This would work perfectly for us. Where can I find the password to access the mysql tables so I can make this alter? And will this affect support at all?mguthrie wrote:Interesting trick we discovered from this thread. If you're using *only* service->hostgroup assignments in a service definition, you can actually pass exclusions as a free variable and Nagios Core will honor the definition. So if you don't have any inclusive host assignments in a service definition you could add as a free variable:
host_name
!host1,!host2,!host3
You would of course be subject to the VARCHAR limit of that table, but that could easily be remedied with an ALTER TABLE query.
Imported Configuration Truncated?
Re: Imported Configuration Truncated?
Tested and this should get you what you need. If you need more than 1024 go ahead and bump it up larger.
This is such a minor alteration it shouldn't have any adverse effects for the software or support. We'll definitely tell you if it's something that affects support
mysql -pnagiosxi nagiosql
ALTER TABLE tbl_variabledefinition MODIFY COLUMN value varchar(1024);Re: Imported Configuration Truncated?
Glad to be of help! I have this in operation now.. There's more to do, of course, but the config is loaded now.. yay!mguthrie wrote:Interesting trick we discovered from this thread. If you're using *only* service->hostgroup assignments in a service definition, you can actually pass exclusions as a free variable and Nagios Core will honor the definition. So if you don't have any inclusive host assignments in a service definition you could add as a free variable:
host_name
Now on to making our various plugins work...
Thanks for the help!
