Sounds good - I'll wait to hear from you next week.
Event Handler not executing when alert goes critical.
Re: Event Handler not executing when alert goes critical.
I done the recommended actions and sent you the service profile in a DM. Thank you.
gsmith wrote:HI
OK - I got the serverEBOC template loaded. It is calling out the event handler Everbridge On-Call.
But when I look at the cfg files for:the event_handler is not defined.
- CMOOSCHSTUP7905.pnp.maas_check_bcache.cfg
cmoosincfup7905.pnp.maas.cfg
pnp-CMOOSCHSTUP7905.cfg
Please try this:Then send me another System Profile so I can see if the EventHandler is getting picked up for CMOOSCHSTUP7905.cfgCode: Select all
Choose Configure, Core Config Manager Under Tools in the left-hand menu select Config File Management Hit the "Delete Files" (red) button - it's OK to do this Hit the "Write Configs" (blue) button Optional but informative - hit the "Verify Files" (white button) In the left-hand menu under Quick Tools select Apply Configuration Click the "Apply Configuration" (blue) buttonThanksCode: Select all
To send us your system profile. 1. Login to the Nagios XI GUI using a web browser. 2. Click the "Admin" > "System Profile" Menu 3. Click the "Download Profile" button 4. Save the profile.zip file and share this in a private message and then reply to this post to bring it up in the queue.
It is working for me, however I modified the serverEBOC host template so that it was
using your "Test" event handler.
Your "Everbridge On-Call" event handler calls out:
/usr/local/integrate/everbridge/onCallEvent.sh
Does that file exist on pnp-CMOOSCHSTUP7905?
Are the owner/group/permissions = -rwxr-xr-x. 1 nagios nagios ?
Turns out the host template was not setup correctly. After fixing it the event handler is working as expected. Please close out this thread.
Best,
Ron
Best,
Ron
