rrdcached no performance data
wneville
Re: rrdcached no performance data
Post by wneville »
I'm certainly making this harder than it should be, huh? Third times the charm - the profile.zip should be in your inbox
ssax
Dreams In Code
Post by ssax »
Received. Thank you!
It looks like you might be missing your /usr/local/nagios/etc/pnp directory.
What is the output of this command?
ls -l /usr/local/nagios/etc/
What XI version are you running? You can find it on the bottom left hand corner after logging into the web interface (it's missing from your profile).
wneville
Post by wneville »
I am running NagiosXI 5.8.7. The output of
is below:
total 232
drwxrwxr-x 2 apache nagios     6 Dec 14 15:40 cfgprep
-rw-rw-r-- 1 apache nagios  1813 Dec 21 07:46 cgi.cfg
-rw-rw-r-- 1 apache nagios 26959 Dec 21 12:02 commands.cfg
-rw-rw-r-- 1 apache nagios  1084 Dec 21 12:02 contactgroups.cfg
-rw-rw-r-- 1 apache nagios 11285 Dec 21 12:02 contacts.cfg
-rw-rw-r-- 1 apache nagios  1665 Dec 21 12:02 contacttemplates.cfg
-rw-rw-r-- 1 apache nagios   796 Dec 21 12:02 hostdependencies.cfg
-rw-rw-r-- 1 apache nagios   794 Dec 21 12:02 hostescalations.cfg
-rw-rw-r-- 1 apache nagios   786 Dec 21 12:02 hostextinfo.cfg
-rw-rw-r-- 1 apache nagios  2290 Dec 21 12:02 hostgroups.cfg
drwxrwxr-x 2 apache nagios 24576 Dec 21 11:39 hosts
-rw-rw-r-- 1 apache nagios 17095 Dec 21 12:02 hosttemplates.cfg
drwxrwxr-x 2 apache nagios     6 Dec 20 16:05 import
-rw-rw-r-- 1 apache nagios  5867 Dec 21 11:39 nagios.cfg
-rw-rw-r-- 1 apache nagios   684 Nov 22 13:45 ndo.cfg
-rw-rw-r-- 1 apache nagios 12838 Nov 22 13:46 nrpe.cfg
-rw-rw-r-- 1 apache nagios  5345 Nov 22 13:46 nsca.cfg
drwxrwxr-x 4 apache nagios   246 Dec 21 11:39 pnp
-rw-rw-r-- 1 apache nagios     0 Nov 22 13:52 recurringdowntime.cfg
-rw-rw-r-- 1 apache nagios   210 Nov 22 13:44 resource.cfg
-rw-rw-r-- 1 apache nagios  1627 Nov 22 13:46 send_nsca.cfg
-rw-rw-r-- 1 apache nagios   802 Dec 21 12:02 servicedependencies.cfg
-rw-rw-r-- 1 apache nagios   800 Dec 21 12:02 serviceescalations.cfg
-rw-rw-r-- 1 apache nagios   792 Dec 21 12:02 serviceextinfo.cfg
-rw-rw-r-- 1 apache nagios  3443 Dec 21 12:02 servicegroups.cfg
drwxrwxr-x 2 apache nagios  4096 Dec 21 11:39 services
-rw-rw-r-- 1 apache nagios 25803 Dec 21 12:02 servicetemplates.cfg
drwxrwxr-x 2 apache nagios    68 Dec 21 11:39 static
-rw-rw-r-- 1 apache nagios 11406 Dec 21 12:02 timeperiods.cfg
within the pnp folder is the following
total 44
-rw-rw-r-- 1 apache nagios 6952 Nov 22 13:45 background.pdf
drwxrwxr-x 2 apache nagios   37 Dec 21 11:39 check_commands
-rw-rw-r-- 1 apache nagios 3370 Nov 22 13:45 config.php
-rw-rw-r-- 1 apache nagios 3090 Dec 17 12:15 npcd.cfg
-rw-rw-r-- 1 apache nagios 4127 Nov 22 13:45 npcd.cfg-sample
drwxrwxr-x 2 apache nagios   36 Dec 21 11:39 pages
-rw-rw-r-- 1 apache nagios   63 Nov 22 13:45 pnp4nagios_release
-rw-rw-r-- 1 apache nagios  855 Dec 17 12:16 process_perfdata.cfg
-rw-rw-r-- 1 apache nagios  793 Nov 22 13:45 process_perfdata.cfg-sample
-rw-rw-r-- 1 apache nagios  524 Nov 22 13:45 rra.cfg
-rw-rw-r-- 1 apache nagios  524 Nov 22 13:45 rra.cfg-sample
ssax
Dreams In Code
Post by ssax »
Hmm, it must not have extracted properly because I see it in the profile now.
