.101.2.132) 56(84) bytes of data.
64 bytes from 151.101.2.132 (151.101.2.132): icmp_seq=1 ttl=60 time=1.55 ms
64 bytes from 151.101.2.132 (151.101.2.132): icmp_seq=2 ttl=60 time=1.34 ms
64 bytes from 151.101.2.132 (151.101.2.132): icmp_seq=3 ttl=60 time=1.60 ms
64 bytes from 151.101.2.132 (151.101.2.132): icmp_seq=4 ttl=60 time=1.30 ms
64 bytes from 151.101.2.132 (151.101.2.132): icmp_seq=5 ttl=60 time=1.55 ms
^C
--- dualstack.j.sni.global.fastly.net ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 9ms
rtt min/avg/max/mdev = 1.296/1.466/1.602/0.132 ms
[root@vmnagios01 nagiosxi]# cd /tmp
[root@vmnagios01 tmp]# wget mirror.uic.edu/CPAN/authors/01mailrc.txt.gz
--2021-01-29 11:24:45-- http://mirror.uic.edu/CPAN/authors/01mailrc.txt.gz
Resolving mirror.uic.edu (mirror.uic.edu)... 128.248.156.76
Connecting to mirror.uic.edu (mirror.uic.edu)|128.248.156.76|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://mirror.uic.edu/CPAN/authors/01mailrc.txt.gz [following]
--2021-01-29 11:24:46-- https://mirror.uic.edu/CPAN/authors/01mailrc.txt.gz
Connecting to mirror.uic.edu (mirror.uic.edu)|128.248.156.76|:443... connected.
Length: 261227 (255K) [application/x-gzip]
Saving to: ‘01mailrc.txt.gz’
01mailrc.txt.gz 100%[=================================================================================================================>] 255.10K 294KB/s in 0.9s
2021-01-29 11:24:48 (294 KB/s) - ‘01mailrc.txt.gz’ saved [261227/261227]
Installation of Nagios XI 5.7.4 fails on Rhel8
Re: Installation of Nagios XI 5.7.4 fails on Rhel8
Using root. Can ping as shown below and that wget grabbed the file.
Hi portbris,
I looked on my CentOS 7 and I don't have "/usr/share/perl5/vendor_perl/LWP/UserAgent.pm".
However, I do have "/usr/share/perl5/LWP/UserAgent.pm" from the "perl-libwww-perl-6.05-2.el7.noarch" RPM package.
Can you please run the below command and see what package those two belong to:
Also, can you please run the below command and see when "Class::Accessor" was installed on your system.
Not sure why it said "Class::Accessor::Fast" is empty.
Can you please also run the below command and see anything in the "Class" folder?
Regards,
Vinh
rpm -qf /usr/share/perl5/vendor_perl/Net/HTTP/Methods.pm
rpm -qf /usr/share/perl5/vendor_perl/LWP/UserAgent.pm
perldoc perllocal
ls -l /usr/share/perl5/vendor_perl/Class/*
Regards,
Vinh
This is the reponse to the commands. Thanks
[root@vmnagios01 tmp]# rpm -qf /usr/share/perl5/vendor_perl/Net/HTTP/Methods.pm
perl-Net-HTTP-6.17-2.module+el8.3.0+6498+9eecfe51.noarch
[root@vmnagios01 tmp]# rpm -qf /usr/share/perl5/vendor_perl/LWP/UserAgent.pm
perl-libwww-perl-6.34-1.module+el8.3.0+6498+9eecfe51.noarch
[root@vmnagios01 tmp]# perldoc perllocal
No documentation found for "perllocal".
[root@vmnagios01 tmp]# ls -l /usr/share/perl5/vendor_perl/Class/*
ls: cannot access '/usr/share/perl5/vendor_perl/Class/*': No such file or directory
Hi portbris,
I tested the install on my new empty CentOS 8 and completed fine.
Can you please run the below commands? .... If package already installed, nothing will happens.
Please update results here:
Regards,
Vinh
yum install perl-libwww-perl
yum install perl-ExtUtils-MakeMaker
yum install perl-CPAN
perl -MCPAN -e 'install Test::More'
perl -MCPAN -e 'install Class::Accessor'
Vinh
[root@vmnagios01 tmp]# yum install perl-libwww-perl
Updating Subscription Management repositories.
Last metadata expiration check: 1:24:25 ago on Tue 02 Feb 2021 05:49:54 AEST.
Package perl-libwww-perl-6.34-1.module+el8.3.0+6498+9eecfe51.noarch is already installed.
Dependencies resolved.
Nothing to do.
Complete!
[root@vmnagios01 tmp]# yum install perl-ExtUtils-MakeMaker
Last metadata expiration check: 1:24:29 ago on Tue 02 Feb 2021 05:49:54 AEST.
Package perl-ExtUtils-MakeMaker-1:7.34-1.el8.noarch is already installed.
Nothing to do.
Complete!
[root@vmnagios01 tmp]# yum install perl-CPAN
Last metadata expiration check: 1:24:32 ago on Tue 02 Feb 2021 05:49:54 AEST.
Package perl-CPAN-2.18-397.el8.noarch is already installed.
Nothing to do.
Complete!
[root@vmnagios01 tmp]# perl -MCPAN -e 'install Test::More'
Fetching with LWP:
http://www.cpan.org/authors/01mailrc.txt.gz
read timeout at /usr/share/perl5/vendor_perl/Net/HTTP/Methods.pm line 243. at /usr/share/perl5/vendor_perl/LWP/UserAgent.pm line 982.
[root@vmnagios01 tmp]# perl -MCPAN -e 'install Class::Accessor'
Fetching with LWP:
Nothing to do.
Complete!
Nothing to do.
Complete!
Nothing to do.
Complete!
Fetching with LWP:
Fetching with LWP:
Hi portbris,
Are you using proxy on your XI machine?
If you are using proxy on your XI, then you need to setup CPAN's proxy in order to install CPAN modules.
Looks like all your CPAN install kept having read timeout.
Regards,
Vinh
Regards,
Vinh
I've never configured a proxy on this server. Where do you want me to check?
Hi portbris,
The best and fastest way is to check with your system-admin on your Nagios XI machine.
Ask them if they used Proxy on your Nagios XI machine.
Couple way to check, but not always correct since there are many ways to setup proxy.
From a Linux Nagios XI command prompt, do:
Please upload status or screenshot of the results.
Regards,
Vinh
echo $http_proxy
or
grep -i proxy /etc/environment
or
grep -i proxy /etc/yum.conf
or
ls -l /etc/profile.d/*proxy*
Regards,
Vinh
[root@vmnagios01 tmp]# echo $http_proxy
[root@vmnagios01 tmp]# grep -i proxy /etc/environment
[root@vmnagios01 tmp]# grep -i proxy /etc/yum.conf
[root@vmnagios01 tmp]# ls -l /etc/profile.d/*proxy*
ls: cannot access '/etc/profile.d/*proxy*': No such file or directory
Did you check with your system admin or network team making sure you do not use proxy? .... and your Nagios XI do have internet connection.
Please check with your network and (or) system admin team and see why your install kept timing out.
Something is blocking CPAN from installing those modules.
One more question, is this a new clean VM?
Regards,
Vinh
Regards,
Vinh
