lsazzad
Posts: 72 Joined: Tue Apr 07, 2015 6:52 am
Post
by lsazzad » Tue Apr 21, 2015 3:18 am
lmiltchev wrote: What do you see when you run the check from the command line?
/usr/local/nagios/libexec/check_nt -H <IP> -p 12489 -s <password> -v PROCSTATE -d SHOWALL -l lsass.exe,explorer.exe
I am facing same problem. I am receiving email from nagios that (Explorer.exe: not running)!
Please have a look over my output from my nagios::
root@RR-DE-NMS-2:~# /usr/local/nagios/libexec/check_nt -H 172.19.30.227 -p 12489 -s QSECOFRR -v PROCSTATE -d SHOWALL -l lsass.exe,explorer.exe
lsass.exe: Running, explorer.exe: Running
Please note that i am using Nsclient++ in one of my Desktop with windows 8.1. Actually i testing now. If it goes ok then i will go though all of live windows servers.
Regards
Sazzad
Posts: 5126 Joined: Sun Feb 07, 2010 10:55 pm
Post
by Box293 » Tue Apr 21, 2015 6:54 pm
Can you please start a new forum thread with your question along with the troubleshooting you have performed so far.
As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new
Privacy Policy .