I think this is an EL8 issue, the /etc/sysconfig/rrdcached file options aren't processed . I'm looking into this (likely needs a unit file update) and will post an update shortly.
I would also edit this file:
/usr/local/nagios/etc/pnp/npcd.cfg
Change this:
load_threshold = 10.0
To this:
load_threshold = 60.0
Edit this file:
/usr/local/nagios/etc/pnp/process_perfdata.cfg
Change this:
TIMEOUT = 5
To this:
TIMEOUT = 20
Then restart npcd:
systemctl restart npcd
ssax
Dreams In Code
Post by ssax »
Edit this file:
/usr/lib/systemd/system/rrdcached.service
Change the file to this:
[Unit]
Description=Data caching daemon for rrdtool
Documentation=man:rrdcached(1)
[Service]
Type=forking
EnvironmentFile=/etc/sysconfig/rrdcached
ExecStart=/usr/bin/rrdcached $OPTIONS
[Install]
WantedBy=multi-user.target
Then edit this file:
Change this:
    OPTIONS="-s nagios -m 0660 -l unix:/var/rrdtool/rrdcached/rrdcached.sock -F -w 900 -z 90 -j /var/rrdtool/rrdcached -b /var/rrdtool/rrdcached"
    RRDC_USER=nagios
To this:
    OPTIONS="-U nagios -s nagios -m 0660 -l unix:/var/rrdtool/rrdcached/rrdcached.sock -F -w 900 -z 90 -j /var/rrdtool/rrdcached -b /var/rrdtool/rrdcached"
    RRDC_USER=nagios
Change this:
#RRD_DAEMON_OPTS = unix:/var/rrdtool/rrdcached/rrdcached.sock
To this:
Then run this command, wait 15 minutes, and let us know if any graphs start showing up:
systemctl restart rrdcached npcd
wneville
Post by wneville »
Thanks so much for your thorough response. I have followed those steps and will continue to monitor the perfdata.
I tailed /usr/local/nagios/var/perfdata.log just to see if anything was happening and see this:
2021-12-22 12:54:44 [706458] [0] *** TIMEOUT: Timeout after 20 secs. ***
2021-12-22 12:54:44 [706458] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2021-12-22 12:54:44 [706458] [0] *** TIMEOUT: Please check your npcd.cfg
2021-12-22 12:54:44 [706458] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1640195644.perfdata.service-PID-706458 deleted
FYI - we are seeing high IOwait % and are evaluating our disk options to see if that will help UI speed / perfdata timeouts etc
ssax
Dreams In Code
Post by ssax »
I would probably increase the TIMEOUT to 40 following the steps I sent before.
If you have issues again, PM me a fresh copy of your profile.zip.
wneville
Post by wneville »
After following your most recent instructions and making some changes to address performance issues (opened a ticket with Nagios support) - we have not lost performance data in two days. I can't thank you enough for your help!
ssax
Dreams In Code
Post by ssax »
Thanks for the update, glad to help! Let us know when we're okay to lock this one up and mark it as resolved.
wneville
Post by wneville »
Good with me, thanks again!
