Thank you much!
The fact that these files were missing entirely concerns me.
Is simply dropping them in place enough to get those backups running again?
Being that the log file showed that they were being called, but that they weren't running, is there anywhere that this failure would have been logged?
Backup Log?
Re: Backup Log?
You would be fine just placing those files in the directory as all the other required parts have been included in Nagios XI.
Re: Backup Log?
By default the messages are sent to the root users mailbox for these. This is set in the cron file, if you wanted the error messages to go somehwere else you could change the /etc/cron.d/nagiosxi to be something like this:jbennett wrote:Being that the log file showed that they were being called, but that they weren't running, is there anywhere that this failure would have been logged?
# Backup MySQL & PostgreSQL Databases
0 7 * * * root /root/scripts/automysqlbackup > /path/to/your.log 2>&1
0 8 * * * root /root/scripts/autopostgresqlbackup > /path/to/your.log 2>&1
Re: Backup Log?
I just tried to run the backup once more and noticed this at the end:
Previously, my session had disconnected before I could see this.
This answers a lot of questions.
I have a check that is running to monitor the /store/backups/nagiosxi directory for the latest file and make sure it's over a certain size as well as no older than a certain number of hours.
Since I apparently have to move away from this backup script and to the standard scripts, is there any documentation on these? I want to monitor the backups to make sure they are at least being generated every so often and are above a certain size. This was what alerted me to this issue in the first place, so I view it as invaluable at this point.
A) is there anything out there already for checking this?
B) if I were to modify my current check, am I correct in assuming that these are the folders I would need to monitor? Am I missing anything here?
zip error: Entry too big to split, read, or write (file exceeds Zip's 4GB uncompressed size limit)
- /store/backups/mysql/daily
- information_schema
- mysql
- nagios
- nagiosql
- test
- /store/backups/mysql/weekly
- mysql
- nagios
- nagiosql
- test
- /store/backups/mysql/monthly
- mysql
- nagios
- nagiosql
- test
Re: Backup Log?
I am attaching 2 files that have been modified to use tarball instead of zip.
The files in the attachment can be placed in /usr/local/nagiosxi/scripts
These will be in future versions of XI but did not make it into 2011R3.2 (released today). If you upgrade after replacing the files you will need to re-replace them after the upgrade to 2011R3.2.
Re: Backup Log?
Thanks!
So, these files will allow the back-up that was running before to run again and be over 4GB in size, correct?
I appreciate it!
I appreciate it!
Re: Backup Log?
Yes, I just modified the files to use tar.gz instead of zip, there should be no limit
Re: Backup Log?
I'm happy to report that my backups ran great all weekend. Thanks again for the help.
Re: Backup Log?
Perfect. We will be making the change from .zip to tar.gz permanent in future releases.
