Hi @ram.bhatta,
As this issue is not one that I am familiar with, and would require duplicating your server to replicate, I would suggest opening a case with our support department. You can open a case here: https://answerhub.nagios.com/support/s/
Nagiosxi Upgrade failed from 5.10.0 to 5.11.2
danderson
Re: Nagiosxi Upgrade failed from 5.10.0 to 5.11.2
No update yet, I wasn't able to replicate your output of "yum list installed mariadb-devel"
This is my output
This environment allows for a successful install of XI 5.10.0 and and upgrade to 5.11.2 so it's possible this package difference is causing issues. It's odd that you have a rhel7 mariadb repo on an Oracle Linux 7.9 OS.
This is my output
[root@localhost ~]# yum list installed mariadb-devel
Loaded plugins: ulninfo
Installed Packages
mariadb-devel.x86_64 1:5.5.68-1.el7 @ol7_latest
Do we have an update on NDO part, as this is not let us to upgrade our environment.
danderson
Just to make sure it's not anything related to packages. Do you have the following installed?
mariadb
mariadb-devel
mariadb-libs
mariadb-server
