escalation noti send to lv1 and lv2 at the same time
vtrac
Re: escalation noti send to lv1 and lv2 at the same time
Post by vtrac »
Hi Hang,
Here's an example of the "Reports > Notifications" page looks like:
Please share screenshot of that notification report for the escalation period of Lv1, Lv2 and Lv3.
Best Regards,
Vinh
sacom01
Post by sacom01 »
hi Vinh,
Pls find attach file. I have sent you all config related to the service and escalation. Pls help me review.
thanks Vinh.
vtrac
Post by vtrac »
Hi Hang,
Can you use other host to test this?
"localhost" is your Nagios XI machine, right?
If you can not PING localhost, then your Nagios XI is down.
How did you make your "localhost" not ping able? .... since this is your Nagios XI machine, if you are not able to PING localhost, then Nagios XI is not checking.
Based on the picture provided below, notification #1 already send out at "01:43:20" .... did you receive mail at that time?
Best Regards,
Vinh
sacom01
Post by sacom01 »
Based on the picture provided below, notification #1 already send out at "01:43:20" .... did you receive mail at that time? --> no, did not receive this notification for all three level. You can see the picture, 3 levels are same.
How did you make your "localhost" not ping able? .... since this is your Nagios XI machine, if you are not able to PING localhost, then Nagios XI is not checking. --> plugin Ping i write to check range of ips (fixed on code), not include localhost. Just add to localhost for easier manage Vinh.
vtrac
Post by vtrac »
Hi Hang,
How are you doing?
I looked at the "objects.cache" file and noticed this service below, which is why you got the email notification to all three LV1, LV2 and LV3 right away if "ping' service is down.
contacts notify_teams_LV3_alert,notify_teams_LV2_alert,notify_teams_LV1_alert
Based on this settings, when PING check fail at 1st notification, email will be sent out to all notify_teams_LV3_alert, notify_teams_LV2_alert and notify_teams_LV1_alert.
	host_name	localhost
	service_description	check PING server
	check_period	24x7
	check_command	check_PING_tritc!!!!!!!!
	notification_period	24x7
	initial_state	o
	importance	0
	check_interval	2.000000
	retry_interval	2.000000
	max_check_attempts	5
	is_volatile	0
	parallelize_check	1
	active_checks_enabled	1
	passive_checks_enabled	1
	obsess	1
	event_handler_enabled	1
	low_flap_threshold	0.000000
	high_flap_threshold	0.000000
	flap_detection_enabled	1
	flap_detection_options	a
	freshness_threshold	0
	check_freshness	0
	notification_options	c
	notifications_enabled	1
	notification_interval	120.000000
	first_notification_delay	0.000000
	stalking_options	n
	process_perf_data	1
	retain_status_information	1
	retain_nonstatus_information	1
Best Regards,
Vinh
sacom01
Post by sacom01 »
hi Vinh,
Dont understand why you always ask me "how are you doing" :D
i can not specify where is my mistake in the config.
All my configs i was sent you in previous comments. So pls help me review any mistake in there.
Tell me if you need more information.
ssax
Dreams In Code
Post by ssax »
You don't have any escalations setup for check PING server that I can see.
Please edit ALL of your service escalations and change the service from check application process to check PING server or test with the check application process service instead of check PING server. Then apply configuration.
benjaminsmith
Post by benjaminsmith »
HI sacom01,
Vinh is out and I'm assisting on this ticket. I'd like to gather up the nagios log files from the time periods in question to check the notification events in the logs.
Those are in the following directory. The logs are rotated daily and labeled by date, so any logs dated 8-6 would contain the date from 8-5.
/usr/local/nagios/var/archives
I would also like to get the most current phpmailer log. Are all the contacts receiving 3 notifications?
 /usr/local/nagiosxi/tmp/phpmailer.log
Lastly, is an offline system like the other one. We may need to set up a remote if necessary.
Benjamin
sacom01
Post by sacom01 »
hi ben,
"Are all the contacts receiving 3 notifications?" --> yes they are.
our system is offline system so unable to remote to.
i can not find phpmailer.log from here /usr/local/nagiosxi/tmp/phpmailer.log
vtrac
Post by vtrac »
Hi @Sacom01,
I'm very sorry!! ... In our training, we always started out with some kind of greetings ... just to be friendly and nice!!!
I usually used "How are you doing?" or "Hope you have a great day!!".
Any way, as stated in the last replied by Sean, you were testing with a service that did not have any escalation defined.
Looks like you were testing with the below service, which is why you got all three levels of notifications.
   host_name   localhost
   check_period   24x7
   initial_state   o
   importance   0
   is_volatile   0
   parallelize_check   1
   obsess   1
   check_freshness   0
   stalking_options   n
   process_perf_data   1
Best Regards,
Vinh
