check_hpasm results not displaying correctly
JasonMagee
Re: check_hpasm results not displaying correctly
Post by JasonMagee »
Please see attached.
Can you also post the "/etc/php.ini" file? Thank you!
JasonMagee
Here you go.
what web browser are you using? everything looks as it should, and each of the strings ' should be translated by your browser into '
JasonMagee
Wow. I did not even think to try changing browsers. I was currently using IE8. It displayed wrong using that browser but worked fine when I used chrome. I am going to update to IE9 now with hopes that it works with that browser. Thanks for all your help on this issue.
Excellent... Crazy that IE8 was still not displaying HTML correctly...
