Thanks for following up, looks like we will want to loop through things after using the Bulk Mod tool.
CCM > Tools > Bulk Modifications Tool > Remove Contact > Select your contact from the drop-down menu > Find Relationships > Check All (for hosts and services) > Save Changes > Apply Configuration
Then hit up the
Let us know how things look,Core Configuration Manager (CCM) ==> Config File Management ==> [Delete Files] ==> [Write Files] ==> [Verify Files]
*: Core Configuration Manager (CCM) ==> Under Quick Tools ==> "Apply Configuration"
*: Restart nagios.service by terminal command: systemctl restart nagios
verify that the host and services look good and verify that there are no errors in core by:
/usr/local/nagios/bin/nagios -vvv /usr/local/nagios/etc/nagios.cfg
Perry
