PHP-fpm is designed to spawn a few PHP processes that live a while, handle multiple requests, and then are reaped (or aren't) when a certain amount of idle time has passed or a certain number of requests has been processed.
Basically this means any one request isn't responsible for causing the memory ballooning. It could be anything, really. I'd only really be concerned if it's still happening.
constant increase in memory usage
Re: constant increase in memory usage
what we see is that at a certain moment, there are like 3 or 4 php-fpm processes using > 15% memory this is approx 2.5GB.
When we restart the apache and php-fpm, they will just come back, even when we just reboot the server, these memory consuming processes come back within secconds.
Only when we remove all the session files which are in /var/lib/php/sessions, and reboot the server these large consuming processes will not come back, at least for a while.
In these session files we can see which user is using which file.
however when we look in debug the php-fpm processes, we see that each process is using multiple session files
can we from the session file find out what happens so it is filling up the memory in the php-fpm processes?
for instance:
for instance:
$ ps aux |grep -i php-fpm
root 1390 0.0 0.0 525328 1296 ? Ss Apr01 0:50 php-fpm: master process (/etc/php-fpm.conf)
apache 2153 1.0 0.3 560824 51356 ? S 09:03 0:19 php-fpm: pool www
apache 2347 3.2 15.7 3065216 2555376 ? S 09:03 1:01 php-fpm: pool www
apache 4404 1.0 0.3 646744 55392 ? S 09:05 0:19 php-fpm: pool www
apache 8348 1.1 0.3 558328 49660 ? S 09:06 0:20 php-fpm: pool www
apache 8350 1.2 0.3 558020 49040 ? S 09:06 0:22 php-fpm: pool www
apache 8352 1.2 0.2 556964 46960 ? S 09:06 0:21 php-fpm: pool www
apache 8358 1.0 0.3 559276 49640 ? S 09:06 0:17 php-fpm: pool www
apache 13924 3.4 15.7 3070032 2560148 ? S 09:10 0:51 php-fpm: pool www
apache 15127 0.9 0.2 551312 42604 ? S 09:11 0:14 php-fpm: pool www
apache 23926 1.0 0.3 566868 56384 ? S 09:18 0:10 php-fpm: pool www
apache 23930 0.9 0.3 559108 49276 ? S 09:18 0:09 php-fpm: pool www
root 44581 0.0 0.0 112816 984 pts/1 S+ 09:34 0:00 grep --color=auto -i php-fpm
apache 244490 1.3 0.3 562116 52760 ? S 09:01 0:28 php-fpm: pool www
apache 244540 1.1 0.3 566596 58064 ? S 09:01 0:23 php-fpm: pool www
apache 245616 3.0 15.7 3072524 2562648 ? S 09:02 0:59 php-fpm: pool www
/var/lib/php/session]$ ls -l
total 6652
-rw------- 1 apache apache 21 Apr 7 12:12 sess_079foaqrupam4u593p32nnhruc
-rw------- 1 apache apache 1139 Apr 7 12:12 sess_1uevltbl5u4ofu6q872d8489e1
-rw------- 1 apache apache 21 Apr 7 12:04 sess_298avq2du4se1pj77s7b6kd4gu
-rw------- 1 apache apache 287684 Apr 7 12:12 sess_3bpi4fpt4gc3mdnt5eurcji6eo
-rw------- 1 apache apache 21 Apr 7 12:12 sess_3l4k7kevtv6n2ld6uhl383dpv1
-rw------- 1 apache apache 21 Apr 7 12:03 sess_3lvfpam5bom12ne1ro660jsqpp
-rw------- 1 apache apache 167849 Apr 7 12:12 sess_5291l38gcuosluj3blbhtbpe7c
-rw------- 1 apache apache 144904 Apr 7 12:11 sess_5d5fs7k9p7rtt4psh86bnp1lj0
-rw------- 1 apache apache 677 Apr 7 12:12 sess_5q5n2ujv56hesbe0hef16i2ids
-rw------- 1 apache apache 21 Apr 7 10:47 sess_714sgqudkm6ui1qivjuk46ofuq
-rw------- 1 apache apache 47802 Apr 7 12:12 sess_7he7b57iavqtk58gv73fbk9f9o
-rw------- 1 apache apache 47802 Apr 7 12:12 sess_85hfogs646htgrhp630nokj2d6
-rw------- 1 apache apache 2707 Apr 7 12:12 sess_8osjssj3nvsre9uqq4r1hbknhm
-rw------- 1 apache apache 859 Apr 7 11:27 sess_96vbhlis5bls6vu8r72qrj3qb0
-rw------- 1 apache apache 860 Apr 7 11:10 sess_99p24ego5rekeoqpdi8i910723
-rw------- 1 apache apache 21 Apr 7 12:12 sess_ahsp3cht0vuidd1lp7i0o0ehbb
