@gsmith , @ssax ,
Any update on this? Thanks!
Enable notifications for specific contact groups
aylesworth
Re: Enable notifications for specific contact groups
Hi
I received the PM showing the example notification, but I never received a PM with
your System Profile. I really need that System Profile so I can take a look at your
groups, notifications, etc.
1. Login to the Nagios XI GUI using a web browser.
2. Click the "Admin" > "System Profile" Menu
3. Click the "Download Profile" button
4. Save the profile.zip file and share the file in a private message and then reply to this post to bring it up in the queue.
aylesworth
Just sent it again, my PM's show that it was sent the first time on 3/10.gsmith wrote:Hi
Thanks!
Hi
I spot checked some hosts, services, contacts and contact groups and they looked fine to me.
If you want to be bulletproof you could backup your Prod system and install it on a Test server.
multiple gmail accounts, or just one and differentiate them by using "+" and "." characters as shown in this article:
https://gmail.googleblog.com/2008/03/2- ... -your.html
It would be a ton of work since you have 49 contacts and 24 contact groups, and you'd have to be cognizant of the fact
that if you add/remove/change contacts on Prod that you would need to do it manually (or via a script) on your test server.
A script would probably be best...updating the email address in the db to use the gmail account mentioned above and
appending "+<username>" to it after you backup Prod and restore to the Test server.
Let me know if this helps you out. We are moving to a new ticketing system so you should probably open an account there
for future inquiries.
If you are satisfied with this answer please let me know so I can those this out.
Thanks!
Then you could simulate all your contacts by changing their emails to a Google email address. You could createNagios XI License Policy
With every purchase we offer 3 separate activation of XI licenses. One for production, one for testing, and one for
high availability. We always recommend upgrading on a test server first before making changes to the production server.
Nagios License Entitlements
https://support.nagios.com/kb/article.php?id=145
Thanks!
We're moving to a new support system!
The Nagios Answer Hub is a place where you can get help with technical questions from our experts. There, you can quickly open tickets and join discussion boards.
Request Nagios Answer Hub access here: https://info.nagios.com/answer-hub-access-new-users
After completing the access form, you will be given access to a portal where new tickets can be created. We will keep the old customer forum sections and ticket system available for current cases to be resolved.
aylesworth
Thanks!
I guess the next question is how do I enable notifications for these groups? Currently everything is turned off except for my account, which I have applied a template to so that it receives all notifications. I just want to make sure that when I enable notifications for those 24 groups that they don't get every single notification and only the ones that they're assigned to receive.
Thanks!
Thanks!
Hi
Go to Configure, Core Config Manager. Hit the blue "Services" box.
Edit one (the wrench icon under Actions) and send me a screenshot of the Check Settings tab and the Alert Settings tab.
Also on the Alert Settings tab open the Manage Contacts and Manage Contact Groups boxes.
Drill down in each and show me the contact and their assigned email address.
Also send me screenshots of the template you set up to limit the notifications (one screenshot for each of its tabs)
aylesworth
Just sent a .zip via PM. Everything looks good for the most part so far as I can tell, everything is set to "skip" as you'll see in the screenshots, like notifications are globally disabled. Additionally, for every notification I'm getting an "UP" notification, even if it contains no other info other than the server is up. I've included the text from one of those below, is there a way to not receive this UP notification every time a problem comes through?gsmith wrote:Hi
***** Nagios XI Alert *****
Nagios has detected a problem with this host.
Notification Type: PROBLEM
Host: XXSERVERNAMEXX
State: UP
Address: X.X.X.201
Info: OK - X.X.X.201 rta 34.816ms lost 0%
Date/Time: 2022-03-31 13:59:38
Respond: http://url
Nagios URL: http://X.X.X.X/nagiosxi/
Hi
Please compare the settings you have for the host that is sending you "up" notifications to the
screen capture I have attached of the host configuration I have set up, since it is not sending out
the "up" notification.
Let me know if this helps.
aylesworth
Hello sorry for the delay I was out of the office, I went over one of my hosts compared to yours and all of the settings are the same. Is it possible that I'm receiving the UP notifications because I have deployed a notification template to my account that contains all alerting options (this is for testing purposes only and will not reflect the normal 24x7 template).
Thanks!
Thanks!
Hi
In your email from Nagios:
When this occurs in a shell on your Nagos XI server:
cd /usr/local/nagiosxi/var
then
vi eventman.log
go to the bottom of the eventman.log and you should see something like:
This will tell you what the problem with the server is.
Let me know what you find.
the Notification Type is PROBLEM.Nagios has detected a problem with this host.
State: UP
Address: X.X.X.201
Respond: http://url
then
vi eventman.log
*** GLOBAL HANDLER (snmptrapsender)...
Array
[event_id] => 928
[event_source] => 2
[event_type] => 1
[event_time] => 2022-04-13 09:35:05
[event_meta] => Array
[handler-type] => service
[host] => localhost
[service] => Memory Usage
[hostaddress] => 127.0.0.1
[hoststate] => UP
[hoststateid] => 0
[hosteventid] => 0
[hostproblemid] => 0
[servicestate] => WARNING
[servicestateid] => 1
[lastservicestate] => WARNING
[lastservicestateid] => 1
[servicestatetype] => HARD
[currentattempt] => 4
[maxattempts] => 4
[serviceeventid] => 169
[serviceproblemid] => 68
[serviceoutput] => WARNING - 6526 / 7768 MB (84%) Free Memory, Used: 1238 MB, Shared: 9 MB, Buffers + Cached: 526 MB
[longserviceoutput] =>
[servicedowntime] => 0
[logging_enabled] => 1
SNMP TRAP SENDER NOT CONFIGURED!
PROCESSED 2 EVENTS
