SNMP problem - No data received from host
Re: SNMP problem - No data received from host
It may not work for all of them but you may be able to install the following to run 32 bit plugins on 64 bit machines
yum install glibc.i686 -y
benhank
Post by benhank »
I must have the worst luck with nagios... ran that but issue persists
Proudly running:
Nagios Network Analyser
Nagios Fusion
Do you know where you originally got the plugin check_em01 ?
You may be able to re-download and recompile to get the correct version.
benhank
Post by benhank »
I got it from nagios exchange.
Proudly running:
Nagios Fusion
Ok, looks like you got it here
http://exchange.nagios.org/directory/Pl ... rs/details
So, I'll try to make this easy for you.
copy the attached file to your servers /tmp directory then run the following from the command line
cd /tmp
gcc check_em01.c -o check_em01
chmod +x check_em01
mv -f check_em01 /usr/local/nagios/libexec/check_em01
benhank
Post by benhank »
[root@lkennagios01 ~]# cd /tmp
[root@lkennagios01 tmp]# gcc check_em01.c -o check_em01
check_em01.c: In function âmainâ:
check_em01.c:242: warning: incompatible implicit declaration of built-in function âexitâ
check_em01.c:292: warning: incompatible implicit declaration of built-in function âexitâ
[root@lkennagios01 tmp]# chmod +x check_em01
Proudly running:
Nagios Fusion
One more command you missed...
benhank
Post by benhank »
This is resolved. You guy's can lock this. And thanks for the awesome assistance.
Proudly running:
Nagios Fusion
