you don't have the GD library installed
kfanselow
Re: you don't have the GD library installed
Post by kfanselow »
Hi Tom,
My apologies - this is what happens when time threads get a little thin. The guidance provided was intended for you - it appears that gd-devel is no longer in a number of repos but you should be able to download and use the CentOS rpm if the RHEL version is unavailable.
Thanks and Best Regards,
Keith
MonitorGuy
Post by MonitorGuy »
My Linux Admin wasn't keen using CENTOS, so he did some searching and found a newer version of gd-devel on the redhat repo.
"it was just right there available from Red Hat - you have to make sure your server has this repo ENABLED: rhel-7-server-optional-rpms" <<< Solution
After the "gd-devel" install, the Nagios update completed using the GUI.
Thanks guys!
Craig
<<MonitorGuy>>
tbarnett
Post by tbarnett »
This got me going.
Thanks for the help.
Tom
Tom Barnett
Senior Systems Administrator
Prime, inc.
2740 N. Mayfair Ave
Springfield, MO 65803
kfanselow
Post by kfanselow »
Hi Tom,
Glad to hear it !!!
Thanks Craig for your time and information as well !!!
We'll lock the thread.
Keith
