NagiosXI Alerts Will Not Email
rpearson
Re: NagiosXI Alerts Will Not Email
Post by rpearson »
So that test worked...I was testing it by turning the server off and waiting for the message to go...so why wouldn't that be working.
rpearson
Post by rpearson »
Update - tests are only working when I use the Forced option.
benjaminsmith
Post by benjaminsmith »
Hi rpearson,
Making progress, glad to see that's getting through. For the user account that you are using, let's make sure the preferences are not overriding the configurations. Click on the username in the upper right-hand of the screen and select Notification Preferences. Is everything enabled?
Next, let's force a hard down state on a host and collect some log output. Enable phpmailer logging in the Email Settings (Admin > System Config > Email Settings
Run the following tail command and then leave it running.
tail -F /var/log/maillog /usr/local/nagiosxi/tmp/phpmailer.log /usr/local/nagiosxi/var/eventman.log /usr/local/nagios/var/nagios.log
Then go to Home > Details > Host Status:
- Find the Host and click on it
- Click the + tab (Advanced)
- Click the "Submit passive check result" link
- Select the Check Result, choose DOWN and type in some text for the Check Output
- Click the Submit button
Make sure the state type is HARD Down to send the notification, you should see the notification execute in the nagios.log.
Then paste the full output from the tail command into the thread. Thanks, Benjamin
rpearson
Post by rpearson »
Of note I am trying to get emails to go to a Contact and not a normal user - although emails are not going to normal users either. I checked and all of those things were checked. Of note BackupExec was the server I "downed"
login as: rpearson
Pre-authentication banner message from server:
| NOTICE TO USERS
| This system is the property of The Krell Institute and is for authorized
| use only. Use of this system constitutes consent to monitoring. Monitoring
| may be conducted for protection against improper or unauthorized use or
| access, or to perform security audits.
End of banner message from server
rpearson@mon's password:
Linux mon.krellinst.org 4.19.0-13-amd64 #1 SMP Debian 4.19.160-2 (2020-11-28) x86_64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Mon Apr 26 14:10:45 2021 from 10.10.0.136
rpearson@mon:~$ tail -F /var/log/maillog /usr/local/nagiosxi/tmp/phpmailer.log /usr/local/nagiosxi/var/eventman.log /usr/local/nagios/var/nagios.log
tail: cannot open '/var/log/maillog' for reading: No such file or directory
tail: cannot open '/usr/local/nagiosxi/tmp/phpmailer.log' for reading: No such file or directory
==> /usr/local/nagiosxi/var/eventman.log <==
PROCESSED 0 EVENTS
PROCESSED 0 EVENTS
PROCESSED 0 EVENTS
PROCESSED 0 EVENTS
PROCESSED 0 EVENTS
==> /usr/local/nagios/var/nagios.log <==
[1619806428] HOST ALERT: file0;UP;HARD;1;OK - file0.krellinst.org rta 0.215ms lost 0%
[1619806442] HOST ALERT: backupexec;UP;HARD;1;OK - backupexec.krellinst.org rta 0.155ms lost 0%
[1619806487] HOST ALERT: proxy;UP;HARD;1;OK - proxy.krellinst.org rta 0.183ms lost 0%
[1619806515] HOST ALERT: vermont;UP;HARD;1;OK - vermont.krellinst.org rta 0.371ms lost 0%
[1619806517] HOST ALERT: kiddos;UP;HARD;1;OK - kiddos.krellinst.org rta 23.542ms lost 0%
[1619806533] HOST ALERT: jira;UP;HARD;1;OK - jira.krellinst.org rta 0.175ms lost 0%
[1619806556] HOST ALERT: www;UP;HARD;1;OK - www.krellinst.org rta 0.374ms lost 0%
[1619806558] HOST ALERT: wwwstage2;UP;HARD;1;OK - wwwstage2.krellinst.org rta 0.177ms lost 0%
[1619806572] HOST ALERT: www-c;UP;HARD;1;OK - www-cvpn.krellinst.org rta 47.074ms lost 0%
