Office 365 Configuration Wizard Broken Text
J.A.K
Re: Office 365 Configuration Wizard Broken Text
Post by J.A.K »
Just wanted to check in any updates on this?
benjaminsmith
Post by benjaminsmith »
Hi @J.A.K,
The developer has found the bug ( there were some characters in the data that broke the decoding of json in php), and is fixing this right now.
The wizards are released as soon as they are finished with development and testing. I don't have an exact date, but I would expect this to be updated within the next week or two.
To check for updates, go to: Admin > System Extensions > Manage Config Wizards and select the Check for Updates button.
Benjamin
J.A.K
Post by J.A.K »
Roger that I have no problem waiting I was just curious if the issue had been discovered or not. Thank you for all the help!
benjaminsmith
Your welcome!
