Hello ssax,
NOTE - lstpui.local is not real hostname. you can find the real hostname in attached logfile.
Please find the required details below and logfiles attached PM,
curl -k -L -vvv 'https://lstpui.local:5693/'
bsanjay@nagiosxi:[~]: curl -k -L -vvv 'https://lstpui.local:5693/'
* About to connect() to lstpui.local port 5693 (#0)
* Trying 192.168.11.46...
* Connected to brmswebqeb1.ux.corp.local (192.168.11.46) port 5693 (#0)
* Initializing NSS with certpath: sql:/etc/pki/nssdb
* Operation timed out after 300489 milliseconds with 0 out of 0 bytes received
* Closing connection 0
curl: (28) Operation timed out after 300489 milliseconds with 0 out of 0 bytes received
Do you have any security software installed on the remote system that could be impacting the connection?
NO, security software is not installed on this system
Best Regards,
Sanjay Batkura
check_ncpa timeout after ncpa agent upgrade to version 2.3.1
Re: check_ncpa timeout after ncpa agent upgrade to version 2
Please create a ticket for this and include a link back to this forum thread so we can get a remote session setup:
https://support.nagios.com/tickets/
Thank you!
Thank you!
Helo Ssax,
Please find the link to ticket ,
https://support.nagios.com/tickets/scp/ ... p?id=14917
Best Regards,
bsanjay
Best Regards,
bsanjay
Locking thread, ticket received, we will continue support through the ticket.
Thank you!
Thank you!
