perl -d:Trace /usr/local/nagios/libexec/check-netapp-ng.pl -H XXXX -C 'XXXX' -T DISKUSED -v '/vol/Atlassian_Test' -t 300Code: Select all
/var/lib/snmp/snmpapp.confCode: Select all
/usr/local/nagios/libexec/check-netapp-ng.pl -H XXXX -C XXXX -V 2c -T DISKUSED -v /vol/Atlassian_TestCan't create SNMP session to X.X.X.X
sub _create_session(@) {
my ($server, $comm, $version, $timeout) = @_;
my ($sess, $err) = Net::SNMP->session( -hostname => $server, -version => $version, -community => $comm, -timeout => $timeout);
if (!defined($sess)) {
print "Can't create SNMP session to $server\n";
exit(1);
return $sess;
}Code: Select all
print "Error: $err\n";
exit(1);
return $sess;
}Code: Select all
/usr/local/nagios/libexec/check-netapp-ng.pl -t 30 -H XXXX -C 'XXXX' -V 2c -T DISKUSED -v /vol/Atlassian_TestCode: Select all
$opt{'version'} = 2;Code: Select all
$opt{'version'} = 2c;Code: Select all
$opt{'version'} = 1;Is everything working as expected now?informatica wrote:This we have run the command with v1, we did like work around.
