ghost alerts
matson-itops
Re: ghost alerts
Post by matson-itops »
[nagios~]$ more /usr/local/nagios/etc/hosts/NagiosXI_Local_Server.cfg
# Hosts configuration file
# Created by: Nagios CCM 3.1.4
# Date: 2021-11-09 11:42:16
# Version: Nagios Core 4.x
# Nagios CCM will overwrite all manual settings during the next update if you
# would like to edit files manually, place them in the 'static' directory or
# import your configs into the CCM by placing them in the 'import' directory.
define host {
host_name NagiosXI_Local_Server
use linux-server
alias NagiosXI_Local_Server
display_name NagiosXI_Local_Server
address 127.0.0.1
register 1
# END OF FILE
gsmith
Re: ghost alerts
Post by gsmith »
HI,
If getting rid of the duplicate host (in your other forum post) solves this
one please let me know and I will lock this one. Then we can get back to
the check_nrpe issue.
matson-itops
Re: ghost alerts
[]$ more NagiosXI_Local_Server.cfg
define host {
use linux-server
address 127.0.0.1
register 1
# END OF FILE
gsmith
Re: ghost alerts
Post by gsmith »
Nice! So do you still have the phantom disk usage service check
hanging around ?
If so please send me a new System Profile.
Thank you!
matson-itops
Re: ghost alerts
still have the ghost checks .
NagiosXI_Local_Server.cfg has not changed since nov 9th
please advise.
matson-itops
Re: ghost alerts
under CCM localhost and NagiosXI_local_Server are both there and they are identical
neither of them has the "ghost disk usage" check.
gsmith
Re: ghost alerts
Post by gsmith »
Hi
My understanding is that localhost and NagiosXI_local_Server
refer to the same machine. Can you delete localhost via CCM
and "Apply Configuration" please?
Let me know the results.
Thanks!
matson-itops
Re: ghost alerts
for some reason this alert was coming from it being in linux_server grouup with a disk check at creation time
we removed it and now it's gone
we stil do have a duplicate, but are aware of it. thank you
we can close this now
