Thanks for following up, want to answer your questions and then provide further troubleshooting.
The perfdata does not associate with the database, please see diagram:For instance, where is this performance data stored, once it is received from the plugin?
[*] could it be a database table with some char limit?
PHP issue is not out of the possibility.[*] maybe the html does not allow passing so much data?
Next steps:[*] any idea is really appreciated
- Tail perfdata logging when triggering the service check. Trigger the service check and watch the perfdata log [list]
tail -f /usr/local/nagios/var/perfdata.log
- /usr/local/nagios/etc/pnp/process_perfdata.cfg
Change:
LOG_LEVEL = 0
To:
LOG_LEVEL = 2
The process_perfdata.pl script should now log all errors and debug information to the file /usr/local/nagios/var/perfdata.log which can be watched using this command:
Please follow up with results,
Perry
