Disabled Hosts Still Monitored
jbennett
Re: Disabled Hosts Still Monitored
Post by jbennett »
-r-sr-xr-x 1 root root 80057 Jul 24 15:54 check_icmp
-rwxr-xr-x 1 root root 80892 Jul 24 15:54 check_ping
I am wondering if this has something to do with permissions though. When I try to schedule down time, or acknowledge a host or service, I get the following:
Error: Could not open command file '/usr/local/nagios/var/rw/nagios.cmd' for update!
When I check nagios.cmd permissions, I see the following:
prw-rw---- 1 nagios nagiocmd 0 Aug 8 16:27 nagios.cmd
and on the /rw folder:
drwxrwsr-x 2 nagios nagiocmd 4096 Aug 8 18:48 rw
I'm wondering if permissions system wide might be wrong?
When I run a permissions check, I see that the Config Scripts and Config Files permissions appear to be ok.
Is there a script that I can run that might reset permissions system wide or am I running into two different issues here?
nscott
Post by nscott »
That nagiocmd group on the nagios.cmd is troubling, it should be nagcmd, can you try restarting the nagios service manually?
service nagios restart
Does that change the group to nagcmd?
Nicholas Scott
jbennett
Post by jbennett »
It does not.
I should note that I followed some directions after searching for a resolution to the issue. Apparently, that wasn't the best move.
When I go to check the groups on the system, I see a group for nagcmd (the comment I made previously, was from my looking on the wrong box).
I'm hoping even more that this is something we can resolve relatively easily.
would taking these steps resolve?
usermod -G nagcmd nagios
usermod -G nagcmd apache
please attach your file locate at
/etc/init.d/nagios
jbennett
Post by jbennett »
Please find attached.
I'm still trying to decipher how you have nagiocmd instead of nagcmd as the group.
Did you try to recompile nagios core outside of one of the XI install or upgrade scripts?
What version of XI are you running?
jbennett
Post by jbennett »
The directions I found online suggested to make the group nagiocmd and change permissions to that group. I have since reverted back now for the /rw folder and the nagios.cmd file.
Apparently, the error message i'm getting is pretty common and the solution is always listed as making sure you have the group as nagiocmd and the file permissions set appropriately.
I am on 2011R2.3 currently.
Where are you finding these solution? I searched our whole forum for "nagiocmd" and only found this thread...
jbennett
Post by jbennett »
Not here, in various other online blogs/threads/posts/email lists/etc.
I changed the group of that file and folder and I still don't have the ability to acknowledge and/or schedule downtime.
I should note that if I chmod 777 /usr/local/nagios/var/rw/nagios.cmd, I'm able to schedule down-time and to acknowledge without error.
I see though that this might not stick with a reboot. I guess I will just have to wait and see.
please run the following and return the output
ls -l /usr/local/nagios/var/rw/nagios.cmd
cat /etc/group|grep nag
Also, as I have asked before
