vCenter Monitong with vmware wizard
benningtonr
Re: vCenter Monitong with vmware wizard
Post by benningtonr »
I did not get this prompt, why would that be?
In which directory do you want to install the executable files?
[/usr/bin]
benningtonr
do we point this ip address at a physical host, or the vcenter itself?
yancy
Re: Still having problems with VMWare
Post by yancy »
benningtonr,
Can you explain which directions you followed?
-Yancy
vcenter
benningtonr
that is what i am pointed to and all my returns a NULL.
I am using the FQDN and it is resolvable.
I installed the sdk and perl items that were in the directions.
First can you verify that a file exists here
ls -l /usr/local/nagiosxi/etc/components/vmware/
Can you open the file and verify that the correct username nad password is in the file and on 2 separate lines.
If so, Can you use that file and run the following command
cd /usr/local/nagios/libexec
./check_esx3.pl -D <hostname> -f /usr/local/nagiosxi/etc/components/vmware/<host>_auth.txt -l runtime
benningtonr
Stupid question here, is the username for vmware access or nagios access?
What exactly is the username being used for so I can give it the correct one.
You need to enter the username and the password for accessing the vmware vCenter. You should have these in the "/usr/local/nagiosxi/etc/components/vmware/<host>_auth.txt" file. If you have something else, the check will fail.
benningtonr
Ok, i have the correct username in there, i think, domain\username, we use AD authentication.
getting this error:
[root@nagios libexec]# ./check_esx3.pl -D 192.168.99.134 -f /usr/local/nagiosxi/etc/components/vmware/whroesx4_whro_local_auth.txt -l runtime
Can't locate Nagios/Plugin.pm in @INC (@INC contains: /usr/local/lib/perl5 /usr/local/share/perl5 /usr/lib/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib/perl5 /usr/share/perl5 .) at ./check_esx3.pl line 32.
BEGIN failed--compilation aborted at ./check_esx3.pl line 32.
