Problem Backend:nagiosxi NDO claims Nagios did not update
gaguilard
Re: Problem Backend:nagiosxi NDO claims Nagios did not updat
Post by gaguilard »
Hi ssax:
The problem continue... six or seven times at day...
I am near to be deperated... :)
ssax
Dreams In Code
Post by ssax »
This should be fixed in the upcoming XI 5.8.6 release (it's currently in testing).
You can update it on yours by taking the attached zip file and upload it in Admin > Manage Components:
nagvis.zip
Then as the root user, run this command:
/usr/local/nagiosxi/html/includes/components/nagvis/upgrade.sh
You may need to close your browser windows/clear the browser cache.
Then go into nagvis and see the maps are working, then stop the nagios process:
systemctl stop nagios
Then go back to the nagvis map and it should still show green. Mine didn't immediately but I didn't clear cache/close browser.
Start the nagios service back up after:
systemctl start nagios
