Website monitoring verifying NTLM Auth
gm_rajkumar
Re: Website monitoring verifying NTLM Auth
Post by gm_rajkumar »
I can see the results from curltest file, however i couldnt get it from check_http_ntlm plugin. So what needs to add further on this .
I can see huge output, i just shared last portion for your reference.
HTTP/1.1 200 OK
Cache-Control: private, max-age=0
Content-Type: text/html; charset=utf-8
Expires: Tue, 17 Jul 2012 16:21:58 GMT
Last-Modified: Wed, 01 Aug 2012 16:21:58 GMT
Server: Microsoft-IIS/7.5
SPRequestGuid: 8cd9f7bd-77f6-439a-b3b6-54a068a82b20
Set-Cookie: WSS_KeepSessionAuthenticated={8219e197-e678-4cb9-95a8-31f2167c42c3}; path=/
X-SharePointHealthScore: 0
X-AspNet-Version: 2.0.50727
Set-Cookie: http%3A%2F%2Fintranet%2Edanagas%2Enet%2FDiscovery=WorkspaceSiteName=SW50cmFuZXQ=&WorkspaceSiteUrl=aHR0cDovL2ludHJhbmV0LmRhbmFnYXMubmV0&WorkspaceSiteTime=MjAxMi0wOC0wMVQxNjoyMTo1OA==; expires=Fri, 31-Aug-2012 16:21:58 GMT; path=/_vti_bin/Discovery.asmx
Persistent-Auth: true
X-Powered-By: ASP.NET
MicrosoftSharePointTeamServices: 14.0.0.6114
Date: Wed, 01 Aug 2012 16:21:58 GMT
Content-Length: 132979
Regards,
Raj.
yancy
Post by yancy »
Well if that's working, then test on the plugin.
./check_http_ntlm http://mynet.test.com/SitePages/Home.aspx testuser abc@123n
and check the results if it fails:
cat /tmp/check_http_ntlm
gm_rajkumar
Excellent Yancy!!!!!!! Its working fine.. Great
yancy
Post by yancy »
Glad to hear it's working!
-Yancy
