[root@gmslybf5backup ~]# ldd --version
ldd (GNU libc) 2.17
Copyright (C) 2012 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Written by Roland McGrath and Ulrich Drepper.
[root@gmslybf5backup ~]# rpm -qa | grep glibc
glibc-2.17-307.el7.1.x86_64
glibc-common-2.17-307.el7.1.x86_64
[root@gmslybf5backup ~]# rpm -qa | grep ncpa
ncpa-2.3.1-1.el8.x86_64
[root@gmslybf5backup ~]# rpm -ql ncpa
/etc/init.d/ncpa_listener
/etc/init.d/ncpa_passive
/usr/local/ncpa
/usr/local/ncpa/_bisect.so
/usr/local/ncpa/_cffi_backend.so
/usr/local/ncpa/_codecs_cn.so
/usr/local/ncpa/_codecs_hk.so
/usr/local/ncpa/_codecs_iso2022.so
/usr/local/ncpa/_codecs_jp.so
/usr/local/ncpa/_codecs_kr.so
/usr/local/ncpa/_codecs_tw.so
/usr/local/ncpa/_collections.so
/usr/local/ncpa/_ctypes.so
/usr/local/ncpa/_functools.so
/usr/local/ncpa/_hashlib.so
/usr/local/ncpa/_heapq.so
/usr/local/ncpa/_io.so
/usr/local/ncpa/_json.so
/usr/local/ncpa/_locale.so
/usr/local/ncpa/_multibytecodec.so
/usr/local/ncpa/_multiprocessing.so
/usr/local/ncpa/_random.so
/usr/local/ncpa/_socket.so
/usr/local/ncpa/_sqlite3.so
/usr/local/ncpa/_ssl.so
/usr/local/ncpa/_struct.so
/usr/local/ncpa/array.so
/usr/local/ncpa/binascii.so
/usr/local/ncpa/build_resources
/usr/local/ncpa/build_resources/LicenseAgreement.txt
/usr/local/ncpa/build_resources/listener_init
/usr/local/ncpa/build_resources/macosinstall.sh
/usr/local/ncpa/build_resources/macosuninstall.sh
/usr/local/ncpa/build_resources/ncpa_listener.plist
/usr/local/ncpa/build_resources/ncpa_passive.plist
/usr/local/ncpa/build_resources/passive_init
/usr/local/ncpa/cPickle.so
/usr/local/ncpa/cStringIO.so
/usr/local/ncpa/cryptography.hazmat.bindings._openssl.so
/usr/local/ncpa/datetime.so
/usr/local/ncpa/etc
/usr/local/ncpa/etc/ncpa.cfg
/usr/local/ncpa/etc/ncpa.cfg.d
/usr/local/ncpa/etc/ncpa.cfg.d/README.txt
/usr/local/ncpa/etc/ncpa.cfg.d/example.cfg
/usr/local/ncpa/etc/ncpa.cfg.sample
/usr/local/ncpa/fcntl.so
/usr/local/ncpa/gevent._semaphore.so
/usr/local/ncpa/gevent._socket3.py
/usr/local/ncpa/gevent.ares.so
/usr/local/ncpa/gevent.libev._corecffi.so
/usr/local/ncpa/gevent.libev.corecext.so
/usr/local/ncpa/greenlet._greenlet.so
/usr/local/ncpa/grp.so
/usr/local/ncpa/itertools.so
/usr/local/ncpa/jinja2.asyncsupport.py
/usr/local/ncpa/libcrypto.so.1.1
/usr/local/ncpa/libffi.so.6
/usr/local/ncpa/library.zip
/usr/local/ncpa/libssl.so.1.1
/usr/local/ncpa/listener
/usr/local/ncpa/listener/static
/usr/local/ncpa/listener/static/css
/usr/local/ncpa/listener/static/css/bootstrap.min.css
/usr/local/ncpa/listener/static/css/ea.min.css
/usr/local/ncpa/listener/static/css/font-awesome.min.css
/usr/local/ncpa/listener/static/css/ncpa-graph.css
/usr/local/ncpa/listener/static/css/ncpa.css
/usr/local/ncpa/listener/static/css/sumoselect.css
/usr/local/ncpa/listener/static/fonts
/usr/local/ncpa/listener/static/fonts/FontAwesome.otf
/usr/local/ncpa/listener/static/fonts/fontawesome-webfont.eot
/usr/local/ncpa/listener/static/fonts/fontawesome-webfont.svg
/usr/local/ncpa/listener/static/fonts/fontawesome-webfont.ttf
/usr/local/ncpa/listener/static/fonts/fontawesome-webfont.woff
/usr/local/ncpa/listener/static/fonts/fontawesome-webfont.woff2
/usr/local/ncpa/listener/static/help
/usr/local/ncpa/listener/static/help/active.html
/usr/local/ncpa/listener/static/help/api.html
/usr/local/ncpa/listener/static/help/configuration.html
/usr/local/ncpa/listener/static/help/graphs.html
/usr/local/ncpa/listener/static/help/index.html
/usr/local/ncpa/listener/static/help/other.html
/usr/local/ncpa/listener/static/help/passive.html
/usr/local/ncpa/listener/static/img
/usr/local/ncpa/listener/static/img/critical.png
/usr/local/ncpa/listener/static/img/footer_lodyas.png
/usr/local/ncpa/listener/static/img/glyphicons-halflings-white.png
/usr/local/ncpa/listener/static/img/glyphicons-halflings.png
/usr/local/ncpa/listener/static/img/ncpa.png
/usr/local/ncpa/listener/static/img/shattered.png
/usr/local/ncpa/listener/static/img/warning.png
/usr/local/ncpa/listener/static/js
/usr/local/ncpa/listener/static/js/bootstrap.min.js
/usr/local/ncpa/listener/static/js/d3.v5.min.js
