Thanks for following up, and based on what version you are currently running and the fact that you want to spin this up onto a fresh installed Linux.
An excellent start, let's get this thing migrated over to the same version on the fresh spun-up Linux server:
cd /tmp/Code: Select all
wget https://assets.nagios.com/downloads/nagiosxi/2014/xi-2014r1.1.tar.gzCode: Select all
tar -xvf xi-2014r1.1.tar.gzCode: Select all
cd /tmp/nagiosxiCode: Select all
./fullinstall
I realize from your follow-up that you did not want "box" answers, but going forward recommend following the migration template that we previously sent.
No worry's though if you find that there is something wonky on the migration we are a short [submit] button away to help resolve any issues that pop-up.
Perry
p.s.
We're moving to a new support system!
The Nagios Answer Hub is a place where you can get help with technical questions from our experts. There, you can quickly open tickets and join discussion boards.
Request Nagios Answer Hub access here: https://info.nagios.com/answer-hub-access-new-users
After completing the access form, you will be given access to a portal where new tickets can be created. We will keep the old customer forum sections and ticket system available for current cases to be resolved.