[1619806588] HOST ALERT: repo;UP;HARD;1;OK - repo.krellinst.org rta 0.166ms lost 0%
[1619806607] HOST ALERT: vertigo;UP;HARD;1;OK - vertigo.krellinst.org rta 0.438ms lost 0%
[1619806620] HOST ALERT: wwwstage;UP;HARD;1;OK - wwwstage.krellinst.org rta 0.180ms lost 0%
PROCESSED 0 EVENTS
[1619806624] HOST ALERT: nessus;UP;HARD;1;OK - nessus.krellinst.org rta 0.169ms lost 0%
[1619806628] HOST ALERT: dc3;UP;HARD;1;OK - dc3.krellinst.org rta 0.206ms lost 0%
[1619806640] HOST ALERT: certserver;UP;HARD;1;OK - certserver.krellinst.org rta 0.211ms lost 0%
[1619806648] HOST ALERT: scribe;UP;HARD;1;OK - scribe.krellinst.org rta 0.191ms lost 0%
[1619806660] HOST ALERT: kids;UP;HARD;1;OK - kids.krellinst.org rta 0.165ms lost 0%
[1619806663] HOST ALERT: www3;UP;HARD;1;OK - www3.krellinst.org rta 0.360ms lost 0%
[1619806670] HOST ALERT: backupexec;DOWN;HARD;1;This is a test
PROCESS EVENT: ID=458088, SOURCE=2, TYPE=1, TIME=2021-04-30 13:17:50
*** GLOBAL HANDLER...
Array
[event_id] => 458088
[event_source] => 2
[event_type] => 1
[event_time] => 2021-04-30 13:17:50
[event_meta] => Array
[handler-type] => host
[host] => backupexec
[hostaddress] => backupexec.krellinst.org
[hoststate] => DOWN
[hoststateid] => 1
[lasthoststate] => UP
[lasthoststateid] => 0
[hoststatetype] => HARD
[currentattempt] => 1
[maxattempts] => 5
[hosteventid] => 59178
[hostproblemid] => 27475
[hostoutput] => This is a test
[longhostoutput] =>
[hostdowntime] => 0
[logging_enabled] => 1
*** GLOBAL HANDLER (snmptrapsender)...
Array
[event_source] => 2
[event_type] => 1
[hoststate] => DOWN
[hoststateid] => 1
[maxattempts] => 5
[longhostoutput] =>
[hostdowntime] => 0
SNMP TRAP SENDER NOT CONFIGURED!
[1619806680] HOST ALERT: db0;UP;HARD;1;OK - db0.krellinst.org rta 0.364ms lost 0%
PROCESSED 1 EVENTS
[1619806698] HOST ALERT: db0rep;UP;HARD;1;OK - db0rep.krellinst.org rta 0.383ms lost 0%
[1619806701] HOST ALERT: db0-c;UP;HARD;1;OK - db0-cvpn.krellinst.org rta 50.081ms lost 0%
[1619806714] HOST ALERT: dc4;UP;HARD;1;OK - dc4.krellinst.org rta 0.219ms lost 0%
[1619806726] HOST ALERT: file0;UP;HARD;1;OK - file0.krellinst.org rta 0.199ms lost 0%
[1619806729] HOST ALERT: backupexec;UP;HARD;1;OK - backupexec.krellinst.org rta 0.149ms lost 0%
PROCESS EVENT: ID=458089, SOURCE=2, TYPE=1, TIME=2021-04-30 13:18:49
Array
[event_id] => 458089
[event_source] => 2
[event_type] => 1
[event_time] => 2021-04-30 13:18:49
[hoststate] => UP
[hoststateid] => 0
[lasthoststate] => DOWN
[lasthoststateid] => 1
[maxattempts] => 5
[hosteventid] => 59179
[hostproblemid] => 0
[hostoutput] => OK - backupexec.krellinst.org rta 0.149ms lost 0%
[longhostoutput] =>
[hostdowntime] => 0
Array
[event_source] => 2
[event_type] => 1
[hoststate] => UP
[hoststateid] => 0
[maxattempts] => 5
[longhostoutput] =>
[hostdowntime] => 0
PROCESSED 1 EVENTS
[1619806786] HOST ALERT: proxy;UP;HARD;1;OK - proxy.krellinst.org rta 0.175ms lost 0%
PROCESSED 0 EVENTS
[1619806813] HOST ALERT: vermont;UP;HARD;1;OK - vermont.krellinst.org rta 0.353ms lost 0%
[1619806815] HOST ALERT: kiddos;UP;HARD;1;OK - kiddos.krellinst.org rta 23.532ms lost 0%
[1619806831] HOST ALERT: jira;UP;HARD;1;OK - jira.krellinst.org rta 0.178ms lost 0%
[1619806854] HOST ALERT: www;UP;HARD;1;OK - www.krellinst.org rta 0.350ms lost 0%
[1619806856] HOST ALERT: wwwstage2;UP;HARD;1;OK - wwwstage2.krellinst.org rta 0.163ms lost 0%
PROCESSED 0 EVENTS
benjaminsmith
Hi @rpearson,
For SMTP mail setup, there is another step to configure Contacts to use the SMTP notification handlers. We have setup instructions in the following guide, please follow that to configure this contact.
