Check for updates using the NCPA agent
Re: Check for updates using the NCPA agent
MONITORME is Linux Ubuntu. This command isnt function
Hello @jakai
Thanks for following up @gsmith is out of the office today. I see that he had you run the telnet command to verify the ability to connect on port 5693. Sounds like you want to go ahead and verify firewall status rules.
Depending on your distro and what it services are enabled we want to first check to see is 'ufw' (Uncomplicated Firewall) is enabled and configured for your distro.
Depending on the results you can configure your firewall with the 'ufw' or use 'iptables' to open/allow port 5693. Both have plenty of online help man's available to refer to.
Please let us know how things are looking,
Perry
ufw statusPlease let us know how things are looking,
Perry
I have open port.
I have open port.
Hello @jakai
Thanks for following up, with the details we see that port 5693 is allowed and that the 'ncpa_listener' and 'ncpa_passive' services are running on the device receiving the connection request. Please make sure that there are no security applications blocking things, like Selinux or Apparamor.
Verify that the services are 'established':
View ports established/listening port for conflicts:
or
Setting the ncpa.cfg to listen for ipv4: (or manually updating /usr/local/ncpa/etc/ncpa.cfg)
Then restarting the 'ncpa_listener':
Verify that you are able to connect:
The example results should look like:
Perry
ss -p | grep -Ei 'ncpa|5693'Code: Select all
netstat -an | grep -E '5693'Code: Select all
ss -atCode: Select all
sed -i 's/#ip = 0.0.0.0/ip = 0.0.0.0/g' /usr/local/ncpa/etc/ncpa.cfgCode: Select all
systemctl restart ncpa_listenerOr take a look at the route:where XXX.XXX.XX.XXX is the IP of the machine you are trying to monitorCode: Select all
curl -v telnet://XXX.XXX.XX.XXX:5693
If it comes back with:then that means we have connectivity. Use ctrl-c to exit out of the curl command.[root@gs-rhel8-23-84 audit]# curl -v telnet://192.168.23.81:5693
* Rebuilt URL to: telnet://192.168.23.81:5693/
* Trying 192.168.23.81...
* TCP_NODELAY set
* Connected to 192.168.23.81 (192.168.23.81) port 5693 (#0)
traceroute xxx.xxx.xxx.xxx -p 5693Please let us know how things are looking,traceroute to xxx.xxx.xxx.xxx (xxx.xxx.xxx.xxx), 30 hops max, 60 byte packets
1 xxx.xxx.xxx.xxx (xxx.xxx.xxx.xxx) 0.216 ms 0.197 ms 0.179 ms
Perry
I did everything according to your procedure. Unfortunately, the problem still persists.
Hello @jakai
Thanks for following up with the screenshot, it appears that it is listening for ipv6 address and not a ipv4 address. Let's verify what address your server is associated with to make sure that you are not using a ipv6 internal address.
or
In the previous message I had you set the ncpa config to listen to ipv4 address:
The result will look something like this: (red is the line of interest)
Perry
ip addressCode: Select all
ifconfigLet's verify that this was updated in the config:setting the ncpa.cfg to listen for ipv4: (or manually updating /usr/local/ncpa/etc/ncpa.cfg)Code: Select all
cat /usr/local/ncpa/etc/ncpa.cfg | grep 'ip ='Please make the necessary adjustments if needed then restart the service:# Default: ip = ::
# Default (Windows): ip = 0.0.0.0
ip = 0.0.0.0
systemctl restart ncpa_listenerPerry
I did as you write. The problem still persists.
Hello @jakai
Looks like the screenshot may have cut off some, it should not have a "#" in front of the ip = 0.0.0.0
Please verify and make the necessary updates if needed and then restart the ncpa_listener.
Perry
cat /usr/local/ncpa/etc/ncpa.cfg | grep 'ip ='Thanks,
Perry
I've tried this before. This procedure does not work.
Hello @jakai
Thanks for following up, and circling back want to go ahead and get the config and logs from you on this so we can see what is going on.
Let's verify the version:
Want to get a list:
Please [PM] over the '/tmp/ncpainfo.tar.gz' when you get a chance, we will get this dialed in.
Perry
grep -Eir 'ncpa' /var/log/* > /tmp/ncpatemp.txt && tar -cvf /tmp/ncpainfo.tar.gz /usr/local/ncpa/var/ /usr/local/ncpa/etc/ /tmp/ncpatemp.txtCode: Select all
/usr/local/nagios/libexec/check_ncpa.py -H yourhostaddresshere -VCode: Select all
/usr/local/nagios/libexec/check_ncpa.py -H yourhostaddresshere -t yourtokenhere --list --verboseThanks,
Perry
