XI2024 | MyTools
bbahn
Re: XI2024 | MyTools
Post by bbahn »
It seems maybe you're trying to access it by clicking the URL? It seems that this won't work. Instead you should be selecting your tool under My Tools or using the blue view arrow under Actions. It is weird to me that clicking the URL doesn't bring you to the website but instead to a local directory in the webroot, but that's how it currently seems to work. If subdirectories don't work, then it may be a bug though.
snapier3
Post by snapier3 »
bbahn wrote: Fri Dec 08, 2023 11:27 am It is weird to me that clicking the URL doesn't bring you to the website but instead to a local directory in the webroot, but that's how it currently seems to work. If subdirectories don't work, then it may be a bug though.
This is where I'm at with it too...
I'll add that to my list of things to look at back-end wise and see if I can find what gives.
snapier3
Post by snapier3 »
I think I found the issue...
In the respective [My/Common]tools.php
There is a double URL encode thing going on...
echo '<td><a href="' . urlencode(encode_form_val($r["url"])) . '" target="_blank">' . encode_form_val($r["url"]) . '</a></td>';
Should be
echo '<td><a href="' . encode_form_val($r["url"]) . '" target="_blank">' . encode_form_val($r["url"]) . '</a></td>';
snapier3
Post by snapier3 »
So yeah, removing the double encode works in the common tools and mytools flavors.
<?php
        $mr = get_commontools();
        foreach ($mr as $id => $r) {
            echo "<tr>";
            echo "<td>" . encode_form_val($r["name"]) . "</td>";
            echo "<td>";
            if (is_admin()) {
                echo "<a href='?edit=1&id=" . $id . "&nsp=" . get_nagios_session_protector_id() . "'><img src='" . theme_image("pencil.png") . "' alt='" . _('Edit') . "' title='" . _('Edit') . "' class='tt-bind'></a>&nbsp;";
                echo "<a href='?delete=1&id=" . $id . "&nsp=" . get_nagios_session_protector_id() . "'><img src='" . theme_image("cross.png") . "' alt='" . _('Delete') . "' title='" . _('Delete') . "' class='tt-bind'></a>&nbsp;";
            echo "<a href='?go=1&id=" . $id . "&nsp=" . get_nagios_session_protector_id() . "'><img src='" . theme_image("b_next.png") . "' alt='" . _('View') . "' title='" . _('View') . "' class='tt-bind'></a>";
            echo "</td>";
            echo "</tr>";
        if (count($mr) == 0) {
            if (is_admin())
                echo "<tr><td colspan='3'>" . _("You haven't defined any tools yet.") . " (<a href='?edit=1'>" . _("Add one now") . "</a>)</td></tr>";
            else
                echo "<tr><td colspan='3'>" . _("No common tools have been defined yet.") . "</td></tr>";
bbahn
Post by bbahn »
That will work, but I think the proper way to fix this would be to split off the initial http:// https:// using a regex like this ^https?:\/\/ and then merging that back with the rest of the string that did go through the urlencode. Otherwise you're not sufficiently protecting against malicious URLs.
Post Reply
