Update NagiosXi to 2011R3.1
albibalu
Re: Update NagiosXi to 2011R3.1
Post by albibalu »
Sorry, but no change. All the same can not see new created Hosts in NagiosXi in NagiosXi views and still i can not delete Hosts in NagiosXi. When i delete the host in NagiosXi Core config and also on root level in the directory the host is still in the view of NagiosXi.
Being this started with 3.1, I think it is related to this issue, run the following procedure
http://support.nagios.com/wiki/index.ph ... 3.x_Issues
albibalu
Post by albibalu »
This Wiki i try before with no change. :(
Please run the following on the XI server
sysctl -p
Of this doesn't fix it you may need to reboot the machine.
albibalu
Post by albibalu »
All this i did already and even rebooting the machine was in my agenda, but nothing of this helped to resolve this problem.
and it will be quite a monster work to setup the machine new with more than 500 host and and and......
H E L P ...........
mguthrie
Post by mguthrie »
Can you show us the output from:
sysctl -A | grep kernel.msg
albibalu
Post by albibalu »
The result of the command : sysctl -A | grep kernel.msg
kernel.msgmnb = 131072000
kernel.msgmni = 16
kernel.msgmax = 131072000
Out of curiosity, have you offloaded your MySQL server?
albibalu
Post by albibalu »
no Changes done on any config, only updated to 2011R3.1 (BTW what you mean with offloading MYSQL Server)
By offloading MySQL, I am asking if you specifically moved MySQL off your XI server
