Yes. same result.
$SERVICEOUTPUT$ macro
Re: $SERVICEOUTPUT$ macro
Are you just running this from the command line or are you adding it to the command definition?
Because running it from the command line isn't going to fill the macro's and you will just get the $ $ $ output like you did....
