report in excel status host
nmarbue79
Re: report in excel status host
Post by nmarbue79 »
I have tried it and changed the https to http and verified that the username and password is fine and it generates the pdf but when I open it I only see the main nagios login screen
nmarbue79
Post by nmarbue79 »
I am attaching the pdf file so you can see it, you only see the nagios login screen
vtrac
Post by vtrac »
How are you doing?
As I said before, you must change these values (below) inside the script:
hostname="x.x.x.x"
username="nagiosadmin"
password="XXXX"
If you don't give the correct "username" and "password", you will only see that login page until you give the correct username & password.
Please NOTE, we are NOT developer. I asked a team member for help and he provided me with the sample script.
The script is just a sample for you to get started. You must find someone in your team to modify it to your needs as we are tech support NOT allowed to write scripts for customer.
Regards,
Vinh
nmarbue79
Post by nmarbue79 »
It already works for me and I do not get the login screen, I just had to add in the script => curl --noproxy '*'
thank you very much you can close the thread
vtrac
Post by vtrac »
Great!! .... locking thread .... :-)
