Installation Error
BanditBBS
Re: Installation Error
Post by BanditBBS »
I did that and it got past the backend but then failed on the DB step :(
Running 'backend'...
backend step completed OK
Running 'db'...
Redirecting to /bin/systemctl restart mariadb.service
ERROR 1007 (HY000) at line 1: Can't create database 'nagiosna'; database exists
ERROR: could not create database. Invalid root MySQL password?
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
ssax
Dreams In Code
Post by ssax »
Comment (or remove) this entire section from the fullinstall script and run it again:
    prompt_mysqlpass
        echo "CREATE DATABASE nagiosna; "
        echo -n "CREATE USER 'nagiosna'@'localhost' IDENTIFIED BY 'nagiosna'; "
        echo -n "GRANT ALL ON nagiosna.* TO 'nagiosna'@'localhost';"
    } | mysql -u root ${mysqlpass:+"-p$mysqlpass"} ||
    error "could not create database. Invalid root MySQL password?"
    # Create tables and add some fixtures
    mysql -unagiosna -pnagiosna nagiosna < nagiosna.sql
BanditBBS
Post by BanditBBS »
Further...now got this:
wkhtmltopdf step completed OK
Running 'webroot'...
Created symlink /etc/systemd/system/multi-user.target.wants/httpd.service → /usr/lib/systemd/system/httpd.service.
webroot step completed OK
Running 'daemons'...
Created symlink /etc/systemd/system/mysql.service → /usr/lib/systemd/system/mariadb.service.
Created symlink /etc/systemd/system/mysqld.service → /usr/lib/systemd/system/mariadb.service.
Created symlink /etc/systemd/system/multi-user.target.wants/mariadb.service → /usr/lib/systemd/system/mariadb.service.
Synchronizing state of nagiosna.service with SysV service script with /usr/lib/systemd/systemd-sysv-install.
Executing: /usr/lib/systemd/systemd-sysv-install enable nagiosna
Created symlink /etc/systemd/system/multi-user.target.wants/nagiosna.service → /usr/lib/systemd/system/nagiosna.service.
Job for nagiosna.service failed because the control process exited with error code.
See "systemctl status nagiosna.service" and "journalctl -xe" for details.
INSTALLATION ERROR!
in your communications with Nagios Enterprises technical support.
The step that failed was: 'daemons'
Checked the status, looks like some of the DB stuff is missing!
[root@cms-365-nna01 nagiosna]# systemctl status nagiosna.service
● nagiosna.service - NagiosNA Daemon
   Loaded: loaded (/usr/lib/systemd/system/nagiosna.service; enabled; vendor preset: disabled)
   Active: failed (Result: exit-code) since Wed 2021-03-10 17:57:32 PST; 2min 13s ago
  Process: 89326 ExecStart=/etc/rc.d/init.d/nagiosna start (code=exited, status=1/FAILURE)
Mar 10 17:57:31 cms-365-nna01.itciss.com systemd[1]: Starting NagiosNA Daemon...
Mar 10 17:57:32 cms-365-nna01.itciss.com nagiosna[89326]: Error connecting to the database. (1146, "Table 'nagiosna.nagiosna_Sources' doesn't exist")
Mar 10 17:57:32 cms-365-nna01.itciss.com systemd[1]: nagiosna.service: Control process exited, code=exited status=1
Mar 10 17:57:32 cms-365-nna01.itciss.com systemd[1]: nagiosna.service: Failed with result 'exit-code'.
Mar 10 17:57:32 cms-365-nna01.itciss.com systemd[1]: Failed to start NagiosNA Daemon.
dchurch
Post by dchurch »
Please execute the following to re-create your database:
mysqldump -nt -unagiosna -pnagiosna nagiosna > /tmp/nagiosna-data.sql
mysql -unagiosna -pnagiosna nagiosna < /tmp/nagiosna-data.sql
Then try restarting nagiosna.
BanditBBS
Post by BanditBBS »
Woot! That fixed it, guess I'll follow the exact same steps for the one I am building in the other datacenter and then make sure everything works and place the order :)
BanditBBS wrote:Woot! That fixed it, guess I'll follow the exact same steps for the one I am building in the other datacenter and then make sure everything works and place the order :)
Great!
Locking thread