-rw------- 1 apache apache 475346 Apr 7 12:12 sess_bftialsdql0nr8ikoicm5afb4c
-rw------- 1 apache apache 21 Apr 7 12:12 sess_bt7q337djv7vviqtlfa55vaj4n
-rw------- 1 apache apache 21 Apr 7 12:12 sess_c3rpqpm5t2stjnsrm4uj3e6vu5
-rw------- 1 apache apache 21 Apr 7 12:12 sess_c8sl67dcbcvfvvcd3u3vtihfiv
-rw------- 1 apache apache 551462 Apr 7 12:12 sess_cucvuipojbeiei2s125k8sooko
-rw------- 1 apache apache 214684 Apr 7 12:12 sess_elqgsk710rab2jt1lv1v8cefre
-rw------- 1 apache apache 466851 Apr 7 12:09 sess_erk1di0l3b219jofabslm54i13
-rw------- 1 apache apache 430204 Apr 7 12:11 sess_eutt1u2huh0l6vc9hcpiksj5cp
-rw------- 1 apache apache 21 Apr 7 10:49 sess_hssur9tln1ng2lsmcfpbtqsr41
-rw------- 1 apache apache 466886 Apr 7 12:12 sess_inco5fj4ous25p9gcst48doeve
-rw------- 1 apache apache 21 Apr 7 12:12 sess_j5tolfcnpj9t0uppk16247cpf0
-rw------- 1 apache apache 21 Apr 7 12:12 sess_klnd0ghfa6l9ekna2v0d1plbit
-rw------- 1 apache apache 860 Apr 7 11:26 sess_ko9ls4u5d0811iptkuot5rq1ep
-rw------- 1 apache apache 21 Apr 7 12:12 sess_mbcq2hs32gb5ul8ive2jdf5eua
-rw------- 1 apache apache 316398 Apr 7 11:35 sess_mg7cootti307c7fk4spjm5all6
-rw------- 1 apache apache 120262 Apr 7 12:12 sess_n30hc7bhfpice8ao28cq43rn5v
-rw------- 1 apache apache 466800 Apr 7 10:45 sess_n83bfhp631b40g0u233tth57hj
-rw------- 1 apache apache 21 Apr 7 10:50 sess_n9aa2jjr5qe711ntop0539sppb
-rw------- 1 apache apache 21 Apr 7 12:12 sess_n9q04297tgbohf57mq59in6l65
-rw------- 1 apache apache 21 Apr 7 12:12 sess_ncf18f7v70e0se87mbkebkqli3
-rw------- 1 apache apache 21 Apr 7 12:12 sess_nh4g3vco171ll5nssscorapcbs
-rw------- 1 apache apache 862 Apr 7 12:12 sess_nii4tlebj79n0mgensmv1ib3v1
-rw------- 1 apache apache 167520 Apr 7 11:47 sess_nte4if26d2pqk4aglbcunjgkda
-rw------- 1 apache apache 856 Apr 7 12:12 sess_o1cbj4edjicf6rt4hnjeur4q2s
-rw------- 1 apache apache 427699 Apr 7 12:12 sess_pades6dn567ein1a24dsnsufj3
-rw------- 1 apache apache 174563 Apr 7 12:03 sess_pk58csi5n4home20k6h6v294b7
-rw------- 1 apache apache 21 Apr 7 10:43 sess_q5mlpuu9oajitrs013os40hd6g
-rw------- 1 apache apache 893 Apr 7 12:12 sess_q8qs7q5c6mib0iiv77uo501jot
-rw------- 1 apache apache 519213 Apr 7 12:12 sess_r5d81fq4pjlfvrch6601ulbug2
-rw------- 1 apache apache 242287 Apr 7 12:12 sess_u02q0s67kqsn64t29tbirulk00
-rw------- 1 apache apache 903 Apr 7 12:12 sess_ucr0m6bv7aeh7s66349sin127i
-rw------- 1 apache apache 702086 Apr 7 12:12 sess_ujv9d51u12qn2pktragpgbf7hg
-rw------- 1 apache apache 21 Apr 7 12:12 sess_vplj08esmjm9tg8se474v5da5j
-rw------- 1 apache apache 213008 Apr 7 12:12 sess_vumsnb62rk8v9serjgbqohl2ma
$ less sess_n83bfhp631b40g0u233tth57hj
language|s:5:"en_US";user_id|s:3:"270";username|s:3:"tvn";session_id|i:1358425...... < AND MUCH more data >
Locking this topic since this was started by someone else, and our convo is just sending them email notifications where they're not warranted.
@jweijters, can you please start a new topic, and PM me your profile so I can take a look at your system? Get one by going to Admin (top menu) => System Profile (in the left menu), then clicking the blue button.
If you're unable to generate the the profile through the web interface, please try generating it from the command line by running these commands as root:
Then send me the resulting /usr/local/nagiosxi/var/components/profile.zip file.
If the profile script fails, please include the ENTIRE output.
rm -rf /usr/local/nagiosxi/var/components/profile*
/usr/local/nagiosxi/scripts/components/getprofile.sh SUPPORTIf the profile script fails, please include the ENTIRE output.