/usr/local/ncpa/listener/static/js/help.js
/usr/local/ncpa/listener/static/js/jquery.3.5.1.min.js
/usr/local/ncpa/listener/static/js/jquery.ea.1.3.5.min.js
/usr/local/ncpa/listener/static/js/jquery.ss.3.0.2.min.js
/usr/local/ncpa/listener/static/js/main.js
/usr/local/ncpa/listener/static/js/smoothie.js
/usr/local/ncpa/listener/templates
/usr/local/ncpa/listener/templates/admin
/usr/local/ncpa/listener/templates/admin/api.html
/usr/local/ncpa/listener/templates/admin/checks.html
/usr/local/ncpa/listener/templates/admin/global.html
/usr/local/ncpa/listener/templates/admin/index.html
/usr/local/ncpa/listener/templates/admin/kafkaproducer.html
/usr/local/ncpa/listener/templates/admin/listener.html
/usr/local/ncpa/listener/templates/admin/login.html
/usr/local/ncpa/listener/templates/admin/nrdp.html
/usr/local/ncpa/listener/templates/admin/nrds.html
/usr/local/ncpa/listener/templates/admin/passive.html
/usr/local/ncpa/listener/templates/admin/plugins.html
/usr/local/ncpa/listener/templates/base.html
/usr/local/ncpa/listener/templates/errors
/usr/local/ncpa/listener/templates/errors/404.html
/usr/local/ncpa/listener/templates/errors/500.html
/usr/local/ncpa/listener/templates/graph.html
/usr/local/ncpa/listener/templates/gui
/usr/local/ncpa/listener/templates/gui/api.html
/usr/local/ncpa/listener/templates/gui/checks.html
/usr/local/ncpa/listener/templates/gui/dashboard.html
/usr/local/ncpa/listener/templates/gui/graphs.html
/usr/local/ncpa/listener/templates/gui/help.html
/usr/local/ncpa/listener/templates/gui/plugins.html
/usr/local/ncpa/listener/templates/gui/stats.html
/usr/local/ncpa/listener/templates/gui/tail.html
/usr/local/ncpa/listener/templates/gui/top.html
/usr/local/ncpa/listener/templates/login.html
/usr/local/ncpa/listener/templates/tail.html
/usr/local/ncpa/listener/templates/top.html
/usr/local/ncpa/markupsafe._speedups.so
/usr/local/ncpa/math.so
/usr/local/ncpa/mmap.so
/usr/local/ncpa/ncpa_listener
/usr/local/ncpa/ncpa_passive
/usr/local/ncpa/operator.so
/usr/local/ncpa/plugins
/usr/local/ncpa/plugins/.keep
/usr/local/ncpa/psutil._psutil_linux.so
/usr/local/ncpa/psutil._psutil_posix.so
/usr/local/ncpa/pyexpat.so
/usr/local/ncpa/resource.so
/usr/local/ncpa/select.so
/usr/local/ncpa/strop.so
/usr/local/ncpa/termios.so
/usr/local/ncpa/time.so
/usr/local/ncpa/unicodedata.so
/usr/local/ncpa/var
/usr/local/ncpa/var/log
/usr/local/ncpa/var/log/ncpa_listener.log
/usr/local/ncpa/var/log/ncpa_passive.log
/usr/local/ncpa/var/run
/usr/local/ncpa/zlib.so
[root@gmslybf5backup ~]# systemctl status ncpa_listerner
Unit ncpa_listerner.service could not be found.
[root@gmslybf5backup ~]# systemctl restart ncpa_listener
[root@gmslybf5backup ~]# tail -n30 /usr/local/ncpa/var/log/ncpa_listener.log
NCPA Installtion on Centos7
sneha.irali
Re: NCPA Installtion on Centos7
attaching the ncpa.cfg file.
Please review all the o/p and let us know how do we proceed further ASAP.
Hope you are having a good day!! ...
I have attached the latest NCPA rpm package, let try remove your current NCPA package and re-install again.
As "root", please run the below command on your NCPA agent machine:
Please answer "y" when prompted.
Now, please download the "NCPA.tar" file and put that on "/tmp" of your NCPA agent machine.
Please remember to copy it as "binary" package.
Please run the below command on the NCPA agent machine:
Please anwer "y" when prompted.
Now, please follow the below KB for setting up your NCPA agent:
https://assets.nagios.com/downloads/ncp ... g-NCPA.pdf
Please run the below command to check status of ncpa_listener:
Best Regards,
Vinh
yum erase ncpa
cd /tmp
tar -xvf NCPA.tar
yum localinstall ./ncpa-latest.el7.x86_64.rpm
Best Regards,
Vinh
sneha.irali
Thanks for provideing the installer and the steps.
It did install appropriately, additionally we had to add the firewall rules as below, then the communication was also fixed.
firewall-cmd --zone=public --add-port=5693/tcp
firewall-cmd --zone=public --add-port=5693/tcp --permanent
Great!! .... glad that NCPA is working ...
May I close this thread?
Best Regards,
Vinh
Best Regards,
Vinh
Great!! ... locking thread ...