Configuring Core Contacts to Use Nagios XI PHPMailer SMTP Settings
Also, double check the contact settings on backupexec, I'm not seeing a 'Core" contact assigned to this host object as well nothing in the admins contact group.
define host {
	host_name	backupexec
	alias	backupexec
	address	backupexec.krellinst.org
	parents	sw-server
	check_period	xi_timeperiod_24x7
	check_command	check_xi_host_ping!3000.0!80%!5000.0!100%
	contact_groups	admins
	notification_period	xi_timeperiod_24x7
	initial_state	o
	importance	0
	check_interval	5.000000
	retry_interval	1.000000
	max_check_attempts	5
	active_checks_enabled	1
	passive_checks_enabled	1
	obsess	1
	event_handler_enabled	1
	low_flap_threshold	0.000000
	high_flap_threshold	0.000000
	flap_detection_enabled	1
	flap_detection_options	a
	freshness_threshold	0
	check_freshness	0
	notification_options	d,u
	notifications_enabled	1
	notification_interval	60.000000
	first_notification_delay	3.000000
	stalking_options	u
	process_perf_data	1
	retain_status_information	1
	retain_nonstatus_information	1
	_XIWIZARD	ncpa
# The Admins contact group.
	define contactgroup {
	contactgroup_name	admins
	alias	Nagios Administrators
Please try to configure the Contact required to use the notification handlers in the guide, add this person as a contact to backupexec, and then run the notification tests once more and let me know if the issue is resolved.
Best Regards,
Benjamin
rpearson
Post by rpearson »
Still no luck. The email goes to IT_TXT and IT Notify if I use the "Forced" option. Without it no emails. What would it cost me to just get an actual support session. I feel like this probably would be resolved rather quickly with a screen share. Otherwise do you have any more ideas? I have redone my profile and will PM it to you. I really need to get this resolved quickly.
benjaminsmith
The configurations look good, and since you are receiving notifications when you force a HARD down, that means it's working from our tests, so it's not an issue with the mail server or email settings.
During normal operations, are you sure the host is down and notifying? From the reporting menu, can you run a State History report on the host object to determine when it went HARD down, and then compare this with the Notification Report, over the same period of time.
Additionally, if it did go down without sending the proper notification, I'd like to review the nagios log from that day, they are located in the following directory.
/usr/local/nagios/var/archives
The logs are archived once a day, so if it says 5-2-2021, the data in the log would be from 5-1-2021.
Benjamin
rpearson
Post by rpearson »
It is not emailing when it is a HARD down. It only emails when I click the "Force" check box. The machine definitely goes down I wait longer then necessary and our Nagios Core install on a separate server is alerting to the down. I will look into the logs and upload them later tonight.
rpearson
Post by rpearson »
PM'd you the last few days of logs.
benjaminsmith
Hi @rpearson,
Thanks for sending over the logs files. I search through all the files that particular hosts and all the notifications on that host. I'm not seeing any entries in the log results showing the host going down, so that would explain why the notification was not sent.
Additionally, all the corresponding notifications for the host are for a Custom Notification. I've sent the output files back to you in a Private Message so you can review the data.
I would recommend scheduling a State History Report on this host, so we can determine if it goes down, whether the notation was sent or not going forward.
Regards,
Benjamin
